Gemini Diff Mounting Designs
#1 _Viper_
Posted 14 April 2010 - 08:05 AM
The problem with Gemini's is that standard they have a 3-link "Torque Tube" setup and when trying to convert to a diff
from another car there is very little room and no stock mounting points to fit upper control arms, Even If I was allowed
weld new mounts to the floor the upper control arms would only be about 5" long and have to remove the sway bar..
Here's a couple pics of the stock diff:
Ive come up with a couple of designs... the First is pretty much a copy of the Ford RRS 3-Link kit
Im using a Hilux diff and the diff carrier bolts in the front the same as a 9" so im planning to use these studs to mount a center "control arm" the same as RRS do but instead of going all the way to the g/box (which isnt possible in a Gem) I will just goto the stock "torque tube" mounts (Red Arrow) and then Ill possible have to use a 2-peice tailshaft to stop the shaft hitting the Torque tube mount as the suspension is dropped (would this be required? under normal driving conditions the shaft wouldnt hit the mount, but if you jacked up the car from the body it would...)
So thats basically the first one, Id have to check if I need to used a bushed end or can use a rose joint on the end and I need to work out what sort of forces are in action in this area and how strong it has to be.
Ok Design number 2... Firstly this question will answer if this will work or not... Do upper control arms have to be striaght? or can they be bent to run down first then forward... this pic will explain better
This is side on of the diff (not the circle is the axle tube not the diff center)
This is above view
So basically a Triangulated 4-link setup but with the upper control arms bent to clear the floor of a gem.... But yea ive never seen upper arms before that wernt straight so not sure if its possible? is it just a strength thing, and bent arms would just bend more? what if I could brace them sufficiently? or is there geometry issues...
But yea opinions or suggestions would be great, I know ill still have to work out pinion angles and geometry, But im just trying to get some basic designs and a couple options to show the engineer and then we can go from there.
#2 _moot_
#3 _Viper_
Posted 14 April 2010 - 08:01 PM
Ok for a drag car tho.
Posted 14 April 2010 - 09:11 PM
You could add a plate to both ends of the tube so it can be bolted to the factory lower arm mount as well as the torque tube mount.
If the engineer does not like the single arm then add another arm in the same position on the other side.
Edited by ls2lxhatch, 14 April 2010 - 09:12 PM.
Posted 14 April 2010 - 09:13 PM
Engineer wont sign off on it, as its looked at as a Single ladder bar as well as requiring mounts to be welded to the floor, plus would favor cornering in one direction more then the other..
Well that eliminates your 3 link setup too then, its basically the same thing if you can only do a short centre arm. A Commodore style 4 link with panhard rod would be good (top arms can be somewhat shorter than bottom without significant adverse effects), but I don't see how you'd find anything solid to mount the top arms to.
edit: added quote for clarity since someone beat me to post
Edited by 76lxhatch, 14 April 2010 - 09:14 PM.
#6 _Viper_
Posted 15 April 2010 - 08:36 PM
And no, The Mcdonalds bro kits is offset to one side which is why its looked at as a single ladder bar and creates different handling characteristics depending on which way you turn which they dont like. My design is the same as a the RRS kit which is engineer approved, it has to be center mounted just like the Stock setup.
Its also something to do with the fact the control arm is solid mounted to the top and bottom of the diff, as one side of the diff raises (going over a large bump etc) there is little allowance for the diff to rotate, and is once again worse one way more then the other... adding another arm the same would make it worse... Ladder bars are for Drag cars only... thats why my design has to be as close to the stock setup as possible for them to even think about allowing it.If the engineer does not like the single arm then add another arm in the same position on the other side.
Thats pretty much what my second design is, Geminis have a panhard rod standard.... But thats why I asked the question of if the control arms have to be straight or can they be bent to clear obstacles?A Commodore style 4 link with panhard rod would be good (top arms can be somewhat shorter than bottom without significant adverse effects
Edited by Viper, 15 April 2010 - 08:49 PM.
#7 _Bomber Watson_
Posted 15 April 2010 - 09:12 PM
Center arm is way to long.
Posted 16 April 2010 - 07:21 AM
Your short 3 link will act in exactly the same way (Bomber's comment appears to be backwards, the longer arm is desirable to minimise the pinion angle change). The original torque tube does this too but you want to be chasing better options. Twin ladder bars has to be better than the short 3 link with regards to sideways load as it gives the same up and down movement but less roll.Its also something to do with the fact the control arm is solid mounted to the top and bottom of the diff, as one side of the diff raises (going over a large bump etc) there is little allowance for the diff to rotate, and is once again worse one way more then the other... adding another arm the same would make it worse... Ladder bars are for Drag cars only... thats why my design has to be as close to the stock setup as possible for them to even think about allowing it.
No reason why they can't be bent that I know of, but they may end up too large with the bracing required to actually fit. Unfortunately the length and mounting point is a long way from ideal - you effectively have the top arms significantly longer than the bottom which reverses the normal pinion angle change and you're concentrating all the leverage on a small portion of the floor pan which will require a fair bit of strengthening. But with the front mounting points so close together you're getting back to the ladder bar design anyway...Thats pretty much what my second design is, Geminis have a panhard rod standard.... But thats why I asked the question of if the control arms have to be straight or can they be bent to clear obstacles?
If the McDonald Bros kit mounts at the same place that the torque tube did then you're keeping the factory geometry (two bars may be better than one as above). If you want to go four link then you're going to need new mounts for the top arms somehow. Please note I'm not an engineer.
#9 _Viper_
Posted 16 April 2010 - 07:52 AM
If I went with the second design Im pretty sure I could get both the upper and lower arms equal length, which is the most desirable right?
Im going to be fitting the diff to the car (with the lower arms, springs, shocks, panhard rod) and get the pinion pointing in the right direction then ill have a better idea of what will fit.
But yea I agree a Longer arm like the RRS kit is much more desirable as the forward and back movement is less as it moves through its arc. But in saying that my 1st design is the same length as the stock torque tube so it would be no worse then standard
Edited by Viper, 16 April 2010 - 07:53 AM.
Posted 16 April 2010 - 04:26 PM
The ladder bars act exactly like the centre arm in the 3 link, they roll the diff as it moves up and down rather than attempting to keep it level like a 4 link.
Correct, and effectively the McDonald Bros kit is the same except with a little offset but much more integrity.But in saying that my 1st design is the same length as the stock torque tube so it would be no worse then standard
#11 _Bomber Watson_
Posted 16 April 2010 - 06:33 PM
If so then it will screw the pinion angles...
If it is pivoted at the diff end then ignore my comment.
As do ladder bars.
#12 _Viper_
Posted 16 April 2010 - 07:58 PM
#13 _Bomber Watson_
Posted 16 April 2010 - 08:27 PM
Cant see any other drama though.
Posted 16 April 2010 - 10:14 PM
That's right, hence why a longer arm is better - less change in angle due to the bigger arc.The way im looking at that RRS kit its mounted to the diff solidly like a ladder bar not pivoted?
With the 4 link, visualise (or plot) the arcs of the top and bottom arms and how they intersect and affect the pinion angle. Roll centre is an interesting one, still trying to wrap my head around that but I think that the panhard rod is going to largely control it if the arms are parallel, triangulating them would cause unnecessary hassles in this area.
#15 _Bomber Watson_
Posted 17 April 2010 - 12:19 PM
Yes your right a longer arm is better with a ladder bar, but if your designing a system from scratch its not the way i would go due to the changing pinion angle....I get what you mean now with me being backwards, i knew what i ment haha...
A simple pivot on the diff end as well would fix all problems
Edited by Bomber Watson, 17 April 2010 - 12:20 PM.
Posted 17 April 2010 - 12:31 PM
Posted 17 April 2010 - 09:13 PM
Aim for the ideal setup then come back to the real world and see what compromises have to be made...
#18 _Viper_
Posted 18 April 2010 - 12:52 PM
But in the interest in improving things, altho a little more complicated I believe I can get a Parallel 4-link setup to work also. With bent arms running at a diagonal from the top of the diff down and then parallel to the floor to the stock Torque tube mounts locations (where I would have a custom cross member incorporating a tailshaft loop, Only problem atm is that the upper arms will be about 200mm longer then the lower arms so not 100% ideal...
I think the next step is to talk to an engineer and see what direction he thinks is the best to head, then it will be a matter of working out what forces are involved and how strong the arms need to be as well the best location for pivot points.
Edited by Viper, 18 April 2010 - 12:55 PM.
