air filters? does the shape and size make a difference
8 replies to this topic
#1 _lc202_
_lc202_
Posted 10 May 2010 - 11:43 AM
i have a worked black 202 in my lc torana fitted with a 350 holley.
i know with modern efi styled motors air box size makes a diffence to performance, is it the same with a carb style motor with the air filters.
eg. am i better off going for a larger diameter, slim style air filter or a smaller diameter, taller style of filter or is it just basically cosmetic.
cheers Rick
#2 TerrA LX
Posted 10 May 2010 - 02:31 PM
You are better off with a large diameter TALL air filter.
#3 _cruiza_
_cruiza_
Posted 10 May 2010 - 05:41 PM
^^^ agreed years ago I saw someone spent a bit of time playing on a dyno and found that a set of mini tumpets fitted to the top of the carb inside a large 4inch tall airfilter added horse power
#4 _lc202_
_lc202_
Posted 10 May 2010 - 05:53 PM
so what i should do is find the largest od filter housing for my holley that i can that will clear the rocker cover (found out that 14" fouls on rocker cover) and then get the tallest filter that i can find that will fit under the bonnet.
can any one tell me who would be the best people to contact to get something along these lines.
#5 _oldjohnno_
_oldjohnno_
Posted 10 May 2010 - 06:50 PM
The majority of air flow into a carb comes in around the circumference of the opening, not straight down the hole. This is why bellmouths with a big radius work so well, and it's also why aircleaners with a smoothly profiled base work well. Eg. the Moroso low profile cleaners, and K&N's stub stack (IMO the one and only half decent product from K&N). It's also why those filters that have filter media across the top (where the lid normally is) often don't flow any better and sometimes worse than a normal filter. Realistically though, a 350 equipped 202 isn't going to need a massive flow capacity so something like an 11-1/2" x 2-3/8" Moroso or similar will have plenty of capacity.
One more thing; if you want your engine to go well and last a long time (as opposed to just going well) then you must use a paper element.
Nothing else - oiled cotton, foam, chicken wire etc. - will filter as well, regardless of what the ads say...
#6 rodomo
  • 18,039 posts
Posted 10 May 2010 - 06:56 PM
:spoton:
#7 _lc202_
_lc202_
Posted 10 May 2010 - 10:17 PM
what the??
that things huge, does the bonnet even shut, btw where is that from
thank old johnno ill look into them, its actually a 350 that has been rebuilt as a 500.
#8 Heath
  • 18,393 posts
Posted 10 May 2010 - 10:53 PM
The revs will dictate how much air the car needs, the carb will have some influence but it won't make the motor bigger :P
The air filter rodomo showed is off a grey motor I believe.
#9 rodomo
  • 18,039 posts
Posted 11 May 2010 - 12:15 AM
Yes, an oil bath air cleaner.
FX-FJ (and others?) but going by the battery position, that one would be FX-FJ.
When did Holden first use a paper element?
FB? :dontknow: I forget?
Edited by rodomo, 11 May 2010 - 12:20 AM.
