QLD transport - engine upgrade
_holdon_
Posted 28 May 2010 - 10:26 AM
Can anyone here confirm this? To me this doesn�t seem right as there are rules on capacity etc that would regulate what you can and cant use. Plus I think when I got this plate done the engineer wrote what engine it was in his paper work.
The V8 engineers approval is also just a blue mod plate.
My car is LC and I am in qld.
Posted 28 May 2010 - 11:22 AM
It will also be recorded with D.O.T.
Changing engines requires inspection by D.O.T.
Failure to do so is an offence. It may also void your insurance.
You should be able to fit another engine of the same capacity, but you still need the new engine number changed on your rego papers.
_mumstaxi_
Posted 28 May 2010 - 12:59 PM
Yes you will need a new Blue plate for a different engine unless it is exactly the same as what was removed, even a 5L V8 changed to a later model 5L V8 can require mod plating if the engines are manufactured years apart,this is due to the fact that you need to retain "all" the pollution gear from the later (cleaner emissions) engine.
For example i went from a 186 Turbo 6 (3 litre), to a RB30 Turbo 6 (also 3 litre) but needed a whole new mod plate as the RB30 required fitment of things like a Catalitic converter to be legal, a lot of people also dont realise that if you revert back to the factory engine (in my case a 173) you need "another" mod/blue plate to do so !
They may want to sight your car/engine and mod plate @ DOT
MT
Posted 28 May 2010 - 02:45 PM
_mumstaxi_
Posted 28 May 2010 - 04:11 PM
To modify a car from how it has been "designed/manufactured" to something else (even back to the way holden built it) still requires approval, and a new inspection and plate, and you can't just remove the old blue plate, it must remain along with the new one(even tho a lot of people do remove the plate,but remember it is still recorded at DOT)
Thats why its a good idea if you plan to get a mod plate for your eng,gearbox,diff,rollcage etc ,that you get them all mod plated at the same time so you can have them all on one blue plate, if you get them at different times you will have 4 mod plates because the 4 mod plates can not be removed and replaced with 1 later on.
MT
_nunganunga_
Posted 28 May 2010 - 07:07 PM
This very rarely happens. Approved persons are rarely/never audited. You may fly under the radar, but if the shite goes down, it can be traced back with the mod plates serial numbers.
What is written on your certificate?
The police are the only people allowed to remove blue plates.
_Kush_
Posted 28 May 2010 - 08:12 PM
_mumstaxi_
Posted 28 May 2010 - 10:10 PM
You can actually have them in the boot,door jam area,or other,as long as a person (police,DOT,insurace) can find and read it easy,and its attached to the main body of the car and not a removable panel.
Most people will look under the bonnet for a mod plate, if you dont have a show car and like to go to places that get "busted" ,the best way to avoid hassle is put your mod plate in the engine bay.
If you do have a show car, ask your engineer about other locations for mod plates,or even ask if you can fit it yourself with his guidance(by rights he is supposed to do it so he may refuse) also ask if he/you can get the plate profesionally engraved (instead of just scratching details into it with a scribe) and request the use of stainless steel pop rivets to attach the plate.
MT
Edited by mumstaxi, 28 May 2010 - 10:11 PM.
_nunganunga_
Posted 29 May 2010 - 07:20 AM
_AGGRO_
Posted 29 May 2010 - 08:27 AM
Posted 29 May 2010 - 04:57 PM
A few people have been nailed in the not too distant past for compliancing illegal mods and not submitting paperwork, so the above is incorrect. �Just because the busts are not advertised may indicate something for you. �Just because the cops/inspectors don't turn up to a workshop (in uniform anywayIt will only be recorded at the transport if the fella who put the blue plate on, sends his paperwork in.
I also know of some plates floating around loose that used to belong to someone who is currently in gaol. �Suffice to say, if those numbers turn up, someone is in trouble.......
If the cops/inspectors are worried enough to check (and we now have a flying squad of skilled inspectors to attend vehicles at any hour of day or night, so that is more likely, as they can pull it from th computer inside their car), and no report shows up, bye bye car, summons to engineer.......
And if they don't write on the report while you are there or show it to you, there is a problem. �I had to talk my compliance guy through what actually had to go on it.
Grant..
_mumstaxi_
Posted 30 May 2010 - 08:20 AM
MT
Posted 30 May 2010 - 09:29 AM
Yep that is correct. So dont know how people got away with it in the boot?
Strangely enough, it was my engineer who suggested putting the blue plate in the boot!
Like some aspects of the modification... it all comes down to interpretation. While one inspector may insist that the blue plate be fitted in the engine bay, another may not.
It's a good question to ask your consulting engineer!
I would also like to add to this thread.... that the reason for fitting the blue plate is not only for compliance reasons, but also to inform the next owner of modifications done.
_AGGRO_
Posted 30 May 2010 - 11:31 AM
Posted 30 May 2010 - 01:01 PM
Posted 01 June 2010 - 06:24 PM
Yes Grant, and while on the subject of paper work..... you are also required to carry/produce on request, your "Certificate of Modification" this is a little green bit of paper with its own seperate ID number (as well as blue plate number) plus has "all" the details of who/what/where, including a Description of Modification/s (in detail)
MT
Steve,
there is no requirement for that anymore. �All certificates are saved digitally by Transport, so cops or inspectors can access them that way.
Good to have, but I didn't get one, and that was five years ago
Grant..
_mumstaxi_
Posted 02 June 2010 - 09:05 AM
I think i will still be keeping mine in the car regardless (well,when i have a car) just in case (as mentioned by nunganunga below) if the correct paperwork has not been submitted /lodged correctly by the engineer, it could save a bit of hassle on the side of the road, as it undisputedly identifies exactly what the plate is for !
I guess i would look at it the same way as.......sure, you may not have to carry a open drivers licence in QLD, but everyone knows if you get pulled up, its a sh*t load easier if you have it on you.
MT
Posted 02 June 2010 - 09:24 AM
I thought that rule had changed also?
_mumstaxi_
Posted 02 June 2010 - 12:11 PM
I guess it depends on your own interpretation of should and must, open lic holders "should" carry licence, and provisional lic holders "must" carry licence at all times.
Below from The QLD Police service site..... http://www.police.ql...fety/licReg.htm
"If you are an open driver licence holder you should always keep your driver licence with you at all times when you drive and show it to a police officer upon request. If you do not have the open drive lience with you, you may be given 48 hours to produce the open driver licence to a police station nominated by the police officer. You may be fined if you do not do this".
As i understand it "should" does not mean you have to , and you "may" be fined if you dont produce it within 48hrs.
MT
Posted 02 June 2010 - 12:34 PM
"should" is being removed from all governmental docs and legislation..............
Grant..
