Hi There,
My LC GTR originally had antique gold trim.
Unfortunately a previous owner has done heaps of changes to the interior
1) Does anyone know what colour the dash bits are supposed to be ??
Looks like the metal work was originally painted a gold colour (it's been re-painted black)
2) Should the dash pad be a gold colour ?? (it's also presently black)
3) Should the console still be black ??
4) Do the door trims have gold with a silver centre ??
Anyone ??
Regards
David
LC GTR Gold Interior colours ??
_VerdoroGTR_
, Nov 25 2005 09:35 PM
9 replies to this topic
#1 _VerdoroGTR_
Posted 25 November 2005 - 09:35 PM
#2 _lcgtr_
Posted 26 November 2005 - 03:17 AM
Whats the trim code on the plate
#3 _VerdoroGTR_
Posted 26 November 2005 - 08:47 PM
Trim Code is
1194 41X
Not sure about the 1194 part but I thought that
the 41 X means Antique Gold ,without any cloth inserts
Whats you thoughts ??
Could the 1194 indicate other colours in the interior
David
1194 41X
David
#4 _houndstooth_
Posted 26 November 2005 - 09:26 PM
Well Im not too sure about the LCs, but the HG gts monaro (made around the same time) shared a lot of the same bits. the paint was a solid colour not metallic and was more like poo yellow, but the vynil used was goldy
Dash pad= gold vynil
metal work=gold
Dash instrument cluster= black like normal
Console=gold
seats=gold
Beigy gold carpet
Door trims and kick panels gold and so are the bits that go on the window sill of the door, was gold vynil..
Hope that helps a little.
Mick
metal work=gold
Console=gold
seats=gold
Beigy gold carpet
Mick
#5 _houndstooth_
Posted 26 November 2005 - 09:27 PM
Oh and the steering wheel boss and column was gold but the horn button black
#6 _gm3300_
Posted 26 November 2005 - 09:44 PM
the number 1194 is the Holden order code for the paint colour, the number that appears on the paint line of the tag is the Dulux paint code info. I don't have the parts book at hand i'll check tomorrow and see what colours the dash bits should be.
grant
grant
Posted 27 November 2005 - 08:02 AM
I seen some NOS gold trim in a shop in Coburg, about 12mths ago. I got nos gtr door trims in sandelwood from them, thanks to HG350.
#8 _gm3300_
Posted 28 November 2005 - 05:15 PM
Hi VerdoroGTR
here's some answers to your earlier questions,
(1)this is from the Dulux info in Fiv's book, all the 41 code interiors were Antique Gold in the following areas
Ash tray lid- Antique Gold-Dulon Suede
Instrument panel/upper steering column assy- Antique Gold-Dulon Medium Gloss
Seat adjuster guard/seat side arms- Antique Gold-Dulon Medium Gloss
(2) according to the LC parts book all the 41 code PAD ASSY-Instrument panel
are the same colour, Antique Gold.
(3)the console should be black, the Opel console has the hole offset to the left and is vinyl covered, the M20 console has the hole centered and is a black blow moulded item.
(4)I'm fairly sure the X in the code means it has a silver flash in the trim (my 40X LC had silver)
Also the LC GTR has a black wheel boss and horn button, whereas a HT,G would have been Antique Gold, hope this helps
grant
grant
#9 _VerdoroGTR_
Posted 29 November 2005 - 08:12 PM
Thanks Grant,
Given me a few clues
I've got the FIV book so I had a look see at the info you quoted.
Not sure about it having a gold dash pad though. The existing one
(Black) looks fairly undisturbed since new. The gold painted dash metal work
is a definate as I can see bits here and there after removing some bits off the
dash.
David
dash.
David
#10 _gtr-xu1_
Posted 30 November 2005 - 11:04 PM
Verodogtr,
I too have a 70 gtr verodo green with antique gold interier. If your after any gold trim Reg from muscle car motor trimming has it in stock.
Reg 0732946805
Reg 0732946805
