VETTEL
Posted 31 May 2010 - 09:51 PM
Posted 31 May 2010 - 10:18 PM
Edited by rorym, 31 May 2010 - 10:21 PM.
_Herne_
Posted 31 May 2010 - 10:39 PM
Herne
_CraigA_
Posted 31 May 2010 - 10:42 PM
A few examples for next time Vettel's ego gets in the way of Webber winning.
Posted 31 May 2010 - 11:08 PM
Doesn't make a lot of sense to me to punch someone with a helmet on?
Posted 31 May 2010 - 11:12 PM
_Yella SLuR_
Posted 31 May 2010 - 11:31 PM
But then again, I might be a little biased.
Edited by Yella SLuR, 31 May 2010 - 11:33 PM.
_Dirty Deeds_
Posted 01 June 2010 - 07:23 AM
You dont go around the outside then turn right to go through a left hand corner when the car you passed has his front wheel in your side pod...too easy for me.He tried the punt and lost...over and out. Watchs Webbers view...look where his front wheel is when Vettel turns right.In V8 Supertaxis he would do a drive through.
Mark will win the championship, nuf-said
Posted 01 June 2010 - 07:48 AM
_JS192_
Posted 01 June 2010 - 10:26 AM
Webber now has a 15 point buffer on his most serious rival for the world championship, as Vettel gained no points from the race
_AGGRO_
Posted 01 June 2010 - 11:14 AM
If they were managing their two drivers they would have ordered them to do this at the same time. Or told seb to hold position.
Also vettel is at fault for the move itself but also for not thinking naturely enough to sit in behind him instead of risking it all to get one spot. Now he has hurt his chances of the championship a bit. And also shame on Christian Horner saying it was both at fault and webber should have given him more room. How was he meant to do that? He came across too quickly for mark to react. And same goes for red bull's right hand man saying webber should have conceded the spot. Shows a bit of favouritism in the team if you ask me.
_JS192_
Posted 01 June 2010 - 11:38 AM
I agree aggro, what Christian Horner said was disapointing; it was actually a perfect example of great defensive driving on Mark's part.
He squeezed Vettel so there was only just enough room to get up along side him, and then held his line parallel to the track...
Did he give him enough room to move across and get a good line for the corner? of course not! he shouldn't have. It is racing!
Vettel made a mistake in his judgement.. its as simple as that
Edited by JS192, 01 June 2010 - 11:41 AM.
_73LJWhiteSL_
Posted 01 June 2010 - 12:58 PM
Steve
_oz772_
Posted 01 June 2010 - 06:28 PM
Posted 02 June 2010 - 11:46 AM
I'm starting to dislike Vettel more and more.
They say he is the new Schumacher, and this goes a way to prove it.
If you can't beat them, crash into them.
If Mark had yielded it is true that he would have lost only one spot, but he also would have lost the championship lead, and once Sebastian was in front we all know that Red Bull would have favoured him even more openly.
Its easy to see that Seb made a desperate lunge because after that lap he would have to go to the same fuel setting as Mark and would have no chance of passing him once that happened.
I don't blame him for trying to pass, or even for the crash, he didn't mean to take himself out, but to blame Mark and for the team to blame Mark is unforgiveable.
I hope Mark takes the championship and goes to another team now. Red Bull have shown their loyalty to Sebastian, which is fair enough given that Mark will retire soon and Seb is the new up and coming star, but come on, it was clear who was at fault.
You have to wonder how else they favour him....
_Woodsy_
Posted 02 June 2010 - 04:35 PM
_waratah_
Posted 10 June 2010 - 11:07 AM
Webber knew the risks squeezing vettel out as much as vettel knew the risks of trying to get the race line!
If one of them shirked the issue well maybe they should go race against a clock and not other cars directly?
Shit happens in racin, generaly spreads around abit more the bigger the sheep stations they race for!
Posted 11 June 2010 - 07:10 PM
Vettel swerved to the right to get closer to the ideal line through the corner but hadn't done the job yet and there was still another car there....
_waratah_
Posted 12 June 2010 - 01:05 PM
well i consider webber was not on the race line or the inside line, the footage from vettels race cam shows webbers reluctance to commit to any one line, thus he was "defending" or squeezing out vettel!Webber didn't squeeze him out, he held the same line....that is the whole point of the arguement....
Also it appears vettel may of crab walked when he braked thus sending him into Webber!
Out of all this few mention the Mclarens were catching webber as vettel did too! I think webber was lucky to increase his lead in the championship as he was staring down the barrel of a 4th placed finnish (you cant hold mclarens out on straights)
_AGGRO_
Posted 12 June 2010 - 03:21 PM
#21
_waratah_
Posted 13 June 2010 - 03:11 PM
When Vettel got past Hamilton as a result of pit stops, vettel was very fast and matched Webber until the "incident' When you sit back behind another car traditionally you use less fuel than the car out in front (although tyer wear and overheating of brakes/engine can happen if you dont get enough clear air)The only reason they were all catching him was because he had to turn down his fuel map to use a touch less fuel. which all the other drivers had to do in the laps after the incident anyway. But RBR told Vettel that Webber was a bit slower which is shit. Vettel sits back in the race while Mark goes out leading the whole thing for RBR and thats how they repay him by telling Vettel that he has more pace so should have a crack
If webber was holding vettel back and thus being endangered by the mclarens who were staying within striking distance common sense would tell you that its best for red bull if the faster man goes ahead!
Whatever happened it all worked out better for Mark as was not going to win that race and increase his lead in all probabilities!
#22
Posted 22 June 2010 - 05:40 PM
Have you seen Formula 1 before?
There wasn't much chance of anyone passing him unless Seb managed to do it where he tried.
You are right, he is better off now in terms of his team mate because he got a bigger gap from Vettel, but had he won that race he would now be leading the championship instead of being in 3rd.
#23
_waratah_
Posted 23 June 2010 - 05:52 PM
Ive made 3 posts in here, you ignore all of them but use 1 sentance so you can get smart like this.Have you seen Formula 1 before?
My opinion differs, if you can't handle that then theres always facebook or bebo
Edited by waratah, 23 June 2010 - 05:53 PM.
#24
Posted 23 June 2010 - 06:40 PM
In my opinion, the other 3 cars would have struggled to pass Mark due to the fact that they also had to turn down their engines to conserve fuel.
The Mclarens were faster on the straights but the Red Bulls were faster everywhere else...
The fact remains, had Vettel been driving anything but a Red Bull and had done that the stewards would have deemed it careless driving and his team would have been punished.
At the very least he robbed us of a thrilling end to the race!
Edited by Potta, 23 June 2010 - 06:43 PM.
#25
_waratah_
Posted 23 July 2010 - 07:47 PM
\Mark webber in the press conference before this Weekends German Grand Prix!if you look in Turkey we were not fast enough. We had an incident on the track but we were not fast enough in the grand prix.
