Cable clutch throwout bearing
40 replies to this topic
#1 _SLR Goat_
_SLR Goat_
Posted 05 June 2010 - 05:50 PM
I think i need a different throwout bearing for my cable clutch setup the kit i have is to suit uc torana pull type clutch the new bearing in the kit is the same as the old one that came with the bellhousing and clutch fork only problem is the bearing doesnt sit firm in the fork has about 5mm gap on each side i think i need a bearing from a early commodore or maybe wb or will it be fine to run with this bearing
cheers dennis
pics of bearing and fork
https://cache.gmh-to.../Picture173.jpg
Edited by SLR Goat, 05 June 2010 - 05:50 PM.
#2 TerrA LX
Posted 05 June 2010 - 07:01 PM
Bearing would be the same, check the part number on the carrier.
#3 _SLR Goat_
_SLR Goat_
Posted 05 June 2010 - 07:43 PM
only the bearing came in the kit no carrier looks like one of those types u have to press the old bearing off and press new one on i think the carrier may be wrong then i think i may need the carrier like the one in post 8 of this thread
http://www.gmh-toran...showtopic=44948
Can u buy those or this it a wrecker hunt part
#4 TerrA LX
Posted 05 June 2010 - 08:23 PM
Dellows sell them.
#5 _SLR Goat_
_SLR Goat_
Posted 05 June 2010 - 08:37 PM
Dellows sell them.
:clap: thanks
#6 _diggaman_
_diggaman_
Posted 05 June 2010 - 08:44 PM
Had this drama myself, once someone that knew pointed out the bearing in the clutch kit I purchased was for a push type not pull the problem was fixed with a simple trip to ABS, a plstic type bearing was supplied and no drama. That bearing looks like the original one I had and just couldn't get the adjustment right.
#7 dattoman
  • 16,485 posts
Posted 05 June 2010 - 08:46 PM
ummm.... Does that fork have provision for the 2 little rubber bushes that locate the bearing carrier ?
Are they missing ?
But yes they are a different clutch depending on rat trap vs cable
#8 TerrA LX
Posted 05 June 2010 - 09:10 PM
I didn't know the clutch plate and bearing were different.
#9 _SLR Goat_
_SLR Goat_
Posted 05 June 2010 - 09:18 PM
Im pretty sure that the carrier is wrong i had a look at a spare box i had which has a rat trap setup bellhousing and fork and the carrier and bearing are the same as what was with the cable bellhousing and fork dosent have any rubber bushes...in saying that i have no idea what they look like has wear marks on the fork where the bearing has being rubbing maybe a trip to abs as diggman did might solve the problem
Posted Image[/img]
Posted Image[/img]
i figured they were the same just the throwout bearings changed
Edited by SLR Goat, 05 June 2010 - 09:17 PM.
#10 _diggaman_
_diggaman_
Posted 05 June 2010 - 09:21 PM
Although the bearings look totally different there is a small difference in how they sit in the fork.
You can get a press on bearing to suit if you have the carrier.
Stuff ups are really the only way to learn!!!
#11 TerrA LX
I thought the bearing was the same, just the carrier was different.
#12 _SLR Goat_
_SLR Goat_
Posted 05 June 2010 - 09:22 PM
sorry your right bearing the same carrier different
#13 _diggaman_
_diggaman_
Posted 05 June 2010 - 09:23 PM
that is the same gap I had and looks like a push type.
Fork should be fine.
#14 _SLR Goat_
_SLR Goat_
Did ABS supply you with a carrier and bearing to suit the cable pull type setup?
#15 _diggaman_
_diggaman_
Posted 05 June 2010 - 09:25 PM
Plastic carrier, metal bearing, works, happy!!!
#16 dattoman
  • 16,485 posts
Posted 05 June 2010 - 09:29 PM
Carrier and bearing are supplied as a unit
No pressing anything off
#17 TerrA LX
Plastic carrier, yuck, ring dellows and have them ship a steel on to you.
#18 _diggaman_
_diggaman_
Posted 05 June 2010 - 09:31 PM
Yeah, $60 nicka down here.
Fixed my problem easy.
#19 _SLR Goat_
_SLR Goat_
Posted 05 June 2010 - 09:35 PM
Cheers for all your help peoples much appreciated one less headache
#20 _SLR Goat_
_SLR Goat_
Posted 09 June 2010 - 08:18 PM
Okay have the right bearing now just wanna ask one more thing i bolted it all up and had a look at how much possible travel the fork can go when clutch is disengaged and it seems to have bout 20mm before the fork hits the bellhousing is that enough?
Posted Image[/img]
Posted Image[/img]
Posted Image[/img]
Edited by SLR Goat, 09 June 2010 - 08:18 PM.
#21 _diggaman_
_diggaman_
Posted 09 June 2010 - 10:56 PM
Looks about the same as mine bud and it works fine.
No expert but!!!!
#22 _lx5008_
_lx5008_
Posted 10 June 2010 - 11:01 AM
three different types of bearings
Edited by lx5008, 10 June 2010 - 11:02 AM.
#23 _SLR Goat_
_SLR Goat_
Posted 10 June 2010 - 05:53 PM
I have the middle type bearing i did some measurements with it installed on the fork in the box and it sits at the same distance from the end of the input shaft as the other two plus its the only one that fits the fork properly i guess i will just have to see how it goes when its all in the car :)
#24 _SLR Goat_
_SLR Goat_
Posted 10 June 2010 - 06:08 PM
IM A GOOSE! the answer was staring straight at me adjust the pivot ball its being wound all the way in
thanks all for the help feel free to make fun of me now
cheers dennis
#25 dattoman
  • 16,485 posts
Posted 10 June 2010 - 09:17 PM
Theres a shorter version of the platic one too
And a shorter version of the one on the right specifically for Celica boxes too
