Holley Throttle cable
7 replies to this topic
#1 _rorym_
Posted 26 June 2010 - 03:39 PM
Hi Guys,
I have the standard LX V8 throttle cable on the car for the Holley...as per the pic...it goes about 40mm past th base arm where the ball bolts into...any ideas how to hook this up?.is there a small arm extension or something?
#2 _rorym_
Posted 26 June 2010 - 03:48 PM
I think I need the throttle cable holder like this one on RRS L34.
Attached File  img0037shw2.jpeg   92K   28 downloads
#3 _SLR Goat_
_SLR Goat_
Posted 26 June 2010 - 04:50 PM
maybe modify that one or ive seen the chrome brackets at the shops that mount the cable from the back and bolt onto to the corner stud of the holley base
#4 its Paul
its Paul
    Formerly lx8vd77
  • 1,577 posts
  • Name:Paul
  • Car:LXSS, VUSS, VESSv & the mighty HB
Posted 26 June 2010 - 05:06 PM
This was how the linkage was on my old engine, you are quite welcome to the bracket if you think it will make a difference.
If you cant see the linkage clear enough, PM me your email addy and i'll send the photos to you and you could zoom in on them.
#5 _rorym_
Posted 26 June 2010 - 05:17 PM
Sorted...found another bracket..all good...just need the small ball thing and it is done.
Edited by rorym, 26 June 2010 - 05:19 PM.
#6 _Squarepants_
_Squarepants_
Posted 26 June 2010 - 08:38 PM
I have some of the ball mounts if you need one. PM me if you want one.
Edit: They are brand new. PM me for more info.
Edited by Squarepants, 26 June 2010 - 08:40 PM.
#7 _rorym_
Posted 26 June 2010 - 11:11 PM
I am good thanks Squarey...will grab one from AutoBarn in the morning.
#8 TerrA LX
Posted 27 June 2010 - 12:12 AM
The spring should be pulling in the opposite plane to the cable to prevent excess load and wear to the throttle shaft bush.
