Using front end spindles from US cars possible?
Posted 28 June 2010 - 10:00 PM
does anyone know if its possible to use front spindles from american cars from the 70s like the Camaro,Firebird,Mustang or other at the Torana LH control arms?
Uwe
Posted 29 June 2010 - 12:45 AM
1967-69 at least
But why would you ?
They had worse brakes than ours ... haha
Posted 29 June 2010 - 01:56 AM
Now to find out if this spindles higher or lower than the original Holden ones.
I did see aftermarket spindles in a lower version for us cars.
By now we are about to built own billet wheel hubs to use vented ford brake disc 300mm diameter front and 280 mm vented disc from a Renault for the rear .
Uwe
Posted 29 June 2010 - 06:58 AM
Posted 29 June 2010 - 07:18 AM
Posted 29 June 2010 - 08:58 AM
And stay away from wilwood
Your in Germany... AP or Brembo should be your first choices
Posted 30 June 2010 - 09:03 AM
Posted 30 June 2010 - 09:29 AM
Poor casting techniques , prone to flexing , no dust boots ,pads are hard to get here , 20mm thick pads squirm on the backing plates when hot ... etc etc
They have certainly improved... but... the guys in Germany... theres so much more he could do than slap on something very average and try to go racing
The amount of AP and Brembo stuff he could lay his hands on off say... old Porsches... would be staggering
Depending on his wheels... a set of Big Reds or even 928 S4 calipers would be an enormous improvement over any off the shelf Wilwood caliper
Lotus Brembos... they work well on Toranas too with suitable brackets and 300-330mm discs (depending on wheels)
I say adapt something to the spindles you already have
Changing the stubs will lead to suspension and steering issues that will have you chasing your tail for years trying to sort out
Posted 01 July 2010 - 03:11 AM
Dattoman can be right with the Wilwood quality, i know there is not much Wilwood here in Germany and i dont know how good Wilwood is in US Motorsports.
I had a 4 Piston rear caliper in my hands and i can say its realy light and you as a customer has to choose the options what should be inside of the caliper,if you choose aluminium pistons (for low and mid temperatures) they will die soon at races.
Wilwood has calipers with rubber seals for the pistons as i could see are available. Also stainless steel and titanium piston calipers for extreme temperatures.
I think it is like everywhere ,good money,good quality.
But as i said,i have no other Willwood informations from a driver here at my place.
I try to find out a light weight lower front hub solution for this 108mm bolt diameter.
Otherwise we go to a 120mm bolt diameter (BMW) to get more options with wheels later on.
We about to build a AP disc brake system in the German classic way, to use existing aftermarket discs.
I did see a Mustang II spindles wich looks like the Holden ones and this Mustang II spindle has maybe a lot aftermarket solutions.
Exploring is fun....
Uwe
_The Baron_
Posted 01 July 2010 - 05:30 PM
Being the talented man you are, you may be able to put a package together, it has all been done before with all sorts of calipers.
Maybe base it on a caliper Uwe has access to...Uwe may even put your name on the car as a sponsor.
That will confuse the German. Vats dis a Datsin.
Posted 01 July 2010 - 10:17 PM
Uwe
Posted 01 July 2010 - 10:27 PM
I'd start with making a billet hub ... use 6061 or 7076 grade alloy treated to T6 hardness (don't go making it off my picture then say it doesn't fit... check your own work)
Then buy a pair of CP5200 calipers from AP Racing
Then a pair of 330mm discs to suit... 28mm thick
Commodore discs are 83mm top to bottom measurement and pull the caliper back nicely from the wheel face just as an example
I'd do these 2 piece and have an alloy hat (using your own measurements
Then make a billet adaptor bracket to mount calipers also from 6061 or 7076
Should end up looking abit like this when front mounted onto a Torana (I think this has CRS 2" drop stubs)
Then check your wheels for clearance
Wunderbar .............
Should keep you busy for awhile
Anything else you need ????????
Posted 02 July 2010 - 04:50 PM
....keep me busy.
Thats this moments when i do belief the reason for a Forum.
Uwe
_Chamois hatch_
Posted 24 October 2010 - 02:02 PM
same ball joints. stubs are about an inch shorter than torana, steering arms are completely different...
I gave up after that.
to be honest after doing the maths the wilwood kit plus postage from the states......it wasnt worth it.
my 2 cents.
