Josh's Ute
707 replies to this topic
#351 _fullnoise_
_fullnoise_
Posted 23 August 2011 - 12:09 AM
hey josh well i have 1 one extractor brand new for the drivers side only you can have for $50 if the passengers side is ok its for a hq to wb 5ltr inj
located in maddington cheers shaun
#352 _gen3torrie_
_gen3torrie_
Posted 29 August 2011 - 12:28 AM
well, its going off to the electricians next monday to be finished the wiring :)
#353 _gen3torrie_
_gen3torrie_
Posted 03 September 2011 - 08:08 PM
so, i ordered the tailshaft an now i have it brand new 3 1/2 inch tailshaft with brand new uni's, so much more bigger than the std 2" shaft
anyway i have started to fit the shifter but it's very touchy sometimes it wont engage 2nd 4th or reverse it'll just pop back out, but yet when it was fitted last time it worked fine? does anyone have much idea about the getrag boxes?
and i have got the clutch fluid line? what is the most suitable oil for the gearbox and master cylinder?
cheers josh
also on the yoke end it has about half an inch showing is that normal? or is it meant to sit flush?
#354 _Liam_
_Liam_
Posted 03 September 2011 - 08:21 PM
Ask Al, he will know. Sounds like the linkages aren't fully engaging properly.
#355 _gen3torrie_
_gen3torrie_
Posted 04 September 2011 - 12:29 AM
only one linkage from the shifter.
also one of the unis fell off when i took the tape off and the little lead looking stuff some fell out does that mean i need the uni re-pressed back on? or will it be fine? it doesnt sit in place till i put the u bolt on
#356 ls2lxhatch
  • 5,332 posts
Posted 04 September 2011 - 02:39 AM
The two uni caps for the diff end are held in place by the diff yoke and u-bolts or caps. When the tailshaft is removed from the diff you tape the uni caps so they do not fall off.
The "lead things" are the needle roller bearings. Clean the needle roller bearings in solvent then put them back into the cap with some grease to hold them in place. If there are any gaps between the needle roller bearings then you have lost some and will need to buy a new uni.
It is normal to have 0.5" of the yoke out of the gearbox. When the diff is at full suspension travel the distance from the gearbox to the diff is greater than it is when the diff yoke is level with the gearbox. As it is a new tailshaft it would be worth removing the rear springs and checking the yoke travel throughout the suspension travel. When the diff yoke is level with the gearbox there should be some travel left at the yoke.
Edited by ls2lxhatch, 04 September 2011 - 02:41 AM.
#357 _Quagmire_
_Quagmire_
Posted 04 September 2011 - 11:37 AM
not sure on the getrags....i'll ask alex this arvo
or come round and ask him
bring beers :)
you can see the new ute :)
but there should be a adjustment available for the linkage cable/rod built in
you pushing the clutch in as well joishie?
try it when the clutch is hooked up
and i told you bout the uni's last nite :)
#358 _gen3torrie_
_gen3torrie_
Posted 04 September 2011 - 01:20 PM
yeah alright so whats the best solvent to clean them?
do uni's come in pairs or can i buy just one?
#359 dattoman
  • 16,487 posts
Posted 04 September 2011 - 01:30 PM
Petrol , kero , anything really
And you can buy a single uni... but its the whole joint
And you just need a cap with some needle rollers in it
Can you use a cap/bearings off the old tailshaft ?
#360 _gen3torrie_
_gen3torrie_
Posted 04 September 2011 - 06:14 PM
well i did try to put the needle bearings back into it, but im not a patient person, so i bought a new one got the whole kit for 29 bucks :) pulled one uni off and put my half done uni on the other new kit. and away i went :) so now i have 2 sets of new unis god damn it
#361 _jabba_
_jabba_
Posted 04 September 2011 - 09:23 PM
You just put the rollers in and roll your finger around with a bit of grease until it drops into place?
#362 _gen3torrie_
_gen3torrie_
Posted 07 September 2011 - 01:07 AM
Welli got the seats back today they r awesome carpet goes in next w
eekend
#363 _nial8r_
_nial8r_
Posted 07 September 2011 - 07:41 AM
you know the drill Josh, pic's or it didnt happen :stirpot: :P
#364 _gen3torrie_
_gen3torrie_
Posted 19 September 2011 - 10:17 PM
Well,
the cowel panel and door and quarter are being sprayed next weekend.
i need to fit the clutch line
fit the accelerator cable
fit the new extractors
fit the new radiator
fit the new water pump
fit the new carpet and retrimmed seats
fit the new wheels
re-paint the rocker covers and injection covers
fit them
fit the front quarter panels, nose cone and bonnet
get the final wiring done
new exhaust system
then i can drive the wheels of it :)
#365 orangeLJ
Posted 20 September 2011 - 07:47 AM
Pics?
#366 _nial8r_
_nial8r_
Posted 20 September 2011 - 08:51 AM
:iagree:
#367 lcgtr1970
lcgtr1970
  • 1,702 posts
  • Name:Jordan
Posted 20 September 2011 - 05:58 PM
sounds good mate. look forward to pics...
i thought you were initially gonna sell the ute? makes sense to keep it after all this work
#368 _TJ355_
_TJ355_
Posted 21 September 2011 - 07:00 PM
Pics please
#369 _gen3torrie_
_gen3torrie_
Posted 21 September 2011 - 09:01 PM
yeah lcgtr i am going to sell, when i stop enjoying it :) i put the hard yard in to make it a decent machine, not a dodgy bros engineered bucket lol
what is there to take photos of?
#370 _Bomber Watson_
Posted 21 September 2011 - 09:12 PM
YOUR NEW STUFF
#371 orangeLJ
Posted 21 September 2011 - 10:37 PM
Interior, paint prep, pedal box in, etc etc
#372 _TJ355_
_TJ355_
Posted 22 September 2011 - 01:13 AM
I think we all read wrong and that's his wish list?
#373 _gen3torrie_
_gen3torrie_
Posted 22 September 2011 - 09:27 PM
no its my to-do list,
seats are still at the trimmer's he's refitting them after fitting the new carpet
the pedal there's photos like 3 pages back
the rad is in my shed, but im getting a betterer one when its tuned and running properly
the water pump is in my shed
the extractors are coming
the new wheels i should pick up either this weekend or next weekend depending on when the back hurrys up and fixes my account after it was skimmed.
#374 _Quagmire_
_Quagmire_
Posted 22 September 2011 - 09:32 PM
i told you that russian whore was a con lady
and there was no such bank as "bnz" m8t :D
Edited by Quagmire, 22 September 2011 - 09:33 PM.
#375 _gen3torrie_
_gen3torrie_
Posted 22 September 2011 - 09:36 PM
hahaha lol
yeah thats were i must of got caught up lol they did take a good sum too, most of my pay they ran away with, wankers, definitely not using the ATM at the pub again.
