Josh's Ute
707 replies to this topic
#26 DanWA
DanWA
  • 2,440 posts
  • Car:LS1 LX 4 Door
Posted 27 July 2010 - 11:44 PM
had yella terra heads, manifold n carb
#27 rodomo
  • 18,063 posts
Posted 27 July 2010 - 11:56 PM
286 needs comp.
Edited by rodomo, 28 July 2010 - 12:09 AM.
#28 _TJ308_
_TJ308_
Posted 31 July 2010 - 06:42 PM
BTW i have a new Crane 284 here never used if ure interested cheaper then buying a new 1 also have lifters and u will need them
#29 _gen3torrie_
_gen3torrie_
Posted 02 August 2010 - 03:13 PM
how much you chasing for it TJ???? 284 would be perfect yeah i know i need new lifters and springs...
i was chasing a Tremec 5 speed but didn't have luck finding one... so i ended up getting a getrag290 out of a VS but the guy didnt wanna seperate the motor from the box so i got the ECU with 215i chip in it (got no idea how that would power up a 185i motor) and loom for $1500 so my VP 165i and T700 will be for sale soon...
Anyway got speaking to dattoman and found out the Getrag would need big tunnel mods... so thats what happened
picture time...
we started of with measurements dropped the motor in and tacked the mounts into place...
started off with the engine mounts as the previous owner welded in commodore V6 mounts instead of getting the CRS kit... dummy fitted it in marked out were we were gonna cut the tunnel and got the drill and tin snips out...
which gave us this hole...
motor came back out to have the mounts welded back into place...
then my mate welding the mounts in...
thats the tunnel done for now... the sheetmetal is off at a fabrication place being rolled so it'll look like brand new...
the motor and box went back in... ( i think in total space of 2 days we pulled the motor and box out about 10 friggin times)
then the x-memba we started off with a piece of 2mm metal blanked it off marked out were the bolts came through and surprisingly it was very close to the standard holes so we drilled it out and it fit perfectly first time...
that square hole next to it is to allow the nut that holds the plate on the back of the gearbox to come through
the big plate with 2 holes underneath was for the old T5 but we ended up keeping it there for extra support...
ohhh and i was trawling through the quokka and came across a cheap HJ premier front end with fluted guards... so that'll be on in the not so distant future...
i just need to find a suitable scoop as there is a hole in the bonnet i was thinking of getting a torana reverse facing and modifying it...
its currently painted in acrylic if i put a sealer on it then primer i can paint in my 2pac paint can't i???
all thats left now is to weld my new tunnel into place... bolt it up... do the wiring, and we should have take-off... then onto the TORANA :)
Edited by gen3torrie, 02 August 2010 - 03:19 PM.
#30 _gen3torrie_
_gen3torrie_
Posted 02 August 2010 - 03:18 PM
also while the engine was out we neatened up the bay a little bit
by painting the inner guards...
painting up the firewall..
half way done
finished
then we painted majority of the interior parts dash, rooflining, crash pad, visors as they had been done before but very poorly...
all thats needed for the twin headlight front is the loom, i hear rares does them for around $60 but i havent really looked into it as of yet??? as the single light front is going back on till the torry goes away for another little trip to the brake place...
thats really it for now...
#31 _Quagmire_
_Quagmire_
Posted 02 August 2010 - 03:21 PM
redex and paint your floor while the interiors out and i hope you retoquered those main caps up before you put your sump back on!!!
#32 _gen3torrie_
_gen3torrie_
Posted 02 August 2010 - 03:34 PM
yes mum i retorqued those bolts with my new torque wrench :)
#33 _Quagmire_
_Quagmire_
Posted 02 August 2010 - 03:40 PM
righto then
not that i really care Posted Image
#34 MRLXSS
  • 12,420 posts
Posted 02 August 2010 - 03:42 PM
Progress is a gen3torrie thread??? Jesus! What next? Heath will finally realise that banjo's are shit? LOL
#35 Heath
  • 18,403 posts
Posted 02 August 2010 - 04:26 PM
Good stuff Josh!
#36 _LH SLR 3300_
_LH SLR 3300_
Posted 02 August 2010 - 05:43 PM
Looks like you're making some good progress there, well done. Are you running the engine, harness, ECU & gearbox out of a VS now or just the Getrag & VS harness/ECU? I'm asking as there are some differences between the VP-VS you need to be aware of. Firstly, VR on have an anti-theft program in their ECUs that will have to be removed so you can run them in older cars like your's. Someone like Chip Torque can do this for you. Also, from memory the only VS 5.0ltr to run the Getrag box from factory was the VS series III & i think these had sequential injection like the VT series I 5.0ltrs. I don't think this will pose any problems for you if you got the sequential distributor & air flow meter these engines run & use the complete VS EFI hardware. As long as you don't go swapping bits over from your VP hardware i think you'll be OK.
#37 Neils LX
Neils LX
  • 2,074 posts
  • Name:a
Posted 02 August 2010 - 06:06 PM
Good to see your getting some work done
#38 _gen3torrie_
_gen3torrie_
Posted 02 August 2010 - 11:03 PM
i have the BCM out of the VS that the engine came out off... my mechanic is going to try and loopwire the BCM and anti theft out of it... so basically send a signal it'll come back ok and we will have ignition
we didnt have any luck today... just sorting out what wire was what...
i'm just chasing after a clutch booster as getrag's are hydraulic and cant be changed to cable... we will probably modify the pedal to suit the booster hopefully we can find room on the firewall for it to fit...
im unsure on what place to take my tailshaft too
either Final Drive, Veem, or DSA
#39 _LH SLR 3300_
_LH SLR 3300_
Posted 03 August 2010 - 04:26 PM
Sounds like you've got it sussed. In my last post i forgot to mention that VR on ECUs are BCM linked but you already know that so it seems you're well on your way to getting it up & running. I'm interested to see how you go with wiring the sequential injection into your car so i'll be watching this thread.
#40 gtrboyy
gtrboyy
  • 3,241 posts
Posted 03 August 2010 - 05:04 PM
Same as what I put back in the lc,I had to get slave cylinder resleeved to get it correct to suit the dellows clutch cylinder,got specs out of vt manual then dropped it off at brake shop for them to work it out.
Ecu wires in basically the same as the earlier wiring harness' + 1 power wire/5a or 10a fuse i think added for the maf,with a relay it kept blowing fuses so we took out the relay & it was fine.
For the getrag,it will also needs bracket in the tunnel for the shifter,hope you got the slip yoke for the g/box or it won't have a speedo,can also stall the engine sometimes coming to a stop
Get a cheap v6 memcal,look up nicefrog or greenfrog(forgot which one it is) on ebay,for $80 he'll do you a nice tune & remove the VATS to make it easier to wire up.
#41 _lxefi304_
_lxefi304_
Posted 03 August 2010 - 07:39 PM
you could just use the vp ecu,loom,dizzy ect. then u no longer have the immobiliser and air flow meter.
you should be able to use a auto ecu and loom with the getrag without any problems. thats how i would do it i had a vr comp and bcm set up in my torana it was a pain compared to a vn/p setup
#42 Neils LX
Neils LX
  • 2,074 posts
  • Name:a
Posted 03 August 2010 - 09:59 PM
Using VN-VP computer makes work a hell of alot easyer.
#43 _gen3torrie_
_gen3torrie_
Posted 03 August 2010 - 11:21 PM
hmmm maybe i should use the vps loom and i have all stuff by slip yoke u mean the big cog on the actual ailshaft which i got off the vs which rns the speedo?
#44 _lxefi304_
_lxefi304_
Posted 03 August 2010 - 11:35 PM
slip yoke is the yoke on the end of the tailshaft that slides into the back of the gearbox.
i dont know if getrags use a yoke on a vs but on a vx v6 getrag they use a rubber joint that uses 3 bolts onto the tail shaft instead of a uni joint.
if the getrag uses a rubber joint(i think it dose) it that could be a issue as that rubber join will only work with a 2 piece tailshaft. so hopefully you can get a normal style yoke to fit into the back of a getrag
Edited by lxefi304, 03 August 2010 - 11:42 PM.
#45 _Quagmire_
_Quagmire_
Posted 04 August 2010 - 12:30 AM
yep josh that will work but you will get fuelling up /hunting at idle from what i got told
and you still have to wire your reverse lights in somehow
and i'm sure veem etc can do you a two piece tailshaft if you pay them enough
#46 gtrboyy
gtrboyy
  • 3,241 posts
Posted 04 August 2010 - 02:55 AM
Yep,slip yoke has the toothed gear on it for v8 getrags different to v6s,without it there is no speedo,throws up an intermittent fault & ya can sometimes stall the engine.
You can swap stuff over from earler vn to vs but not to vs s3 & vt's.
Use all the vs s3 ecu,wiring & getrag complete otherwise you'll get a few headaches mix n matching parts.VS S111 & Vt 5litres use a slightly different manifold & dissy to earlier models so those would have to be swapped over to run earlier ecu etc ,will still have the issue of no speedo.
reverse lights is easy,reverse switch is near slave cylinder.
Edited by gtrboyy, 04 August 2010 - 02:56 AM.
#47 _eh-buddy_
_eh-buddy_
Posted 04 August 2010 - 10:27 AM
looking good but why would it need a 2 piece tailshaft?
i had a vs manual ute with a 1 piece shaft (done before i got it) and using a 9 inch
never realy had a problem (the car was a pretty wild thing though)
Edited by eh-buddy, 04 August 2010 - 10:34 AM.
#48 _lxefi304_
_lxefi304_
Posted 04 August 2010 - 12:52 PM
ohh i didnt realise that getrags dont have a normal style speedo drive. so yea use the vs ecu etc
#49 _Quagmire_
_Quagmire_
Posted 04 August 2010 - 01:56 PM
only cause i'm kicking him up the bum Posted Image
#50 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 04 August 2010 - 04:11 PM
St Quagmire.
