Whats the best CAM for the street you've had, 186-202
Posted 14 July 2010 - 08:23 PM
Cheers Blake
Posted 14 July 2010 - 08:43 PM
the 150A and 392C are both magic camshafts, nice lump, good power but the 150A isnt that much of a pig.
Posted 14 July 2010 - 09:01 PM
Blake
_Bad Blood_
Posted 14 July 2010 - 10:04 PM
_gmlj6_
Posted 14 July 2010 - 10:24 PM
_Brad1979UC_
Posted 15 July 2010 - 12:08 AM
INT 224 [email protected]" 0.4545" Valve lift
EX 232 [email protected]" 0.474" Valve lift
sounds like this....
really most red 6's with a big cam sound horn
_Eedman_
Posted 15 July 2010 - 01:22 AM
i bought one of these for my 202.
http://cgi.ebay.com....#ht_1126wt_1137
went for a stage 2 and also got straight cut gears too.
Posted 15 July 2010 - 06:48 PM
cheers Blake
_wjr2980_
Posted 15 July 2010 - 08:49 PM
Lobe sep 107
@ 0.050 Duration Int 246 Exh 254
Valve lift Int 506 Exh 497
Very lumpy!!!
I have to run a 3800 stall. Revs to 7000rpm all day.
_Squarepants_
Posted 15 July 2010 - 09:52 PM
It's ok, idles well with a bit of a lump in it, performance is notably better than stock, you can tell when it "comes on cam" and drivability is fine with a 5 speed box.
In all honesty, I'd prefer a bigger one. I reckon a 40/80 would be a good thing, if not slightly bigger again.
Just make sure your bottom end will handle at least 7000rpm.
_why-psi_
Posted 16 July 2010 - 04:04 AM
was a bit of a pig to drive
_clubspClubsportr8ortr8_
Posted 16 July 2010 - 11:08 AM
Stage 5 Heatseeker
biggest hydraulic one they made for holden 6. solid went to stage 6
Incorrect as Heatseeker do the HS60 hydraulic still and it is a stage 6 plus Peter still grinds custom cams to suit what ever info you give him.
_tim_lxhatch_
Posted 18 July 2010 - 08:22 PM
Posted 18 July 2010 - 08:46 PM
can someone tell me how the crow cams go as well. pm me if needed?
i'd stay away for a performance application. ive seen them drop lobes and lifters not rotating
_hydengineering_
Posted 22 July 2010 - 05:33 PM
Posted 22 July 2010 - 07:26 PM
Thinking they are somewhere on the NSW north coast now.
There old 30/70 cam was the ducks guts for daily drivers.
Reckon they forgotten more about red 6s than most these days know.
_iwanacoupe_
Posted 22 July 2010 - 07:33 PM
Posted 22 July 2010 - 09:00 PM
Posted 22 July 2010 - 09:08 PM
Posted 22 July 2010 - 09:35 PM
sorry to jack the thread but while where on the subject anyone no the best cam for 186/stroker 221 crank, As far as i kno there not good for high revs so anything revn over 6 is no good. Place i spoke to about puttin motor back together recommended crow xu1 cam but ive heard a few bad things about them plus wots the point of having a cam in there thats needs to rev more than me motor can handle??
more cubes will put the rev range lower on the stroker than it would on a 202 or 186.
so the rpm range will be lower than all the listings for cams that are for a 202.
Edited by greens nice, 22 July 2010 - 09:37 PM.
#21
Posted 23 July 2010 - 08:04 AM
#22
_iwanacoupe_
Posted 23 July 2010 - 11:03 PM
My experience with Strokers is limited But I do know a bit about the 235 version. It is true they don�t like big revs. 5800 would the limit. But what they lack in high rpm HP they make up with in the way of torque. Crow aren�t that bad. A bad batch of cores can haunt any cam manufacturer. I would pick a cam with 6000rpm limit in mind. You also want a fairly wide lobe separation. This spreads the power band wide to make use of the torque offered by the extra cubes. I�d use a crow 35667 cam. We have installed this cam in a 186 daily driver with one of our new SIM002 EFI Intakes. It idles well and makes power between 2500-6000. The 100 lobe separation and the high lift both help improve the cylinder filling. Cylinder filling in emphasised with the extra cubes you have. A 72 XU1 cam only has a rev range of 2500-5800, but because it relies on duration rather than lift to fill the cylinders I feel the 35667 will offer better performance in your application. I hope this info helps
this is info i got from a fella who makes main stud girdles, anyone no of a really really good holden 6 engine builder in adelaide?
#23
_2ELCS_
Posted 23 July 2010 - 11:23 PM
Wayne
#24
_iwanacoupe_
Posted 23 July 2010 - 11:30 PM
#25
_2ELCS_
Posted 23 July 2010 - 11:45 PM
