lx - lh front end any difference ?
Posted 19 July 2010 - 09:15 PM
Posted 19 July 2010 - 09:32 PM
Posted 19 July 2010 - 09:40 PM
Posted 19 July 2010 - 09:50 PM
Posted 20 July 2010 - 09:08 AM
Posted 20 July 2010 - 09:17 AM
Pretty much the only common thing shared between all 8 or so different models are the rubbers, ball joints and tie rods.
Posted 20 July 2010 - 12:26 PM
... & the welding spatter.
Posted 20 July 2010 - 12:37 PM
And the GMH black.
Posted 20 July 2010 - 12:59 PM
Posted 20 July 2010 - 01:16 PM
Posted 20 July 2010 - 01:21 PM
Probably better off switching now and rebuilding the LX front end and drop it in when your ready.
Posted 20 July 2010 - 01:52 PM
I have summarised the differences between LH, LX, UC and A9X on this page. The information is from this forum spread over dozens of threads.
Posted 20 July 2010 - 02:03 PM
#14 _OLJ_08_
Posted 20 July 2010 - 08:57 PM
If you are planning on rebuilding the front end then there is little difference between the LH and LX. The main difference is the position of the UCA mount bolts and the thickness of the steel used for the UCA and LCA.
hey,was just reading thru the infomation,i have a rack that is in a uc which is 994077 and means its 25;1 but the info says the uc is 9942632 and 9942633..is my rack still out of a uc or different model.thanks
Posted 20 July 2010 - 09:05 PM
Not much info to go on regarding whether its the same or not since we don't know what you have
Posted 21 July 2010 - 11:07 AM
The UC rack is 9940277. There is contradictory information as to what the ratio of the racks are. I was originally given a ratio of 25:1 for the UC rack however this does not appear to be correct. My UC rack is around 3.5 turns lock to lock which calculates out to around 20.4:1. I have updated the page to make it clear which rack is which.
I am still not sure what the LX or A9X rack ratios are. If someone can measure the travel on an LX and A9X rack for one turn then we should be able to calculate the ratios.
Posted 21 July 2010 - 12:33 PM
#18 _LH SLR 3300_
Posted 19 August 2010 - 06:07 PM
Posted 19 August 2010 - 06:30 PM
I have a 1974 LH & a 1977 LX i wish to swap the steering racks over. I know they have different steering arms between each model but will this affect the swap in any way?
What makes you think they are different?
AFIK they used the same arms, only L34, A9X and UC used different arms.
Posted 19 August 2010 - 06:40 PM
UC steering arm Left 9947249(GM7249) Right 9947248(GM7248)
LX steering arm Left 9928329(GM8329) Right 9928328(GM8328)
LH steering arm Left 9928327 Right 9928326
L34 steering arm Left 9935249 Right 9925250
#21 _LH SLR 3300_
Posted 19 August 2010 - 07:38 PM
To be honest, i thought only LX with RTS & UC were different, i assumed LH & pre-RTS LX were identical. I read ls2lxhatch's link page & as he's stated from his research, they have different part numbers so i figured there might be a difference/variation between LH & LX other than the ratio. I also know the racks are usually date coded. I'm only bothered to know as i'm selling my LX cheap to suit wreck or restore but it has a recently recoed rack that i'd like to fit to my LH if possible as it would save me the expense of reconditioning it's original rack.
#22
Posted 19 August 2010 - 07:56 PM
#24
Posted 19 August 2010 - 09:27 PM
I have also read that you can not purchase replacement bushes for the LH rack. They are available for the LX/UC racks.
See this thread.
We have gone from talking mounting bushes to the internal rack shaft bush....
LH/LX use rubber rack mounts, UC use a solid bush mount.
Edited by TerrA LX, 19 August 2010 - 09:29 PM.
#25
Posted 19 August 2010 - 09:50 PM
Edited by ls2lxhatch, 19 August 2010 - 09:51 PM.
