Heater Hoses for LX V8 - Post ADR 27
53 replies to this topic
#26 _Yella SLuR_
_Yella SLuR_
Posted 21 August 2010 - 11:51 AM
I can see why they've done it that way now. That heater hose stopped being produced by Rares in 2000!!!
Mick, have you done a 9928623 pre-pollution hose? I think you can actually guide it across the top of the manifold without the special bends, and still hook it up to the right places, which is probably why they stopped making them.
If all else fails, I will configure mine as per the pictured L34, which is semi-close sort of.
#27 _sstorana_
_sstorana_
Posted 22 August 2010 - 09:53 PM
Hi Pat
No I haven't done the hoses for the pre pollution set up yet. Once I get the pollution ones done, I will look at getting these ones done as well..
Mick
#28 _Yella SLuR_
_Yella SLuR_
Posted 22 August 2010 - 10:07 PM
Okies, thanks for that Mick. I'm going to bypass the pre-heat for the time being, but would love one when they are available. Note there is also a little zig-zag hose from the thermostat housing to the inlet manifold housing. This one isn't listed in the parts manual, or not that I could find in mine anyways. You may have it in yours, as I do not the diagram below in my manual either.
#29 _sstorana_
_sstorana_
Posted 02 September 2010 - 08:40 PM
Hi all
some updated pics of the hoses. these are as close as you could get them to the original bends, etc.
I should have thesein late Oct/ early Nov..
Mick
#30 TerrA LX
Posted 02 September 2010 - 08:51 PM
Fantastic.
#31 _1ARC_
_1ARC_
Posted 03 September 2010 - 03:07 PM
Fantastic.
Hi Mick, Are you taking orders?
John
#32 _sstorana_
_sstorana_
Posted 03 September 2010 - 07:23 PM
Fantastic.
John
Hi John
I won't be taking orders until I get them into the country and work out the final prices. Rest assured, I am getting alot of sets in!
Mick
#33 AbsynthHatch
AbsynthHatch
  • 736 posts
  • Name:Mark
Posted 03 September 2010 - 07:54 PM
Would you be looking at getting the short one, seeing as its still available and look at maybe selling them as a set of 3
Edited by AbsynthHatch, 03 September 2010 - 07:54 PM.
#34 _sstorana_
_sstorana_
Posted 03 September 2010 - 08:49 PM
Hi Absinth
The small bypass ones have already been done by us..
yes, I will be doing the small one and yes, I will be doing these as a set of three.
Mick
Edited by sstorana, 03 September 2010 - 08:50 PM.
#35 AbsynthHatch
AbsynthHatch
  • 736 posts
  • Name:Mark
Posted 03 September 2010 - 10:36 PM
Do you have a list with photo's of all the products that you now make Mick, rather then going through ebay.
#36 _sstorana_
_sstorana_
Posted 03 September 2010 - 11:00 PM
Hi Absinth
After Toranafest, I will have a complete list on here...
as well as a list of upcoming items..
Mick
#37 _The Baron_
_The Baron_
Posted 03 September 2010 - 11:20 PM
Great news,
I need to get a few things from you, so I will add these to the list when the hoses become available and will be in touch then.
#38 _sstorana_
_sstorana_
Posted 03 September 2010 - 11:34 PM
no prob Tony
Mick
#39 AbsynthHatch
AbsynthHatch
  • 736 posts
  • Name:Mark
Posted 07 September 2010 - 04:41 PM
Yeh same here, will do one big order, to save on postage.
#40 _sstorana_
_sstorana_
Posted 03 October 2010 - 08:36 PM
Hi All
I hope to have the final samples for the hoses and the Hatchback rear quarter window Seals this week. Once I do, I will post pictures..
I have a number of new parts coming, that include;
27A Heater Hoses,
Rear Quarter Windpw Seals,
Hatchback Rear quarter Window Dome Nut and Screws,
Park Brake Release Kobs (Vers 1)
RTS Badge for LX,
RTS Badge for US/ HX/ VB,
Black Pinchweld,
Rocker Cover Hose Clips,
Late LX/ A9X/ UC Brake Line Grommets,
SS and Holden Grille Emblem Brackets,
Heater Knob and Screw, and
Hatchback Radio Brackets..
AM Radio/ MP3/ Ipod Adapters
Mick
#41 _sstorana_
_sstorana_
Posted 07 November 2010 - 05:53 PM
Hi All
updates on the heater hoses can be seen here;
http://www.gmh-toran...0&gopid=550165
Mick
#42 _sstorana_
_sstorana_
Posted 28 February 2011 - 11:46 AM
Hi All
These heater Hoses are now available and you can find out more information here;
http://www.gmh-toran...es/page__st__25
Hey Mick (REDA9X),
Thanks for supplying a set for the cause! If you would like a couple of sets, PM your details and I will send them to you..
Mick
#43 Shiney005
  • 9,524 posts
  • Car:Toyota Mirai
Posted 26 May 2017 - 02:08 PM
^ Just having a look, the L34 picture is not correct, unless there is a difference in the heater hoses between the SL/R 5000 and the L34. You can see the heated manifold outlet blocked off. I am configuring mine as per the manual.
Digging up the past I know, but the L34s had the water heating of the inlet manifold deleted. The picture above is correct. I am also going to steal it for a thread on water pumps. :)
#44 hanra
  • 10,936 posts
Posted 26 May 2017 - 02:33 PM
Did the SL/R 5000 L34 use the same inlet manifold as a SL/R 5000?
#45 hanra
  • 10,936 posts
Posted 26 May 2017 - 02:47 PM
Im lucky enough to of had 1 original hose to suit my Pre 27a setup. Its still in good nick. The other 2 hoses, I just went to SCA and bought a shit load of hoses and just played around until I could get something to fit, bit of a chop here and there etc, I then returned all the other hoses for refund!!!!
It would be good to get the right hoses for pre 27a also!
#46 Shiney005
  • 9,524 posts
  • Car:Toyota Mirai
Posted 26 May 2017 - 02:49 PM
Very similar. No part number for it. The two water inlets on the manifold were blanked off with grommets, and the inlet hose to the cabin heater would have had its own part number as it was a totally different shape to anything else from Holden. Patience Brad. All will be revealed soon. (I'm tying in heater hoses with the water pump thread)
#47 hanra
  • 10,936 posts
Posted 29 March 2022 - 08:05 PM
Still no pre 27a heater hoses about that I could see?
#48 308 Sunbird
308 Sunbird
  • 973 posts
  • Name:Stuart
Posted 30 March 2022 - 07:07 AM
Yep maybe one day we will get them Brad.
#49 hanra
  • 10,936 posts
Posted 30 March 2022 - 08:20 AM
Im sure there would be a market for them. I guess the hard thing is finding a suitable sample to copy. My drivers side hose is original but my passenger side hose is a cut down version of a hose I found at SCA that provided pretty much the correct bends and turns. I think Mackay Rubber list the smaller one from thermostat to manifold anyways.
#50 Shiney005
  • 9,524 posts
  • Car:Toyota Mirai
Posted 30 March 2022 - 10:34 AM
To answer your question from five years ago Brad, with the L34, both water inlets to the inlet manifold were blanked off. One heater hose went from the thermostat housing, around the drivers side of the carby, then under the coil and into the heater box. This hose I think would be unique in the Holden world. Maybe Bedford had the same?
The other hose went from the water pump, under the top radiator hose, under the coil and into the heater box. There were no hoses on the passenger side.
Attached File  New L34 motor.JPG   367.14K   8 downloads
