PROJECT PAPAYA - A VERY FRUITY RESTO THREAD
#226
_nial8r_
Posted 01 April 2012 - 07:11 PM
#227
Posted 08 April 2012 - 12:55 PM
I started by working on the previously hidden "band-aid" repair.
A nice incision all the way around the wound, and it is removed.
Then I took the removed section and overlaid it on a mint section of another guard, marking it out and taking my replacement piece.
More on that repair section later.....
Next was the underside of the exact same rust repair. This one had no band-aid, and was still an open wound.
So using the same section of mint guard, I took a repair piece the same size.
The beauty of using this, is that it is the exact same profile as original, not a fabricated piece that will look different. You can see what I mean here... and why exactly does the inner part of the guard need that shape anyway?
Working from the top side, I welded that one into place, and lightly dressed the weld. Over the top I will weld the outer skin piece, and after a light grind and file, it should be back to new, both sides, with no dirty band-aid slapped over the top.
And finally,..... after spending a day sucking in welding fumes and grinding dust, nothing beats a cold beer! Sadly for me on this day.... My beer died a lonely death in the freezer :(
I must remember to NOT get distracted after a long day in the man cave!
Edited by notna, 08 April 2012 - 12:57 PM.
#228
Posted 22 April 2012 - 04:17 PM
Cleaned up the inside of both guards, did a little seam sealing, and gave them a good hit of stoneguard, because we all love that stuff right!!
Then gave the outside a nice lick of epoxy primer. I tried very hard to file finish these, after removing a fair wack of bog and tapping out the little dents. The wheel arch of one was previously partly formed with bog, but I managed to reshape it with hammer and dolly. I was really pleased with the way it all turned out, but it did still need a very small skim of filler.
I'll guide coat these and block them back next weekend, then prime them.
#229
_nial8r_
Posted 22 April 2012 - 05:13 PM
oh and how could you do that to an beer
#230
Posted 22 April 2012 - 05:35 PM
#231
Posted 22 April 2012 - 10:59 PM
In the end, I used 1 original guard and 1 ebay replacement, plus bits from 2 MINT UC guards (why don't they rust huh?) and a third LX guard. I file finished the bare metal and repaired guards as best I could. LOTS of hours in these, but i'm really happy with them and will put them on my SL/R with pride!
Lee.... ur a dreamer!
Nick, cheers mate!
#232
_nial8r_
Posted 23 April 2012 - 03:28 PM
#233
Posted 24 April 2012 - 10:50 PM
If you get sick of doing panel beating work the guy I have used is a genious and reasonably priced too (and around the corner).
Phillip
#234
_A9XOSS_
Posted 25 April 2012 - 10:21 AM
#235
_likatiger_
Posted 25 April 2012 - 10:35 AM
Edited by likatiger, 25 April 2012 - 10:35 AM.
#237
_likatiger_
Posted 25 April 2012 - 04:10 PM
#238
Posted 25 April 2012 - 07:10 PM
Cheers for the comments guys. Today I guide coated and blocked back the hi-fill primer. I love it when you start blocking back, and all the high and low spots become visible, and then gone (if you have enough hi-fill). It's satisfying knowing that the panel is that straight!
Here is hi-filled and guide coated panel, enjoying some sunshine....
Here is what you see when you begin to block it back. The high and low spots are well defined.
And when it is (nearly) finished, you can see how damn flat and straight it is.
I was explaining to a neighbor today that 99% of people will judge your car by how shinny and straight it is. So investing the time (and money) into panel work is WELL worth it.
On the weekend I will prime these again and then put them away, waiting for final colour, when I do the whole car at once.
#239
Posted 25 April 2012 - 07:14 PM
Posted 25 April 2012 - 07:34 PM
#241
Posted 25 April 2012 - 08:12 PM
#242
Posted 27 April 2012 - 01:35 PM
#243
_nial8r_
Posted 27 April 2012 - 02:35 PM
thanks hanra, will head down to the opposition and get me some
Hey Jason you should be able to get the panel stands through your joint.
gone are the days of hanging parts of the olds cloths line
#244
Posted 27 April 2012 - 02:56 PM
Oh and I'm still getting my jollies from this, while not getting them from the Juicy Papaya Fruit....
Stop bragging (as we're getting jealous) and get back to work on the Torana.
Edited by lxsstorana, 27 April 2012 - 02:57 PM.
#245
_pborg8_
Posted 27 April 2012 - 10:14 PM
i wll post Pics of my project as I get more firmiliar with the forum. thanks for the Insperation . Paul
#246
Posted 28 April 2012 - 05:05 PM
In regard to sand or soda.... I know what I prefer, but it really comes down to your budget, your expectations and ability. Sand will rip into paint, bog and rust, which will make it easier for you in the long run, but it can also blast holes where you never expected them to be. Soda is much more gentle on panels, but leaves you with a little more work in removing bog and rust.
I honestly believe that anything is repairable. Not much scares me in regard to work and repairs. I enjoy the challenges!
Now that you have introduced yourself I will be sure to follow your progress on this forum!
EDIT: Driver side engine bay plate came from an eBay seller. It was $80. I never saw any, ever, then there were heaps on eBay about a year ago, now I don't see any again! Just keep an eye out on there and one will hopefully pop up.
Edited by notna, 28 April 2012 - 05:07 PM.
#247
Posted 28 April 2012 - 05:43 PM
I just use a cork block..... been using just that for the last 10 years. Happy to be recommended something good though!
I used to be a cork man, loved my favorite cork block (got a few, but one i used mostly and had nicely worn corners etc) like a child, then i randomly pickeed up a selection of other types from the paint shop, now im a block whore and have like 10 different blocks for all different jobs.
I have "The Standard One" "The Flexi one" and "Chroma Block" from these guys
http://www.amaxi.com...ks/starters-kit
And a couple of these:
http://dura-block.co...ablockline.html
And some randoms....Rarely leave a trade show without having my name on a new block or two.....
Have my eyes on a few more atm......There addictive.....
Edited by Bomber Watson, 28 April 2012 - 05:48 PM.
#248
Posted 29 April 2012 - 03:19 PM
More progress today. I finally have these guards at a stage where I can put them back to rest and move on to another panel. I'm thinking the front apron next, but that's down the track. First, the finishing of the guards.....
After the first block back, the high and low spots became much more apparent. There weren't that many though mond you, but the few that were visible, WERE VISIBLE!
So I had to skim fill these and then smooth over.
Then I blocked both guards back again...
And was VERY happy with how they came out. I could tell from studying the surface hard, that these were as good as I could ever get them. Sooooo...... they got the primer treatment. 2K Hi-Fill. Very niiiiice.
And now I can put them away in this state, ready for colour later on, and move onto the next mini project. That will be coming soon.....
#249
Posted 29 April 2012 - 03:33 PM
Many of them are made from various density foams, so some are quiet stiff, some are nice and flexy, chromablock is very very flexy, good for a final rub down with 800 before paint.
Posted 30 April 2012 - 07:29 PM
I can see the benefit of of some flex, especially with the sometimes complex shape of some panels!
