PROJECT PAPAYA - A VERY FRUITY RESTO THREAD
#276
Posted 18 June 2012 - 11:34 PM
#277
Posted 19 June 2012 - 08:52 AM
#278
Posted 19 June 2012 - 10:15 AM
#279
Posted 19 June 2012 - 02:59 PM
It almost looks like The SLR models didn't get it but perhaps the SL range did?
^ This SL/R clearly has it but not the trim piece. I wonder if there was any sequence, dates, etc. as to which SL/R's were blacked out and which weren't, I can't imagine it being totally sporadic.
s
#280
_Broady247_
Posted 19 June 2012 - 04:06 PM
Due to boredom on paternity leave I thought I might just go down stairs and measure the smile for you. Mine is a late 74 SL and has the little turrets attatched. I will be removing them as i don't really like the smile (which is in good nick if needed). There are six turrets in total spaced as follows and all measured from the number plate mount.
FRHs measured from center.
and again.
FLHS measured from center.
and again.
and height = 9mm measured square off the radiator support area before it turns down towards the turrets.
The height is common to all the turrets. Were as the distance between and actual horizontal placement varies, as can be seen.
#281
Posted 19 June 2012 - 04:25 PM
If my resto needs a smile, I'll buy yours Andrew!
I always think of the smile as being the stainless trim piece, but yes, clearly the SL/R did have a black smile only. Maybe we can call that one a toothless smile?
#282
Posted 19 June 2012 - 04:40 PM
#283
Posted 24 June 2012 - 04:55 PM
I have noticed that on the inside face of front aprons, they seem to develop surface rust. Probably because from the factory, there wasn't much in the way of paint protection applied behind there. I chose to brush on 2 coats of rust preventative satin black. That, plus any primer and colour overspray, should keep the rust at bay.
Once that had dried, I gave it 2 coats of 2K Hi-Fill primer. I loooove this stuff... makes a well prepped panel look so smooth and inviting for colour!
One thing I find interesting is the amount of overspray that can be swept up off the floor. This floor was clean, and that pile of dust is from 2 coats applied to one panel. Scary! I'm starting to think that spraying at home with kids around isn't such a good idea....
At this stage of the resto, I'm starting to ask myself some questions.
Should I forget the notion of painting all panels in colour, separately, or should I prime everything, paint the door jams and inside of panels in colour, then assemble the car and paint in colour?
I was going to paint it in 2K colour, but now I'm thinking acrylic + clear. I already have 4L of PPG acrylic clear, and I have done some really amazing, multiple trophy winning, paint jobs in acrylic in the past. It's kinda what I know best.... bloody hard work though to buff it!
Only done one car in 2K colour. Came out good, but I'm no pro and yes, I did get a run in it, and it was a BITCH to fix up!
Thoughts and opinions...?
Edited by notna, 24 June 2012 - 04:58 PM.
#284
_LH SLR 3300_
Posted 24 June 2012 - 05:52 PM
#285
_Broady247_
Posted 24 June 2012 - 06:20 PM
When ever want to use 2k she makes me go to the factory suit up mask up and get in the booth. She would never allow it anywhere near the house. Acrylic I can paint at home and she has no problem but there is a lot of post spray work. Plus far more coats are required due to sanding and buffing
So in short, I have access to booths and professional painters for tips and help so I prefer 2k. If I didn't, I probably would use acrylic and be good, real good at sanding.
#286
Yea I have done the concourse, show car, rarely driven thing before.... and they were acrylic. This resto is NOT for show... I want to drive this one and I love how tough 2K is.
That being said.... I want to paint it myself.
I liked "Dirtbag's" concept of spraying 2K on the backside of panels and acrylic on the outside. I'm starting to lean towards that idea for my own resto.
I agree Andrew.... sanding and buffing acrylic is an absolute BITCH!
Is that 2K overspray that I swept up on the floor dangerous to breathe in, even when it's dry like that?
Edited by notna, 24 June 2012 - 06:23 PM.
#287
_Broady247_
Posted 24 June 2012 - 06:32 PM
Oh and the smile might make a appearance (very shortly) on a certain black SLR in cairns.
#288
Posted 24 June 2012 - 08:07 PM
#289
_Broady247_
#290
_LH SLR 3300_
Posted 24 June 2012 - 08:29 PM
#291
_AD_75_
Posted 24 June 2012 - 08:36 PM
#292
Posted 24 June 2012 - 10:09 PM
#293
Posted 25 June 2012 - 07:41 AM
#294
Posted 25 June 2012 - 01:24 PM
Glenn
#295
Posted 25 June 2012 - 02:43 PM
Also, was reading up the other day on on 2K hardener and noted that fast hardener makes your paint cure with less gloss. Is that right? Would explain the last 2K home job I did then....
#296
_AD_75_
Posted 25 June 2012 - 03:23 PM
#297
_nial8r_
Posted 25 June 2012 - 07:59 PM
Or you can always just take it on and duct tape a huggies to ya face
#298
_LH SLR 3300_
Posted 25 June 2012 - 08:01 PM
#299
Posted 25 June 2012 - 08:55 PM
Bought a Sundstrom mask and spare filters today. Same as what I had used in the past. I still like the idea of 2K colour.... it is tough and can handle a bit of abuse.
#300
Posted 26 June 2012 - 03:03 PM
