I like that a LOT! Can't wait to get it rolling on those.
Hope its not just sitting on the Beer.
Posted 08 October 2013 - 04:11 PM
Posted 08 October 2013 - 06:03 PM
Oh it was... but it's all good, the beer has now been consumed
Posted 08 October 2013 - 10:32 PM
Working on some other smaller things too.
Had another box of bits and pieces plated. LOVE how these come out. I spend a lot of time cleaning up all these things, and the quality of the plating really is good after the extra effort that goes into them.
At the moment I am working on the diff. Stripped it bare and started to clean up the housing...
So far, so good. But unfortunately there are some simple things I need to fix, like the stripped threads for the bottom 2 long bolts...
Oh and the stripped threads on the housing studs
Does anyone know where I can buy new ones of these?
And finally, since I am reconditioning it, I want to replace the axle bearings. How do you get the bearing cups out of the housing?
Hey Mate , As a fitter by trade. Best thing to do, is run a bead of weld directly on that center of the bearings outer race, causing it to shrink. Then you can just hook it out..Do it all the time at work with crusher gearboxes.. Unless you got Skyes and Pickevant puller set.The correct way if you can be bothered.
Edited by Caustic, 08 October 2013 - 10:33 PM.
Posted 09 October 2013 - 07:14 AM
Posted 09 October 2013 - 09:55 AM
Posted 09 October 2013 - 11:11 AM
I'll try the weld trick. If that doesn't do it, hooking it out might be the go. Cheers for the tips guys! Always better to ask first than have a go and stuff something up. Do people replace axle bearings and leave the bearing cup in the housing? Surely that is dodgy?
Posted 09 October 2013 - 11:19 AM
Made some progress over the weekend. I actually had the house to myself for the whole weekend, and I spent all of it in the garage finishing off my engine bay repairs. My SL/R is NOW at teh stage that I thought it would be when I bought it. All of the repairs I have carried out so far I didn't anticipate having to do, as I bought it sight unseen and none of this was mentioned in teh advert.
Anyway..... Welded in a new battery tray.
And the same panel on the opposite side.....
And now I'm ready to leave it for another month...... and then remove the subframe nd start stripping the underside and get the whole front end ready for paint. That's for another day......
Posted 09 October 2013 - 11:28 AM
No mate. All done professionally and above board. The existing panel has been retained and stored away for safe keeping, even though the majority of it is ratsh!t.
Posted 09 October 2013 - 11:54 AM
Posted 09 October 2013 - 07:48 PM
Officially it is dodgy, especially if bearing people are reading this ;-)Do people replace axle bearings and leave the bearing cup in the housing? Surely that is dodgy?
Posted 07 November 2013 - 05:13 PM
Bearing cups popped out easily. Didn't realise they were a relatively loose fit like that, so to speak.
Saving my pics and info for a bigger update... sorry guys... ... but just quickly, where can I get new studs for my diff housing?, that locate the diff centre to the housing, like so:
IMG_20131005_160705.jpg 184.17K
3 downloads
4 of the 6 in my housing were pretty well rooted. Definitely don't want to re-use them. Can you buy new?
Cheers!
Posted 07 November 2013 - 05:26 PM
Posted 07 November 2013 - 08:57 PM
Yea I have tried a few local places, and extensively online. All that has come up are second hand ones of the same. I'd really like new if possible.
The most likely thing might be wheel studs of the same thread and diameter.
Posted 07 November 2013 - 09:11 PM
Posted 08 November 2013 - 12:31 PM
Thanks Captain Yea, it was obvious, but I was still searching everywhere but a diff place.
Picked these up today, plus the oil filler plug (mine was rounded badly) for $30.
20131108_132508_resized.jpg 136.66K
3 downloads
The resto progresses.... Much meatier update coming soon.
Edited by notna, 08 November 2013 - 12:32 PM.
Posted 09 November 2013 - 10:44 AM
Yeah why is it we always try to do stuff the hard/long way first until someone
comes along and gives you a simple solution.
Posted 23 December 2013 - 12:32 PM
Well Christmas 2013 is upon us, so it's timely that I update this thread, and tell you all how I have spent soooo many hours on my restoration, with what seems like little progress. It's not quite frustrating yet, because the results of all my hours in the shed or garage are still motivating me. This is why we do it right? For the love of the resto!
I have two avenues of restoration going on right now. One is finishing rebuilding the diff and front end, so I can get the body back on all 4 wheels, and the other is finishing the paint so I can bolt it all back together.
The standard diff was completely stripped, inside and out, and was so impressive, I nearly just clear coated it as it...
IMG_20131005_160620.jpg 204.26K
1 downloads
I then had to replace the diff centre mounting studs, and helicoil the 2 stripped threads.
IMG_20131109_174226.jpg 63.82K
2 downloads
And I gave it a sweet coat of 2K black.
IMG_20131109_183052.jpg 156.34K
1 downloads
With all new bearings, brake lines and components, and a reco centre, it is now ready to assemble.
While this was going on, I was prepping and painting the rear doors. I have a set of abolute MINT doors, that have never been resprayed. So stripping them has been a breeze...
IMG_20131026_180147.jpg 117.12K
1 downloads
I then etch primed, hi-filled, and blocked.
IMG_20131130_130545.jpg 82.36K
1 downloads
They came out dead straight and totally satisfied my anal retentive ways.
IMG_20131208_163356.jpg 154.57K
3 downloads
Edited by notna, 23 December 2013 - 12:33 PM.
Posted 23 December 2013 - 12:37 PM
I then suited and masked up for some more paint action....
IMG_20131221_135139.jpg 45.77K
1 downloads
And hit the backsides with 2K
IMG_20131221_145156.jpg 61.9K
1 downloads
Then wrapped them up for myself for Christmas...
IMG_20131222_100534.jpg 52.08K
2 downloads
And gave the supa straight and smooth outer faces...
IMG_20131222_105451.jpg 58.06K
1 downloads
Some delicious Papaya in 2K.
IMG_20131222_154150.jpg 70.48K
2 downloads
Setup and prep for 2K is really time consuming, which is why this resto is going at a snail pace... but damn the results are amazing. LOVE that gloss off the gun.
Time for some downtime over the new year period, then back into it.
Merry Christmas all, and a hugely Happy New Year!
Edited by notna, 23 December 2013 - 12:40 PM.
Posted 23 December 2013 - 12:53 PM
Posted 23 December 2013 - 01:29 PM
Holden just knew that when they designed and manufactured the UC, it would become THE donor for all good SL/R restos and the like, in years to come. That's why the doors remained the same
Urban myth, complete BS, or true? Hmmm....
Yep, loving spraying the 2K. Maybe I should have hada career in paint / panel. I love it way more than my day job.
Posted 21 February 2014 - 10:29 PM
Plenty of progress happening at the moment, as I am between jobs... again... so the resto becomes full time in the meantime
Finished rebuilding the diff. Everything new, reco or reconditioned, including the brake lines. Made those myself... hope they seal properly!
12180_10152270697687491_934131333_n.jpg 123.29K
2 downloads
Fitted the diff back into the body. New everything there... shocks, springs, even plated all the bolts and nuts... every single one!
1654423_10152270697597491_463135360_n.jpg 82.82K
4 downloads
Next to go back in was the fuel tank. It's had a makeover inside and out. Totally clean, coated and painted. I tried to go for the original look with the silver. Wasn't after anything more than that.
1970722_10152277072892491_448135777_n.jpg 72.24K
3 downloads
Then up it goes... back where it belongs...
1622185_10152277072837491_1244257037_n.jpg 98.7K
2 downloads
And we get to see a pretty hot looking ass end
1779304_10152277113557491_864495917_n.jpg 79.15K
4 downloads
Finally got to fit wheels (to the rear only) and drop it back down on the deck. The front end is sitting on a trolley. Once I put the K-frame back together, it's on all 4's!
1798473_10152277113477491_188611070_n.jpg 77.29K
2 downloads
With all the weight back on the wheels, all the panels start to go on. Rear doors first, then fronts, then guards and apron. That's how I'm approaching it... anyone got a better way, let me know!
Drivers side...
1958090_10152279317172491_396975529_n.jpg 97.34K
2 downloads
Passenger side...
1798847_10152279317127491_135908120_n.jpg 83.05K
2 downloads
and.... that's all I got for now. Absolutely more to come.
Posted 21 February 2014 - 10:51 PM
Posted 21 February 2014 - 11:17 PM
Very excellent.
Posted 22 February 2014 - 05:04 AM
Beautiful.
Posted 22 February 2014 - 05:33 AM
Awesome so far keep at it
