PROJECT PAPAYA - A VERY FRUITY RESTO THREAD
703 replies to this topic
#151 notna
notna
  • 706 posts
  • Name:Reverse of username
  • Car:1976 LX L32 SL/R
Posted 06 July 2011 - 11:08 AM
top shelf work mate! the original resto is coming along great
could you give me a few tips with the spot weld cutter? did you use a 3/8 cutter?
Yes.
did you drill through both panels?
The cutter I used won't let you drill through both. A spot weld drill will. They are different. I did however drill a very small pilot hole through both panels so that the tip of the cutter would locate better and not slide off to the side.
and if you drilled through both panels were they easy to weld the holes back up?
Very easy to weld back up using the cutter, because the bottom panel layer is still solid.
i am getting a spotweld drill/cutter and can't decide which one is best, the cutter or the drill. i don't really like the idea of drilling through both panels. i'd rather drill through one so it is easier and stronger to weld the panels back up back up.
I agree with your logic there.
#152 _toranatime_
_toranatime_
Posted 06 July 2011 - 12:20 PM
thanks mate, this is a great forum, everyone is willing to help out. i just ordered a spot weld cutter, hopefully it will be here soon.
cheers, you made my decision much easier.
#153 lxsstorana
lxsstorana
  • 2,499 posts
  • Car:SS Hatchback
Posted 06 July 2011 - 12:25 PM
Was good to catch up yesterday Anton and that Fxxd was only passing through my garage (hopefully going on Saturday)
It's a worked 351, tricked up auto, 9 inch etc etc and NSW engineered in case people are wondering.
:threadjacked: (here's one photo and now lets get back to toranas.)
#154 LHSL
LHSL
  • 995 posts
  • Name:Phillip
Posted 06 July 2011 - 03:38 PM
So true guys.... I think any 70's Torana will require rust reparis though, and also have hidden faults that you unearth in the process. I reckon this car is solid.... despite what I have had to do. The chassis repairs were unexpected.... That's what you get when buying sight unseen, from a bullshit artist! :o The floors and boot are sweet. Once I finish where I'm at now, I have a minor sill repair and rear 1/4 lower repair and thats probably it.
Still.... awesome learning curve for me, and I have enjoyed it so far :D
So true. It is strange how different toranas rust in different places. My LH SL is a Melbourne built car, front plenums, front screen, all floor pans are brand new. Rear screen and boot floor different story. Yours on the other hand seems to have not suffered these issues but other more common LH/LX ones. BTW I may be selling mine as I have no time to restore. I can't believe you bought a car sight unseen! Very trustworthy.
Keep up the good work and keep that finger dry!
Phillip
#155 mitchg
mitchg
    The guy with the Torailer
  • 3,111 posts
  • Name:Mitch
Posted 06 July 2011 - 03:43 PM
Lookin good Anton! You've done so much since I saw it! Gonna be an awesome car!
#156 _nial8r_
_nial8r_
Posted 06 July 2011 - 07:20 PM
here ya go Anton it might make ya feel a bit better knowing i just come across this
i forgot that i had these few pins hole to sort out being the last of my repairs so i did the cut and found this
is stopped there as i have to make the cut a lot bigger as it not only goes in to the plenium but in to the cab aswell :surrenderwave: a few pin holes on top and a nightmare underneth :Headbang2: :Headbang2: :Headbang2: :Headbang2: :Headbang2: :Headbang2:
#157 _berro59_
_berro59_
Posted 06 July 2011 - 07:58 PM
Man that's nasty!
Berro
#158 _Kush_
_Kush_
Posted 06 July 2011 - 08:02 PM
Oh, man up! Both of you!
I had to make that section from scratch and it took 3 hours!
Nial8r you are a bloody crybaby! Hahahaha!!!! :)
#159 _Liam_
_Liam_
Posted 06 July 2011 - 08:03 PM
They are both lucky... At least some of the original metal is there in the first place.
#160 _nial8r_
_nial8r_
Posted 06 July 2011 - 08:25 PM
i have to cry kush cause know one else will do it for me :furious: and i guess i will find out how much more worse it is when i throw the grinder at it tomorrow :DOH:
#161 notna
notna
  • 706 posts
Posted 06 July 2011 - 11:47 PM
LOLing so hard right now @ all of you! :D
#162 notna
notna
  • 706 posts
Posted 08 July 2011 - 06:36 PM
Progress.... progress... maybe the last for a week or so (family back from holidays and now i gotta do family stuffs.... as we do)
This was what I started with today. Nasty bit of factory rust there.
Attached File  SLR_05.jpg   223.48K   2 downloads
So I chopped it out as best I could.....
Attached File  SLR_14.jpg   223.19K   1 downloads
...and figured I would leave the bottom layer there and repair that one, then plonk on top my salvaged piece from the trusty UC (aren't they great for fixing LX's ;) ).
This is the piece I cut from the said UC....
Attached File  SLR_18.jpg   197.55K   2 downloads
And this is how I will be attaching it, to repair mu trusty LX....
Attached File  SLR_22.jpg   196.17K   1 downloads
Then I sliced another piece from my good 'ol Mini door that I had stashed down the side of the house. I can't believe that a few years ago I bought a whole running Mini for $50, and I am STILL reaping the rewards from that score ;)
Attached File  SLR_23a.jpg   76.8K   3 downloads
And i welded that sucker in place, then ground those welds flush, ready for me to plonk the UC bit on top and weld it in.
Attached File  SLR_29a.jpg   71.8K   1 downloads
That's as far as I got. More to come..... :D
#163 _Leakey_
_Leakey_
Posted 08 July 2011 - 06:42 PM
Exactly the repair I need to do Anton. For the time being it will be bog city for me....
#164 notna
notna
  • 706 posts
Posted 08 July 2011 - 06:50 PM
Nooooooo!!! No bog mate! But then again.... if you ask for me to weld yours up, I will tell you to bog away!! :P How's that console btw ;-)
This was the under side from my awesome UC (that I chopped to bits) :P Just the one teeny weeny hole, as opposed to one teeny weeny bit of solid metal :D
Attached File  SLR_20.jpg   200.64K   2 downloads
#165 _Kush_
_Kush_
Posted 08 July 2011 - 08:58 PM
That's a nice repair you've done there :)
#166 _Liam_
_Liam_
Posted 08 July 2011 - 09:39 PM
Wish I had a UC to pinch panels off of...
#167 notna
notna
  • 706 posts
Posted 12 July 2011 - 06:30 PM
Pics often do things HUGE justice, or not enough. My repair work in this area has been fooking awesome, if I may say such things myself ;) But in pics it can look shite. Ii'm going to finish this one off tomorrow, plus.... Mick, aka lxsstorana, has kindly supplied a LH side front guard to eith use to repair mine, or repair for use itself. I'll tackle this tomorrow too. can't wait!
MASSIVE THANKS MICK.... when i put them both next to eachother this arvo, I knew I had sorted that problem in one way or another! :buttrock:
Next update tomorrow night ;)
#168 lxsstorana
lxsstorana
  • 2,499 posts
  • Car:SS Hatchback
Posted 12 July 2011 - 09:14 PM
Happy to help. :)
Keep on welding and grinding (you're winning the war) :gun:
#169 notna
notna
  • 706 posts
Posted 01 August 2011 - 10:33 PM
Bit of an update for you all.
Finished welding up the repair to the passenger side windscreen area. Came up well and I know there is no rust or holes anywhere in that area now.
Attached File  SLR_06.jpg   197.41K   3 downloads
Then I got to work on my passenger side guard. First I un-rolled the lip, and took it back to original.
Attached File  SLR_02.jpg   196.33K   2 downloads
Attached File  SLR_04.jpg   204.84K   1 downloads
Then I chopped out the very nasty bottom corner where it had been hacked badly for a front spoiler. It isn't called a "spoiler" for nothing! :D
Attached File  SLR_03.jpg   200.61K   1 downloads
Then, thanks to (lxsstorana) Mick and the guard he sourced for me :buttrock:, I cut a decent matching piece and welded it into place.
The extra welds there were pin holes and the like, that needed repairing.
That's about as far as I have gone with that guard. The rest of it is quite alright.
Then I went back to work after my 1 month break. It was a sad day..... :dontknow:
Since then I have been working on getting it back on 4 wheels. I have stripped the front subframe that came from (LH SLR 3300) Matt, and given it the RANEX once over. How good is that stuff huh? I have been using it for a few years, and had a lot of trouble buying some more just recently.
Then I POR15'd it, and while it was tacky, I gave it a dust of satin black. I love the look that gives, and I love the protection of POR15.
I've got a full subframe rebuild kit coming, including bushes, joints, etc.... and a subframe mount kit. I figured that since the front end is all sorted, I can slip the finished subframe in and continue working backward on the car. The bay will be primed and painted later on with the rest of the car.
Sadly, I don't have a large shed to spread out and leave the car in. I gotta be caring and sharing with the missus, and let her have half the garage. That's why it's best I get it rolling again. :surrenderwave:
More to come, sometime soon.
Edited by notna, 01 August 2011 - 10:36 PM.
#170 Tyre biter
Tyre biter
  • 982 posts
  • Car:Should have gone with Palais...
Posted 01 August 2011 - 11:47 PM
Great thread - I just read it right through and really appreciate your documenting everything - a great thread for someone like me to use as a reference point - thanks.
Indeed I was enjoying this so much that I totally forgot about the electric wok I had filled with some water to loosen up tonight's dinner remnants. I now have a house full of smoke, window wide open on a freezing Canberra night and have totaled a wok! Good thing my bride is away for a few days - I can hear the conversation we will have when she gets home; She says: "Honey, where did you put the wok?" I reply: "Umm, it just stopped working and so I threw it out. We'll have to get anew one" :)
Finally, please keep posting your efforts with your front suspension - I too am attempting this now and somewhat greedily I say that I would really profit from your experience with this part of the build. I have it out and mostly disassembled, the K Frame and lower wishbones arms in nice black shiny paint but I have to take apart the upper wishbones - think I need to visit a suspension shop in order to have the existing bushes pressed out and some new ones pressed in... So (like you), I have to install the suspension re-build kit and later the mounting kit when the K-frame goes back in - from what I have read here the re-fitting of the K-frame is an awful job for which one needs to retain their patience and their ha-ha! Time will tell I guess?
All the best and cheers, TB
#171 notna
notna
  • 706 posts
Posted 02 August 2011 - 10:22 AM
LOL @ your wok! It went out in the best way possible.... while you were distracted by Toranas :D
When I dropped my K-frame out, I literally dropped it! :o It slid off my jack while I was lowering it, and BOOM.... hit the floor. It was then I realised that it's too damn heavy to work with, in a home garage, in 1 piece. I plan on mounting the bare K-frame back into my car, and then building the entire front end "in the car". I am yet to strip my old K-frame. The control arms, sway bar, steering rack etc are all good. It was the actual K-frame that was 'ratus shitus'. I will strip the old and clean / paint everything, and refit those bits to the new one in the car. Will definitely let you know how it goes.
#172 hanra
  • 10,969 posts
Posted 02 August 2011 - 12:45 PM
+1 mate! Ill be dropping my K-Frame at some stage in the future for a full re-build. Ill blast and 2 pac mine however.
#173 _nial8r_
_nial8r_
Posted 02 August 2011 - 01:50 PM
IMO Anton iw ould build the K-frame and wheel it under the front end then lower the front down " slowly " that how i did mine when i took it off the chook cooker and it when back on fairly easy :badabing:
#174 _mick74lh_
_mick74lh_
Posted 02 August 2011 - 09:16 PM
The front part of the car is looking awesome. The repairs are a real credit to you.
I guess you can do the k-frame either way. I assembled mine first and then had 2 people help putting it in, but theres no reason why you couldn't assemble it attached to the car once you've got the new bushes pressed into the control arms.
#175 notna
notna
  • 706 posts
Posted 21 August 2011 - 05:53 PM
Been progressing this slowly, but haven't had anything spectacular to post.
Started to strip down my old front end. The K frame is bent, which is why I bought the replacement.
Attached File  SML_40.jpg   216.55K   1 downloads
Everything else is OK, well so I thought.....How does a coil spring snap like that?? :o
Attached File  SML_51.jpg   231.44K   1 downloads
Then I started to round up all the bots and bits. I dug out containers of Torana bolts I have had for 20 years, and then sorted those out with the ones from this SL/R. I plan on getting everything silver zinc plated. On previous restos I have used gold zinc, and meticulously wire wheeled each nut and bolt prior to sending them off for plating. This time I thought wire wheeling everything is a bit much, but you still need to clean off old paint and crud otherwise the plating looks crap. Today I I dunked these into a big tin of paint stripper, and shook them around for 30 mins. Then I added some petrol and continued shaking.
Attached File  SML_47.jpg   225.91K   1 downloads
After a while I dumped them out in a big tray and gave them a blast with a high pressure water cleaner.
Attached File  SML_55.jpg   244.86K   3 downloads
They cleaned up really well and will only need a very light lick on the wire wheel at the most.
Will send them and lots of other bits off soon for plating. I have a place in Smithfield that does a ripper job.
More to come.....
