lx vs UC diff mounts
#1 _keg006_
Posted 08 August 2010 - 04:56 PM
Can i cut the diff mounts of the LX diff and use them for the conversion on the BW to fit my uc? Has anybody ever made there own mounts? If so any suggestions
Posted 08 August 2010 - 06:16 PM
Lower is fine though
The top mounts are at a different angle
Posted 17 August 2010 - 04:29 PM
Posted 17 August 2010 - 04:37 PM
All the mounts on the BW78 will need removing.
Posted 17 August 2010 - 04:42 PM
Maybe the guy at Aussie diffs missunderstood me when I told him about it. He told me to get an LX diff to replace the top and bottom UC mounts as the UC bottom and top differ to LX diffs? I'll find out when I take it all down to him in the coming weeks. Either way I have an LX diff to cut up
Posted 17 August 2010 - 06:32 PM
Posted 18 August 2010 - 11:51 AM
It's only $200 to get them to do all 4, so I'll get them to do it then if there's any dramas I can ask them 'whats wrong?.
Posted 18 August 2010 - 01:28 PM
Posted 18 August 2010 - 01:30 PM
Posted 20 August 2010 - 10:32 PM
Also the distance between the top arm centres, both on the top of the diff and at the floor end.
I still can't see the lower brackets being in a different position unless the upper arm location changes pinion angle between the two model cars...but that would change the whole setup throughout the suspension travel.
#11 _suxgas_
Posted 30 November 2010 - 01:18 AM
Posted 30 November 2010 - 08:02 AM
I think they are having you on about UC lower mounts being different though. I've used banjos in UC's before by simply welding HQ-HZ top mounts onto a LH-LX banjo and it all worked perfectly.
#13 _suxgas_
Posted 30 November 2010 - 08:57 AM
Posted 30 November 2010 - 11:54 AM
#15 _nemo355v8_
Posted 30 November 2010 - 12:22 PM
Its as simple as getting the old mounts cut off and welding on the modle specific top mount, UC for UC. LH/X for LH/X.
There maybe a slight differnce on the bottom arms but I doubt it is any thing to worry about.
A fool mate of mine used a LX Bango in his UC and managed to get the top arms bolted up, It was putting a lot of distotion in the bushes thou.
A guy on Ebay makes adapter arms for UC to LH/X change overs.
http://cgi.ebay.com....=item230beaa166
Posted 30 November 2010 - 06:23 PM
Wouldn't they induce binding and also allow the diff to move around as the mounting points are not parallel?
Posted 30 November 2010 - 11:44 PM
#18 _rocket_
Posted 01 December 2010 - 01:17 AM
http://www.altra9.com.au/
Posted 01 December 2010 - 02:25 PM
#20 _Kush_
Posted 01 December 2010 - 04:06 PM
I had a look at my diff today and it's cast steel.
See pic
Can someone please un-confuse me?
#21 _rocket_
Posted 01 December 2010 - 04:16 PM
Yeh, I didnt see them on there either, but has was telling me how it is such a long process to cut the off and dress them, and weld the onto the housing, and most people dont want to pay for the time it takes, so they have new brackets made for all holdens, so you end up with a nice neet job, and a bracket that hasnt been stressed for 30 yrs.best give them a call for more info, very helpfull guys.Can't see the new brackets on the web site???
#22 _rocket_
Posted 01 December 2010 - 04:19 PM
How on earth do you cut off the upper mounts to weld them to a new diff?
See pic
I d say more in the case of yours, it would be a 9 inch going into a UC, and using new LX style brackets to weld onto a steel housing, rather than the cast unit you have.
#23 _Kush_
Posted 01 December 2010 - 04:30 PM
thanks Rocket
