spraying clear acrylic
3 replies to this topic
#1 _wileyg_
_wileyg_
Posted 14 August 2010 - 07:15 PM
hey guys just wanted to know if any one knows the deal with spraying clear after base coat is dry. i painterd my base coat (just a solid colour) and was gonna clear it straight after but ran out of time. so do i sand it back a bit then clear it? do i have a time frame to wait till i do it as i painted the car today
cheers shane
#2 _Yella SLuR_
_Yella SLuR_
Posted 14 August 2010 - 08:47 PM
Hit it with 800 wet and dry, being extra careful of your edges. If it helps run some 12mm masking tape over your ridges to stop you sanding too close (or through) to them. You just want to form a key for the clear.
Edited by Yella SLuR, 14 August 2010 - 08:48 PM.
#3 _Quagmire_
_Quagmire_
Posted 14 August 2010 - 09:22 PM
dam i could have used that tip a week ago
does it matter if it's mettalliic?
ain't you sposed to mix a little base coat into the clear as well?
#4 S pack
  • 15,726 posts
Posted 14 August 2010 - 11:15 PM
Same difference whether it's metallic or solid colour. The main reason for colour sanding before applying clear is to smooth out any orange peel ,runs etc so you get a smoother glossier deeper looking finish.
Adhesion should not be issue if you apply acrylic clear coats over acrylic colour that has already dried.
Acrylic lacquer thinners are referred to as hot thinners as they melt into the previous/existing paint layers as you apply the next coat.
That is why it is not advisable to spray acrylic lacquer over enamel as the lacquer thinners will soften the enamel and make it wrinkle, blister and peel.
Enamel thinners on the other hand are referred to as cold thinners as they don't melt into the previous/existing layers.
Enamel can usually be sprayed over acrylic lacquer without any major problems.
Mixing some top coat colour in with the clear is usually done when repairing metallic paints and you need to blend the new paint into the existing. It should not be necessary to mix some top coat colour with the clear coats when doing a full repaint but no reason why you can't if you want to.
