DIRTBAG FINALLY HAS A TORANA.....SORT OF?
542 replies to this topic
#151 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 11 December 2010 - 08:57 AM
pics!!! Posted Image
#152 rodomo
  • 18,039 posts
Posted 11 December 2010 - 09:54 AM
Attached File  Dirtbag.jpg   80.67K   5 downloadsTHREAD STEAL!!!
I thought I'd post this here cos I might get an answer sooner?
I've been watching your threads but did I miss something? :dontknow:
#153 myss427
myss427
  • 1,636 posts
Posted 11 December 2010 - 10:00 AM
Hey Dirtbag, go on put tiny bands in the wheel tubs and you'll get 10's in there! I have 2 10's laying around the shed in HQ pattern with 3 and half back space if you want.
#154 mitchg
mitchg
    The guy with the Torailer
  • 3,111 posts
  • Name:Mitch
Posted 11 December 2010 - 01:32 PM
Rodomo isnt that the camaro?
One closest is the firebird.
#155 rodomo
  • 18,039 posts
Posted 11 December 2010 - 01:50 PM
There's a difference? :fool:
Is there a Firebird thread that I've missed? :dontknow:
#156 mitchg
mitchg
  • 3,111 posts
  • Name:Mitch
Posted 11 December 2010 - 02:56 PM
Hahah hes mentioned the firebird here and there. Its his wifes car i think
But looking at the camaro thread, im thinking its the other way round and the firebird is on the rotisserie. Or thats just another project he hasn't mentioned.
#157 _dirtbag_
_dirtbag_
Posted 11 December 2010 - 03:10 PM
Hahaha, you guys are funny : )
OK, the car closest in the pic from rodomo is the 69 camaro. The car right in the background with no front panels is the 68 firebird I'm building for my wife. The car on the rotiserie is a 1963 pontiac bonneville 2 door hardtop. Probably one of the rustiest cars I've had to fix, and basically no aftermarket panels, so I've had to make nearly all of it. Good fun : )
Geeez myss427, you sure know how to get a guy thinking. You're a bad influence. I'd still need the skinny front wheels though, cos the 7s I have would look ridiculous on the front.
So tell me, are those 10s a donation? :badabing:
#158 _Quagmire_
_Quagmire_
Posted 11 December 2010 - 03:20 PM
So tell me, are those 10s a donation? Posted Image
pics of the bonneville please Posted Image
#159 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 12 December 2010 - 09:36 PM
:spoton: :spoton: :spoton:
#160 _dirtbag_
_dirtbag_
Posted 17 December 2010 - 06:20 PM
OK. Here's a quick rundown on the bonneville.
Here it is the day it arrived at my place.
This is looking up to the inner/outer sill and chassis rail. Mint condition : )
After what felt like a million hours it was all back to bare metal.
After etch priming the whole lot I unbolted the body from the chassis, then propped the body up on the chassis with some timber to make it easier to get onto the rotisserie. Only problem was the body was holding the chassis together, so when I propped it up on the timber it broke the chassis in two at the firewall. Bargain : )
Eventually I got it onto the rotisserie. It's still on there to this day.
Here's a look at the inner sill. Nice!
This channel is where the chassis runs. It all needs replacing.
The floor and floor supports have a few issues too.
All the grey bits are new metal.
Here's the majority of the floor fixed, the wheel tub has been stretched 100mm to fit 20x16s and the new outer sill made and clamped into place to check fit.
With the lower part of the rear quarter cut off I could make a new lip for the outer wheel tub.
Here's the same channel I showed earlier that the chassis rail sits in. Looks a little different now.
Now with a bit of new metal on the outside it sort of looks like a car again.
Anyway, I could go on for ages about the work gone into this thing but I wont bore you with it all. Basically everything is pretty stuffed and I've been fixing it : )
#161 _cruiza_
_cruiza_
Posted 17 December 2010 - 06:32 PM
You are never boring Dr Dirt, and sorry to make this a reprimand but in future we your loyal followers expect to see multiple threads, on the build up of each master piece as you weld your magic grinder, MIG and craft
#162 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 17 December 2010 - 06:35 PM
no doubt it will come up as good as the rest of the dirtbag done vehicles... but more to the point, pics of the new wheels on the uteorana!! Posted Image
#163 _dirtbag_
_dirtbag_
Posted 17 December 2010 - 06:37 PM
Another thing I thought I'd have a quick play with was a steel 4 inch camaro/torana style scoop.
I started with some 1.2mm zincaneal sheet. I used the folder to put the small swage through the middle of the piece.
It's hard to see the swage as it's quite small, just like a torana bonnet.
You can just see the swage here. I wanted it to match the torana bonnet really well.
I've got a piece of 1 inch pipe I can clamp into the folder so I can do bigger radius bends than the machine allows. I thought this might be good enough for the side bends.
I just did a few basic pie cuts to get the front to angle down.
I traced the profile of the bonnet onto the lower edges of the scoop, then trimmed it to fit. Once that was done I used a hammer and dolly to put a radius around the base of the scoop, where it meets the bonnet. Then I tacked the scoop on.
I then stripped the bonnet, cleaned the scoop and put a lot more tacks on the scoop.
Because I don't get much time to play with my own little projects I put some rust converter on it so it can sit around for a while.
This is just a trial to see how easy it would be. I think this one looks OK but is a little bit squared off, so if I do another one it will be more rounded. I'll see how it looks once this bonnet is painted.
So what do you think?
#164 _dirtbag_
_dirtbag_
Posted 17 December 2010 - 06:40 PM
I'll put the wheels on the car when I get a pair for the front. I don't want mismatched wheels. Fussy, aren't I : ) hahaha
#165 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 17 December 2010 - 06:58 PM
scoop looks good! when are you going to start selling them Posted Image
#166 _Gunmetal LH_
_Gunmetal LH_
Posted 17 December 2010 - 07:04 PM
"...so if I do another one it will be more rounded. I'll see how it looks once this bonnet is painted."
Looks sweet so-far!
Yes on the more rounded shape. I've never made something like this so you can take this 'with a grain of salt' but would it be easier to get the top shape (like the front sloped section) and use 2 seperate side pieces? :dontknow:
#167 _Lamo_
_Lamo_
Posted 17 December 2010 - 07:07 PM
The bonnet looks great Dr. Dirt!
#168 _dirtbag_
_dirtbag_
Posted 17 December 2010 - 07:24 PM
Looks sweet so-far!
You could make it in 3 separate sections, but then you've got a lot more welding and metal finishing to take care of. Plus the extra risk of it warping. That's basically the point of this exercise was to see if I could fold up something in 1 piece that can still look OK once it's welded on and smoothed in. I'll have to wait and see when this one is primed whether I need to make it out of multiple pieces to get the look I'm after.
#169 _mick74lh_
_mick74lh_
Posted 17 December 2010 - 07:32 PM
Cool. I love the work you've done on the Bonneville. Isn't there a thread on it somewhere already?
#170 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 17 December 2010 - 09:00 PM
Yep, in the 69 Comaro thread
Just confirming I noticed the boot pan in the Bonni is different to the 63 Pontiac Laurentian.
#171 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 17 December 2010 - 10:08 PM
Since the chassis is #@$^%& in the Bonni, aybe an Art Morrison sub frame would be the go, if they make them for this model.
#172 _Herne_
_Herne_
Posted 18 December 2010 - 12:00 AM
Mr Dirtbag you are an amazing man, your work never ceases to impress me ( I am easily pleased but thats not the point).
You Sir are a true credit to the hobby, more power to you.
Herne
#173 _dirtbag_
_dirtbag_
Posted 18 December 2010 - 12:05 AM
Thanks Herne. People normally just call me an asshole hahaha : )
Bart, the owner of the car has a '62 chassis there for me to play with that's in good nick. I was just going to bring the rear rails in a bit but now maybe we'll go with a McDonalds Bros triangulated 4 bar rear clip instead.
#174 Heath
  • 18,393 posts
Posted 18 December 2010 - 10:33 AM
Awesome scoop!
#175 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 18 December 2010 - 11:17 AM
No worries, there were variations in the chassis from 62 on, the K chassis and wide track, the K chassis being the narrow track i think. Im sure you're more than able to buff that issue out
Great work. :3gears:
