AUSSIE DESERT COOLER RADIATORS
20 replies to this topic
#1 _JNR_ATE_
_JNR_ATE_
Posted 19 August 2010 - 09:35 PM
Hi guys, im now building a pretty angry HG with DART 400SBC.
I need to organise the radiator and have been lookign at the ADC aluminium 4 core "burnout king" with twin thermo and over flow bottle attached.
Its a fair wack of a price at $1350, does anyone have this setup, is it worth it.
Would there radiator only and BA Falcon thermo fans be the same for less. without the good looks of the ADC setup of course.
Any help would be great
JNR_ATE
#2 _1uzbt1_
_1uzbt1_
Posted 20 August 2010 - 10:22 AM
I had one of these rad/fan combos come into work this week,im not sure if they use the same fans on all combos but the fans appeared to have very little airflow as this particular car was getting warm slowly.I would stick to the tried and tested Ford fan sets.
Edited by 1uzbt1, 20 August 2010 - 10:23 AM.
#3 _JNR_ATE_
_JNR_ATE_
Posted 20 August 2010 - 05:15 PM
OK, they run 2 single fans, like davies craig ones. i heard the commodore ones are ok aswell.
They just so "complete" with the setup.
Any other people?
JNR_ATE
#4 _SLYLX_
_SLYLX_
Posted 20 August 2010 - 06:07 PM
stay away from aussie dessert coolers,i have 1 in my nissan patrol with a 350 chev,its fallin to bits.....thier not made in house anymore ,im gettin a hq style one built in 2 weeks,as for thermos,ive got au falcon thermos and there the best part of the car,and chevs run hot!never goes over halfway,as for hi revs and burnouts,im not sure
also mine was brass not alloy,so they might be good,but the brass is crap
#5 _JNR_ATE_
_JNR_ATE_
Posted 20 August 2010 - 09:02 PM
Sweet, im def going aluminium, but by the sounds of it the Falcon thermo fans will be a better/smarter choice.
JNR_ATE
#6 TerrA LX
Posted 20 August 2010 - 09:13 PM
The dessert cooler they have recommended to you sounds rather large to me.
#7 _JNR_ATE_
_JNR_ATE_
Posted 20 August 2010 - 09:34 PM
there is $100 difference between the "street and strip" and "burnout king" setups
Wouldnt it be better to over compensate on the cooling package? i know the street and strip will be sufficient with a good Elec water pump, just figured it'd be a smarter choice.
JNR_ATE
#8 TerrA LX
Posted 20 August 2010 - 09:57 PM
It doesn't quite work like that, unless you are going to run a full auto controlled electric pump and no thermostat, allowing you to then evenly distribute the coolant at a constant temp but without the flow rate the heat around the motor itself will be different if that makes sense.
What I mean to say is that after warm up, with the thermostat open (or in the case of an auto controller without thermostat), coolant flow should be relatively constant to engine output (read RPM) and airflow the variable in a perfect world, mantaining even engine operating temp.
I am of the opinion that going to a thicker, instead of a larger surface area radiator will only restrict air flow and trap heat, not release it to the airflow.
I suggest you read up on the stickies for a more informed choice.
#9 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 13 March 2012 - 04:29 PM
anyone out there not happy with there aussie desert cooler?
#10 V-SLR5000-P
V-SLR5000-P
  • 1,321 posts
  • Car:L34 x 2
Posted 13 March 2012 - 05:12 PM
I'm not a fan, had one built years ago when they were in Nth Melbourne. Gave them my old radiator and they still couldn't make it the right size first time around. Eventually got it right, but lost a customer in the process.
#11 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 13 March 2012 - 06:22 PM
yeah they had me as a customer then lost me because i just sent one back to them today, i am not too happy.
i thought they were one of the best.?
#12 mr5000
mr5000
    chief break-everything
  • 3,455 posts
  • Car:77 lx 4door
Posted 13 March 2012 - 06:53 PM
a friend of mine had a aussie desert cooler on his hj monaro couldnt keep it cool no matter what he did everythign else was perfect he spoke to a few people lots of people told him to sell it and get one made by race radiators in dandy hes never looked back same thermos ect on it heard same storys from other people
#13 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 13 March 2012 - 09:11 PM
heres the pic of the one i got maybe just a one off...they were nice about it and are taking it back and when they recieve it they said they would refund me.
#14 _sshatch355_
_sshatch355_
Posted 13 March 2012 - 11:34 PM
got one of there brass triple flow 4 core ones in mine but was brought 8 or so years ago and we removed the baffles when we swapped from sbc to holden v8. cant fault it car runs cool im a happy customer so that makes 1 lol
#15 _1uzbt1_
_1uzbt1_
Posted 14 March 2012 - 10:28 AM
jonesey, what in particular is wrong with the one you sent back??
#16 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 14 March 2012 - 11:11 AM
little things add up
if you look at the top you can just see that sections of the cooling fins are damaged the photos aren’t the best.
the alloy thermo housing had scratching where it looked like someone slipped with a screw driver
minor scratching on the top tank (i could have buffed it out i spose but why should i its meant to be new)
it had the black thermos, which look really nice but i ordered their chrome ones and got the black
it was missing the relay and wiring for the thermos (that was ordered too)
i also paid for a oil cooler to be supplied and that was not in the box either
not major problems on their own but they all added up.. Look i think i might just have been unlucky the have a good rep (there is always a lemon here or there and looks like i got it)
#17 rexy
rexy
  • 3,740 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 14 March 2012 - 11:01 PM
I have their product in three of the fleet. All HQ size 4 core tripple flow jobs. They have done an excellent job. Kept the BBC in the ute cool for 16 years and the 383 in the LX cool for just as long. About 7 years ago got a custom one for the father in laws 404 pug ute. He lives up in the hot country and its always done well.
These are all brass units made in house.
No problems here.
#18 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 14 March 2012 - 11:51 PM
great keep the good raps coming! i don't want to believe that some one with such a good name was selling shit.
#19 Bernie
Bernie
  • 301 posts
  • Car:2 lx Hatches and 3 lx 4 doors
Posted 15 March 2012 - 07:37 AM
Jonesy,Got one from PWR ,Looked great performed well until I gave it a good rap to a 4wd group .Lost all its coolant from a crack in the base to coolant tube ,took it to PWR in qld as it cooked my 6.5 turbo .The owner asked me how much I wanted to waste on getting them to do anything about it .I told him to remember me next time it turns to crap for your race team .My phone rang hot when it went into the wall about 6 months later .There is a God I thought .
Race radiators now supply me rads when I need them .
Really that isn't a big deal what your complaining about .It is aluminium and is easy to scratch and damage with general handling .Grab some polish and get int it if you want it perfect .Ask them to sort out the issues you have with the colours etc .Then if you get no where then give them a bagging .
#20 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 15 March 2012 - 10:43 PM
I understand what you are saying but the fact is when you pay $1300 for a new product ( the fin damage is what I was not happy with) you want to get a new product or at the least everything that you paid and ordered to come in the post. I am not saying that there products are not good if you read through my post I do not think I am bagging them at all, as I said I think I just got a lemon ( in my opition) and I was just sharing an experience and having a chat (thats what the forum is for?) There after sale customer service was great they are letting me return the radiator for a full refund, they post really quick And in the end I have paid a little extra and got another great product from a local business. Thanks for the reply, jonesy
Edited by jonesy, 15 March 2012 - 10:47 PM.
#21 fatslr
fatslr
  • 1,247 posts
  • Name:Garth
Posted 16 March 2012 - 12:25 AM
Hey Jonesey i know exactly where your coming from and agree with you whole heartedly.
A really good mate of mine went to Summernats a few years ago and organised a radiator with the above said to pick up from Motorvation a week or so later .
Mate was amping from getting to go to Summernats and pumped knowing that his radiator for his E38 was going to be waiting to be picked up from the ADC stand at Motorvation went with him to pick it up and was shown a hemi V8 radiator with necks on opposite sides to a 265 .
"sorry mate i wasn't sure if they were different"
after going to Summernats and taking the time to talk shop and order correct part he was let down and fobbed off .
I am not saying their product is no good but these stories are true and when you work hard for your money and do everything to make it happen and get let down the word does get out.
At 41 i have definately started to accept that life is full of disappointments but after each one you learn a little .
