how much power can a W50 toyota box take
19 replies to this topic
#1 _bunkerjest_
_bunkerjest_
Posted 22 August 2010 - 11:12 AM
are they a very strong/ reliable box and what sort of power can they take
#2 TerrA LX
Posted 22 August 2010 - 02:05 PM
Are you a very good/capable driver and how sticky are your back tyres?
#3 dattoman
  • 16,487 posts
Posted 22 August 2010 - 05:28 PM
I've broken them with non turbo 4 cyl datsun engines
#4 Heath
  • 18,394 posts
Posted 22 August 2010 - 05:31 PM
Everyone will have their own opinions. I've heard good things about their capacities...
Did Toyota ever publish a torque rating for them?
#5 dattoman
  • 16,487 posts
Posted 22 August 2010 - 05:46 PM
This states stock HP applications
http://users.tpg.com.../gearboxes.html
It states the alloy T50 using more HP than the W50 ... I've broken both in Dattos
Some say they can take up to 240HP.... but its the torque that breaks them
But your talking about potentially fatigued metal on a SH box... so don't expect it to handle a healthy 308
#6 TerrA LX
Posted 23 August 2010 - 02:12 PM
Reving to 8000rpm with a locker diff on slicks on the track????
#7 dattoman
  • 16,487 posts
Posted 23 August 2010 - 09:07 PM
Yes.... your point ?
And it was 9600 rpm anyway :)
#8 TerrA LX
Posted 23 August 2010 - 09:21 PM
That would ruin just about any second hand box.
IMO if you are after sever duty such as this then HD bearings and blueprinting the box would be mandatory.
#9 dattoman
  • 16,487 posts
Posted 23 August 2010 - 10:09 PM
I didn't say mine was a SH box
It was a fully race prepped unit
Except it didn't have straight cut gears...I didn't have the spare $3500 for close ratio straight cluster
I doubt anyone would put a Celica box behind a Holden and spend thousands rebuilding it when better boxes would be available cheaper
#10 TerrA LX
Posted 23 August 2010 - 10:40 PM
Yeah you are right, you did not, don't know why I thought that sorry.
#11 _77hatch_
_77hatch_
Posted 25 August 2010 - 09:48 PM
i rebuild diffs and gearboxes for a living , if i get a celica 5 spd come in i usually advise the customer they are better to update to a better 5spd if they can !. im sick of seeing dissapointed people bringing them in with chewed gears ,failed bearings and 5th gear falling apart! . the T5 has to be the best bang for buck 5 spd getting around !
#12 _nemo355v8_
_nemo355v8_
Posted 11 September 2010 - 07:16 PM
totally agree with this, why stuff around with 4 cyl boxes behind a 8 when T5 s can be had so cheap now days.
The conversion is going to cost the same and a T5 can be had for $200- 300 where as a toyota box will cost $500- 750.
for a torana use a T5 out of a EA to AU falcon and your shift only moves back about a inch.
Hell ya can pick up shit EA-EB falcons dirt cheap take the box out and wreck out the rest, may even make money towards the conversion, lol
#13 _bunkerjest_
_bunkerjest_
Posted 12 September 2010 - 07:43 AM
is the T5 in the EA-AU the same between 6 cyl and V8??
#14 _nemo355v8_
_nemo355v8_
Posted 12 September 2010 - 03:37 PM
I believe so the only differnce is the bell housing.
#15 mr5000
mr5000
    chief break-everything
  • 3,455 posts
  • Car:77 lx 4door
Posted 12 September 2010 - 07:12 PM
t 5s have alot of different input shaft lengths there was a thread on this not long ago
#16 _nemo355v8_
_nemo355v8_
Posted 12 September 2010 - 08:14 PM
there are 6 or mare different lengths I found the EA -AU ford one was the best suited to a torana, about the same length as aussie 4 speed and the shift close to original torana.
Good upgrade for any one running ford single rails, you can use the same bell housing with a little modification, then every thing bolts up.
clutch,Xmember, tail shaft, speedo all can be reuse on the T5
#17 _hatch76_
_hatch76_
Posted 13 September 2010 - 09:37 PM
Hey mate
so if running the falcon T5, can you still run a full centre console?
#18 _Machine_
_Machine_
Posted 17 September 2010 - 09:02 PM
so a holden t5 and a ford t5 are the same box and a 6 cyl and v8 box? except the input shaft? anything else?
Thanks, Mark.
#19 _nemo355v8_
_nemo355v8_
Posted 22 September 2010 - 12:11 AM
Hey mate
Yes you can you will have to put the gear stick in a vice and give it a slight bend as it touches the consul when in 5th and reverse. no major issues there.
I even went as far to mod the shift to look stock Torara. You must use a Falcon box for shift to be in same place as original Torana.
I run a falcon box behind a alloy headed 355 strocker that has run a 12.5.
I have broke 1 by dropping the clutch in third while racing but before that it had coped a fair bit of punishment, good cheap 5 speed in my opinion.
#20 _nemo355v8_
_nemo355v8_
Posted 23 September 2010 - 12:14 AM
Thought i would add a pic of where my shift sits with this box.
