VN rear track measurement
#1 _CHOPPER_
Posted 26 November 2005 - 08:02 PM
Posted 27 November 2005 - 08:19 AM
#3 _Yella SLuR_
Posted 27 November 2005 - 08:54 AM
Why not Ford 9"? Alot of the guys are going to Borg Warner diffs, don't know how they compare strength wise, but I believe you get the strength without the weight. Think that's what the thinking is.
Posted 27 November 2005 - 09:11 AM
The BW is nowhere near as strong as a ford 9", in stock form the 9" is probably still 100% stronger.Chopper 1482mm on the wifes VN Wagon (Just went out and measured it). Borg Warner 3.08 LSD.
#5 _CHOPPER_
Posted 27 November 2005 - 11:55 AM
Once again, what is the rear track of a VN Commodore? Yella seems to think it's 1482 MM, I thought it was over 1500 MM.
Posted 27 November 2005 - 04:39 PM
#7 _CHOPPER_
Posted 27 November 2005 - 07:54 PM
#8 _Yella SLuR_
Posted 27 November 2005 - 08:28 PM
Edited by Yella SLuR, 27 November 2005 - 08:29 PM.
#9 _Yella SLuR_
Posted 27 November 2005 - 09:01 PM
#10 _1QUICK LJ_
Posted 27 November 2005 - 10:54 PM
#11 _Yella SLuR_
Posted 28 November 2005 - 07:10 PM
VN Review
Front track (mm) - 1451 (Executive and Berlina), 1453 (Calais).
Rear track (mm) - 1478 (Executive and Berlina), 1480 (Calais).
Now if I can just find some pics of the G-Pak Torries which is what I was actually looking for!!!
Edited by Yella SLuR, 28 November 2005 - 07:10 PM.
#12 _CHOPPER_
Posted 03 December 2005 - 08:00 PM
I thought somebody else would have picked up on this by now. Did you know that a stock VN axle is just as strong as a 28 spline Ford 9" axle?Question, why would you use a VN diff if you have to cut it down? Go to the wreckers there missing centeres and axles missing from heaps of commdores. Every second VL turbo has a 9inch and different box. Must be real good diffs. Why not just put 9inch in and forget about it.
#13 _Yella SLuR_
Posted 03 December 2005 - 08:22 PM
#14 _CHOPPER_
Posted 03 December 2005 - 08:59 PM
#15 _Yella SLuR_
Posted 03 December 2005 - 09:09 PM
#16 _CHOPPER_
Posted 03 December 2005 - 09:11 PM
Posted 05 December 2005 - 01:06 PM
#18 _CHOPPER_
Posted 11 December 2005 - 12:38 PM
VB - VK "series 1" rear track is 1414 MM.*
VK " series 2" and VL rear track is 1440 MM.
* A reliable source says that the wagon rear track is an extra 12.7 MM wider than sedans.
