"L34 heads" are they numbered or anything?
Posted 30 August 2010 - 09:25 AM
Well plans change and now I want them out of the shed (sick of moving the frOckers around)
But I just thought Id ask if the numbers meant anything-
numbers cast in the head are-
2812174
19D
10
They were sold as L34 heads which im assuming were fitted to a whole bunch of things (L34 being the high output v8 right??)
If anyone could fill in the blanks for me?
Cheers,
Chris
Posted 30 August 2010 - 10:33 AM
Edited by MRLXSS, 30 August 2010 - 10:34 AM.
Posted 30 August 2010 - 10:49 AM
Posted 30 August 2010 - 11:38 AM
This thread raises questions for me...
has some people saying that they are L34 heads??
Posted 30 August 2010 - 12:08 PM
Are you sure L34 heads have an X on them?
Nope, not sure at all! LOL. I've just heard people say this...
Posted 30 August 2010 - 05:08 PM
As I stated in that thread OrangeLJ references, the 99 numbers are simply a part number. The casting number of L34 heads should be the same as all other HQ-HJ/LH 253 or 308 heads as they are (as far as I know) just modified standard head. As to tell if a pair of heads is off an L34, hard one. Dave Bennett probably produced many more heads that were actually fitted to L34 vehicles, and also probably modified standard heads identically for aftermarket use. So my guess is unless you have an L34 with an un-opened engine i'm not sure how you'll ever prove the heads are the originals of the car. So trying to identify heads on the bench - good luck!
_Quagmire_
Posted 30 August 2010 - 09:06 PM
i've heard this to?
dr terry would be able to answer he helped me track down what mine where out of (although it was when i was on fastlane)
do the valves have "yt" any where on them?
they pre pollution?
Posted 30 August 2010 - 09:19 PM
Hi guys, just lookin at these heads supposedly off a 253 commodore engine, the # is 9936122 on both of em.
Struck my attention as they both have the 'x-cast; in the head.
The heads have standard valves and a pretty bog stock.
So i'm pretty sure the 'x' is nothing special. Unless this has already been clarified?
Mike
Posted 30 August 2010 - 09:20 PM
Posted 31 August 2010 - 08:40 AM
The heads need a service, and one is missing two valve springs and valves.
Came with a manifold too that Ive had sandblasted and is in pristine condition.
So Im guessing if I got my $150 back id be doing well.
Posted 18 September 2010 - 08:20 PM
gmh made 60 sets of 2812174 heads with the x on the end of them for the car that got dropped the gtr-xu2
all they where was the std head with little hier flow and larger valves which later became the l34 heads.
I bought a set of heads at a swapmeet (with a manifold) and was planning to use them later on to build a 308.
2812174
19D
10
Cheers,
Chris
