LH - LX Rad Support Dimension Please
Posted 26 September 2010 - 09:29 PM
My SL/R came with a repaired rad support. It was a dodgy job, and I have cut that part out and bought a Rare Spares rad support rust repair section.
Can someone have a look at the attached image and tell me what that dimension is please? I need to know so I can trim up my rad support and weld the new section in, and have all the holes line up for the radiator.
Cheers!!
SDC11407.jpg 137.68K 4 downloads
Posted 26 September 2010 - 09:33 PM
For those who have done this repair, is this the correct profile after you weld the rust repair section in?
SDC11413.jpg 122.9K 2 downloads
Does anyone have some pics handy of their rad support? I have nothing to work off and would really appreciate some visual help. Taaaa.
Edited by notna, 26 September 2010 - 09:33 PM.
Posted 26 September 2010 - 09:34 PM
#4 _nial8r_
Posted 27 September 2010 - 08:12 AM
hope that might help but if your really want the measurments i have a support hanging in my shed and can grab them for you if ya like ???
Posted 27 September 2010 - 10:48 AM
I do have my front apron that I can bolt on for positioning. Bonnet striker must be somewhere..... it was removed when I bought the car. It's probably in a box. Again, great idea, thank you.
Question Lee..... In the pic below, are the 2 areas circled in red both parallel to each other, and 90 degrees to the ground? Is this where the radiator bolts to?
IMGP3606.jpg 84.26K 3 downloads
#6 _nial8r_
Posted 27 September 2010 - 04:23 PM
the holes you have circled are the radiator bolt holes and the bottom tabs kick inwards a bit. about 5-10mm.
also the top and bottom hole arn't parallel, if you can make out the red lines in the photo, the line starts on the inside of the top hole and runs through the centre of the bottom hole and is the same on both sides. i hope that makes some sence, i also chucked in the measurment from the top to the bottom and its 380mm from the centre of the striker hole to the top of the lower section of the support.
#7 _LH SLR 3300_
Posted 27 September 2010 - 05:48 PM
Posted 29 September 2010 - 10:45 PM
#9 _nial8r_
Posted 30 September 2010 - 11:21 AM
Posted 01 October 2010 - 07:03 PM
#11 _LH SLR 3300_
Posted 01 October 2010 - 08:24 PM
Posted 02 October 2010 - 04:53 PM
I had been measuring heights and checking levels, but not in all the places you have mentioned. Will do ASAP. Cheers for your input.
You are welcome over anytime to eyeball it and advise some more.
#13 _nial8r_
Posted 02 October 2010 - 07:37 PM
Posted 16 October 2010 - 05:50 PM
Contemplating buying gassless MIG wire tomorrow just to get down and dirty!
As always.... will keep you posted of progress.
#15 _nial8r_
Posted 17 October 2010 - 05:53 PM
#16 _Kush_
Posted 18 October 2010 - 01:08 PM
im not a great fan of gasless migs, i just hope once you get it on it doesnt move on ya cause it would be a real bitch if you had to unpick it all again, then again your mig might be a lot better than mine as when i tried welding using gasless wire it didnt seem to get the penatration, anyways let us know how ya go
Did you reverse the polarity on your mig using gasless? Sometimes people overlook doing this.
#17 _nial8r_
Posted 18 October 2010 - 06:59 PM
Posted 18 October 2010 - 09:46 PM
