Converting to HQ
#1 _arsnic_apple_
Posted 30 September 2010 - 11:58 PM
Just wanted to know if hq drums are the same as torana but with the only
differance being the stud pattern. I have had my torana banjo anxles redrilled
in HQ stud pattern and now i need to change over my drums obviously.
Cheers Blake
Posted 01 October 2010 - 12:08 AM
Posted 01 October 2010 - 06:18 AM
Posted 01 October 2010 - 09:18 AM
This is going back a while now and never resolved the problem so I stand to be corrected.
Posted 01 October 2010 - 10:38 AM
1ARC LX Project
The HQ drums are a larger diameter 10". The LX drums are 9" however they protrude past the axle face further than the HQ drums.
I remember once trying to fit a set of Cheviot Hustler mags from a HG Monaro on my LX. They would not bolt up because the cast section of the brake drum on the LX protrudes past the axle face. This results in the spokes of the mags hitting the brake drum before the BUF touched the axle.
Article posted by dattoman.
Edited by ls2lxhatch, 01 October 2010 - 10:40 AM.
#6 _bunkerjest_
Posted 01 October 2010 - 07:21 PM
Posted 01 October 2010 - 10:46 PM
At least thats how I interpret it
He's got Torana brakes on the car still... but redone the axles to HQ for wheel choice
Now he wants a drum to suit
If thats the question
No you can't use the Q drum as its larger
And no theres not a drum that will do the job
So you'll have to get your originals redrilled to Q pattern or upgrade the brakes to the 10" Q ones
With corresponding changes to handbrake cables etc etc
Posted 02 October 2010 - 02:05 AM
You may find that a HQ pattern rim will not fit with LX drums. The rim needs to have a raised section that fits into the LX drum. If the HQ pattern rim fits with the LX drum then the simple option is to re-drill the LX drum. Just hold the LX drum up to the HQ rim and see if the rim clears the drum.
Edited by ls2lxhatch, 02 October 2010 - 02:20 AM.
Posted 02 October 2010 - 10:11 AM
He could have used a spacer like XU1's did to clear... just like my LH has on it to clear the wheels
Posted 02 October 2010 - 11:16 AM
#11 _arsnic_apple_
Posted 02 October 2010 - 11:17 AM
Went and got the drums redrilled yesterday ready to put on today
cheers Blake
Posted 03 October 2010 - 01:42 PM
Thoughts?
Posted 03 October 2010 - 02:03 PM
