LH wiring help
#1 _stcos85_
Posted 13 October 2010 - 04:45 PM
first issue is what I found above the gearbox tunnel. there are 2 purple wires and a light and darker green wire plus one orange wire that seems to go under the car. The purple wires have been badly looped back and none are connected anywhere but I think they go to a switch on the side of the gear selector. I have attached a few pics. can anyone confirm that these 4 wires go to the small switch in pic 2 and if so what terminals.
Also what does the orange one do?
the other issue I found is behind the tacho. there seems to be a wire missing, next to it it says brown but the only spare wire I found with the right connector in the area is a red wire. It has been fitted with an SLR dash at some point. All the rest is wired up and seems to have the correct wires. Does anyone know if I should be connecting the red wire.
If anyone can help me with these few issues it would be appreciated.
Posted 13 October 2010 - 05:06 PM
Just incase it blows up..... or something.
Red is usually +. & the brown wire is for the ?????? tacho??/?
I don't have a wiring diagram handy, so i'll chime out now.
#3 _JadeGreenLHSLR_
Posted 13 October 2010 - 07:08 PM
Waz
#4 _JadeGreenLHSLR_
Posted 13 October 2010 - 07:19 PM
Check this out, the purple is ur neutral safety starter switch, so thatl connect to the points on that switch that close when its in neutral.
Also try this http://peterpam.cust...t.au/lxwire.jpg
Edited by JadeGreenLHSLR, 13 October 2010 - 07:25 PM.
Posted 14 October 2010 - 06:49 AM
#6 _stcos85_
Posted 15 October 2010 - 07:18 PM
I checked the switch and it does seem to operate but when in park and reverse positions the same pins make the circuit. Its only when i put it in neutral it changes pins. I assume the positions are Park, reverse, neutral, drive etc. Only asking this as i haven't had it running yet. Still curious about why the purple wires were looped back. Could the switch be the wrong one as it does seem to only change when it goes to neutral.Yep, green ones are reverse light and purple ones are neutral safety switch, both of which are operated by the shifter. Put an ohmmeter on each pair of two pins on the shifter switch to see what positions they connect at - the reverse switch pair will only be connected in the reverse position, and the neutral safety switch pair will only be connected in park and neutral. Since the switch has been bypassed it may not have been operating correctly, could simply need adjusting or may need replacing.
Also any ifeas about the orange?
#7 _Tuflx8_
Posted 15 October 2010 - 07:22 PM
Posted 15 October 2010 - 08:19 PM
The purple wires are connected because otherwise the car won't start. The switch may be damaged if it doesn't operate correctly, they do wear out.Still curious about why the purple wires were looped back. Could the switch be the wrong one as it does seem to only change when it goes to neutral.
#9 _HRV8_
Posted 18 October 2010 - 01:40 AM
Regards.
#10 _stcos85_
Posted 18 October 2010 - 06:45 AM
