Posted 03 May 2006 - 08:11 PM
TORANR ARMORE - Yeah No worries mate, Line me up against it!!!!
In Dett - Mph was 101.5 or 163kph
ToranaZ - Here's the Specs of the donk, had a fair bit of help as im best mates with a machinist, so things were a lot cheaper..... I think it's a 205, It's not a 208 as that is .060 thou over, mine is only .030 thou over.
Blue 202 Block, Acid Dipped, Crack Tested, Bored 0.030", Decked 0.004".
Crank Ground, Polished
ACL Race Series Bearings and Moly Rings
Starfire Rods, Hypertek Flat Top HQ race pistons 0.030"
High Energy Sump
39/79 Solid Crow Cam and Lifters, Works from around 3500 - 7000
Crow Straight Cut timing Gear
VK Electronic Distributor
Stage 3 Blue Motor Yella Terra Head, Matchported, Polished and shaved 0.060"
ACL Race Series Copper Head Gasket
Yella Terra Roller Rockers 1:5 ratio
45mm Dellortos on matchported Redline manifold
Pacemaker Extractors, Matchported, into 2 1/2in exhaust with 3 inch sidepipe.
It runs on straight Avgas, But on the street I have to use premium so I have to take the timing back to 3 degrees to stop it pinging.
They were the Specs of the motor when it ran the 13.5 second 1/4. Sinces then I've added a few things as in a Yella Terra Steel Explosion Proof Lightened Flywheel, a Pro-Comp Multiple Spark Ignition Unit and Pro-Comp PC-91 Coil. I've also had the carbys tuned as they were way out when I raced it and have also picked up a set of 8 inch slicks for that traction problem so now i should be able to really stick it into it off the line.
Just wondering, Has anyone watched the Vid??? Does it work?
Les
