XU-1 diff codes and housing numbers
61 replies to this topic
#1 _Mike73_
_Mike73_
Posted 15 October 2010 - 12:58 AM
Hi to all,
I have the following Diff housing codes;
2.78 course normal DF 281072 1971 S model
3.36 course L/Slip WM 2823488 1972 XU-1
3.08 course normal DA 2809395 1970 XU-1 and LC & LJ GTR
3.08 course L/slip WM 2823388 1972 XU-1
2.78 course normal TF 2810717 1973 S model
3.36 Fine L/slip XM 9934111 14th Aug 73 on XU-1
I would like to know the numbers and codes for 3.08 and 2.78 fine spline as fitted to the 14th of August on, models and retro fitted to some others? Thanks
any help appreciated Mike
Edited by Mike73, 15 October 2010 - 01:00 AM.
#2 _Mike73_
_Mike73_
Posted 13 February 2012 - 03:43 PM
Further to this post I have now recieved information that a 3rd of August built XU-1 diff has a 4 G 3 date WM housing, when comparing this to my 16th of August XU-1 with a 9 G 3 XM assembly may indicate ( as long as the dates were in order ) that between the 3rd and 16th of August that the diffs changed from Course spline to fine spline.
This matches the break in production from the 9th to the 14th, with the 14th being the start of the final batch comming off the end of the production line.
Can anyone add to this finding?
Mike
#3 _Mike73_
_Mike73_
Posted 09 March 2012 - 06:05 PM
Mike
The diffs changed from WM code course spline ( 3.36 ), to XM code fine spline ( 3.36 ) by the diff stamped dates between the 4th and 9th of July 1973.
Mike
#4 _LOR-411_
_LOR-411_
Posted 14 August 2013 - 10:36 PM
Hi Mike, are you saying that an XU-1 completed on the 15th of July 1973 (my car) could have been fitted with a fine spline diff?
I ask this as I have a 3:36 fine spline LSD / baffled housing in my car at the moment - non-original. I say non-original as when I got my car it was a rolling shell with tags. So, the original running gear was changed out years ago but I managed to pick up a set of axles in 1989. I have often felt guilty about using the fine spline diff but hey, if it could have been fitted with a fine spline diff that would be great.
Thanks, Bruce
Edited by LOR-411, 14 August 2013 - 10:38 PM.
#5 S pack
  • 15,717 posts
Posted 14 August 2013 - 10:53 PM
Thanks, Bruce
Hi Bruce,
Mike is saying the fine spline rear axle assemblies were produced in July but weren't used in production until approx 1 month later ie: August.
Dave.
#6 _Mike73_
_Mike73_
Posted 29 September 2013 - 07:28 PM
Hello Mike here, been away from the site for a while.
There also seems to have been fine spline diff replacement componets available when pre Aug 73 XU-1's blew their diff, I know of at least one genuine original XU-1 with known history which had fine spline componets fitted by the dealer to his 1972 XU-1
In general production terms Dave is correct there was normally a lag time between the date of the diff  ( and other componets too ) to the vehicle production date.
There was also a lag time between the vehicle sales date for homologation purposes and the public sales date, but that is a whole different topic.
Mike
#7 jd lj
jd lj
  • 2,113 posts
  • Name:James D
  • Car:LJ SVO
Posted 18 March 2015 - 05:29 PM
I was under the Torana the other day and thought I'd look for the diff housing code while I was there. After a bit of scrubbing I found the code 2809_ _ TA. I've read this thread previously and was sure I hadn't seen any codes with TA in them. The last couple of numbers I couldn't make out at the time.
I believe that the diff housing isn't the original one for my car because I have a receipt from when the previous owner bought a diff housing while preparing the car for racing.
I know it has baffled axle tubes but don't know if these are original or not and it's currently running a 3.36 fine spline lsd.
While I'm at it does anyone know what would be the correct code for a 3.08 coarse spline lsd in a 7/73 lj s model.
JD
#8 _Nitter_
_Nitter_
Posted 18 March 2015 - 06:09 PM
This is from my late 71 xu1
  • Attached File  diff.jpg   94.58K   164 downloads
#9 jd lj
jd lj
  • 2,113 posts
  • Name:James D
  • Car:LJ SVO
Posted 28 April 2015 - 04:00 PM
Well my diff housing is out and the code appears to be "TA 280833 " and stamped with 17B3D. 17 Feb 73 I assume, but not sure what the D means.
Has anyone got a picture of original diff baffles? Mine has baffles but I don't know if they're original ones or not as I think the housing may not be the original one from my car due to previous track work and receipts I have from the previous owner.
Has anyone got the parts manual handy to check the diff housing code for a July 73, 3:08 coarse spline lsd.
Thanks in advance.
#10 S pack
  • 15,717 posts
Posted 28 April 2015 - 06:00 PM
James
You won't find those part numbers in a parts book. Those part numbers are for the complete rear axle assy as fitted on the production line.
Complete rear axle assemblies were not serviced as spare parts.
280833 will be for a std 6cyl 3.08 or 2.78 rear axle assy. I don't believe anyone has worked out what the D stands for yet.
Edited by S pack, 28 April 2015 - 06:01 PM.
#11 jd lj
jd lj
  • 2,113 posts
  • Name:James D
  • Car:LJ SVO
Posted 28 April 2015 - 06:33 PM
Thanks Dave,
It appears I did a typo, the code was meant to be 280933, does anyone know what the TA means.
Pictures of any factory baffles would be good too.
#12 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 28 April 2015 - 07:44 PM
Hi
I believe this is original
Bazza
#13 hanra
  • 10,967 posts
Posted 28 April 2015 - 09:55 PM
Baffles in my SL/R 5000 housing.
00000000-0000-0000-0000-000000006C5E_zps
#14 _SableMet7/73_
_SableMet7/73_
Posted 29 April 2015 - 02:15 PM
My 2823489 WM housing
Attached File  WM.JPG   302.12K   162 downloads
#15 crabba67
crabba67
  • 903 posts
  • Name:anthony
Posted 29 April 2015 - 02:54 PM
Jono,the diff stencil is 88 not 89.
cheersAttached File  xu1 diff mark.jpg   50.04K   157 downloads
#16 _Agent 34_
_Agent 34_
Posted 29 April 2015 - 07:30 PM
James - post a picture - I've built and put two sets in both of my diffs. given the age of your car for the track  the type of welding will determine  POSSIBLY when they were fitted - eg braze - electric arc.
this is not to say that someone " did not braze them in "
AFAIK - all the original houses / baffles were brazed ( oxy ) in.
Edited by Agent 34, 29 April 2015 - 07:31 PM.
#17 _tassietreasures_
_tassietreasures_
Posted 29 April 2015 - 09:24 PM
9th month 73 fine spline , all the best cheers
#18 _SableMet7/73_
_SableMet7/73_
Posted 29 April 2015 - 10:57 PM
OK, cant see the 1st & last numbers. Only have _82348_ WM left.
Got the 2823489 number from my Feb 72 parts cat for 3.36 XU housing.
Mines 19F3...D btw.
Thanx.
#19 crabba67
crabba67
  • 903 posts
  • Name:anthony
Posted 30 April 2015 - 12:35 AM
Thanks Jono,The part number is for assy as Dave explained eg: the lj gtr 3:08 diff/housing assy number in the parts catalogue is 2809465 the stencil is 2809395.
#20 crabba67
crabba67
  • 903 posts
  • Name:anthony
Posted 30 April 2015 - 12:38 AM
Hi James, the number you have on the diff housing maybe 2809395.
Thanks Dave,
Edited by crabba67, 30 April 2015 - 12:45 AM.
#21 jd lj
jd lj
  • 2,113 posts
  • Name:James D
  • Car:LJ SVO
Posted 30 April 2015 - 05:09 AM
Thanks for all the pictures and codes so far everyone.
I disassembled everything yesterday and they're definitely not factory baffles, it looks like it was someone's first attempt at welding.
Crabba, the code you listed (2809385), do you know what 2 letters go with it.
The first and last numbers on mine are very hard to read, so that code could very well be what's on there.
#22 crabba67
crabba67
  • 903 posts
  • Name:anthony
Posted 30 April 2015 - 10:34 AM
James, DA for 2:78/3:08 and i think DJ is 3:36/3:55
#23 crabba67
crabba67
  • 903 posts
  • Name:anthony
Posted 30 April 2015 - 10:44 AM
Also holden have XM for the fine spine diff on the broadcast sheets but the stencil is wx with no part number.
Edited by crabba67, 30 April 2015 - 10:54 AM.
#24 S pack
  • 15,717 posts
Posted 30 April 2015 - 04:03 PM
The white line below the letters is probably there to denote which way is up. So most likely the intent is to read the code as XM.
#25 jd lj
jd lj
  • 2,113 posts
  • Name:James D
  • Car:LJ SVO
Posted 30 April 2015 - 05:10 PM
That last picture also has the code on the passenger side and not the drivers side like all the others.
