* * * * * 1 votes
Lucky the lime green metalic GTR 1972
748 replies to this topic
#551 _Agent 34_
_Agent 34_
Posted 16 June 2013 - 05:52 PM
OK BRO's it's update # 102 - the little torrie threw a brake shoe !
dave - yep it's about right and i need to send this to them tomorrow
update
sorted the rares yellow plastic handbrake issues
sorted the brake booster - this was human error as you need a spacer behind the bracket  to put the booster on a different angle
put all the wiper arms and also wiper motor back
did the right hand side rear brake
found a new use for boogie boards
it's an old shitty grill not the right one, but could not help myself
1 more mill
Edited by Agent 34, 16 June 2013 - 05:53 PM.
#552 brocks72xu1
brocks72xu1
  • 731 posts
Posted 16 June 2013 - 07:30 PM
Looking good grant
#553 frash da bucket
frash da bucket
  • 1,890 posts
Posted 17 June 2013 - 12:32 PM
Hi Grant,
Your shoes are on back to front mate,
Leading shoe,short shoe facing the front of the car,
Trailing shoe,long shoe facing the back of the car mate.
Regards John.
#554 frash da bucket
frash da bucket
  • 1,890 posts
Posted 17 June 2013 - 01:20 PM
Hi Grant,
Your handbrake cables go in first,not last,
You need a second person,to help slide the cables though to underneath of the car to the handbrake handle,you have to fit the rubber boots on the cables first,the dust boots are left and right mate,put on a bit of grease on the ends to help slide through the rubber dust boots,and have your nuts ready 7/16 to put on the handbrake handle inside of the car.I have put new handbrake cables on my car coupla months ago.
Regards John.
#555 S pack
  • 15,722 posts
Posted 17 June 2013 - 05:22 PM
Grant, your fuel filler pipe is incorrect. The flange on the pipe sits behind the rear panel, inside the boot, not on the outside.
Love that wiper motor, so sexxxxxeeeeee.
Dave.
Edited by S pack, 17 June 2013 - 05:25 PM.
#556 _sunburst73-xu1_
_sunburst73-xu1_
Posted 17 June 2013 - 05:41 PM
Dave.
And there is a foam type gasket as well that go's between the filler pipe and panel.
Looking good mate.
#557 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 17 June 2013 - 06:37 PM
Hi
See below. The gasket is critical, otherwise water will sit permanently behind the boot catch area (and cause a rust hole like the one I had).
Bazza
#558 _Agent 34_
_Agent 34_
Posted 17 June 2013 - 06:54 PM
double bugger !
got the gasket but it's behind the filler - was wondering what was going on here as the screws were not working and also the tank connection rubber seemed to be short - will fix
John, read the manual and just threw them on last night, will re arrange now but the manual seemed to have the shoes shown like that.
nothing like doing a job twice ah ?
thanks gents, need all the training wheels i can get
1 mill back
Edited by Agent 34, 17 June 2013 - 06:55 PM.
#559 RallyRed
  • 8,147 posts
Posted 17 June 2013 - 07:57 PM
Hi Grant... real good,....and.....like a Toranafest possibility?
#560 S pack
  • 15,722 posts
Posted 17 June 2013 - 08:09 PM
double bugger !
1 mill back
Grant, John (Frash) is right about the brake shoes. Primary shoe has the shorter lining and always faces to the front of the vehicle.
Also as John said, get your h/brake cables installed as you need to connect them to the brake shoe actuating levers before you assemble the brakes.
#561 _Agent 34_
_Agent 34_
Posted 17 June 2013 - 08:18 PM
please GOD no more torana pain !
Let me move forward please please please, I won't do anything wrong again !
I just want to go to torana fest with a torana , three years with not torana is not fun anymore !
#562 hanra
  • 10,969 posts
Posted 17 June 2013 - 08:36 PM
I think I got mine the right way around. And yeah. hook them levers up first. It's fiddly work.
Edited by hanra, 17 June 2013 - 08:36 PM.
#563 frash da bucket
frash da bucket
  • 1,890 posts
Posted 19 June 2013 - 11:58 PM
Hi Brad,
Yourself adjusting mechanism on your backing plate,to adjust your brakes isn't right either,and missing a few bits.
Regards John.
#564 hanra
  • 10,969 posts
Posted 20 June 2013 - 04:29 AM
Well spotted, however ita an old photo. Just wanted to show the brake shoes.
#565 _mikecatts_
_mikecatts_
Posted 20 June 2013 - 07:39 AM
Looking good Grant.....
#566 hanra
  • 10,969 posts
Posted 20 June 2013 - 11:38 AM
Here's a later photo, sorry for the hijack Grant.
As per the book
#567 _Agent 34_
_Agent 34_
Posted 20 June 2013 - 06:19 PM
ERRR now I'm missing the things as John has said and also Brad has shown.
when i pulled the brakes  off the old 4 door,  parts these were not there ?
I assume that they can operate without them ?
Edited by Agent 34, 20 June 2013 - 06:20 PM.
#568 frash da bucket
frash da bucket
  • 1,890 posts
Posted 20 June 2013 - 07:10 PM
Hi Grant,
Yes they can operatate with out these mate,there only a automatic brake adjusters grant,that photo that you have put up is the os rear.I still have this set up in mine,god knows why did put them back in.
Your car would have had them too,but someone hasn't put them back into yours,my gtr had them, as the same as the xu-1.
Regarsd John.
#569 hanra
  • 10,969 posts
Posted 20 June 2013 - 07:25 PM
They only adjust the brakes ones the car is moving in reverse and brakes depressed if I am correct? I'm usually not though!!! Hahaha.
#570 frash da bucket
frash da bucket
  • 1,890 posts
Posted 20 June 2013 - 07:28 PM
Hi Brad,
Thank you for supplying the photo's,of you car and from the book,and your shoes are correct also,i have owned 2 LJ's,my gtr had it for 10 years and have had my xu-1 for 24 years,and have pulled both of them apart and put back together again over the years,i do know them inside and out.
Regards John.
#571 S pack
  • 15,722 posts
Posted 20 June 2013 - 07:33 PM
Correct Brad, the self adjusters only work when the brakes are applied whilst the vehicle is traveling in reverse.
If the self adjusters are removed you have to adjust the brakes manually at regular intervals.
#572 frash da bucket
frash da bucket
  • 1,890 posts
Posted 20 June 2013 - 07:35 PM
Hi Brad,
Yes handbrake only,when reversing,don't do it many times will over adjust and won't move forward at all,i have always adjusted them manually.
Regards John.
#573 S pack
  • 15,722 posts
Posted 20 June 2013 - 07:45 PM
Hi Brad,
Regards John.
Drum brake self adjusters have nothing to do with the hand brake John. They work when the brake pedal is depressed and the self adjusters cannot or should not over adjust the brakes to the point they are locked. Generally three brake applications in reverse is enough.
#574 frash da bucket
frash da bucket
  • 1,890 posts
Posted 20 June 2013 - 07:50 PM
It only works of the handbrake and not depressing the brake pedal,by pulling up the handbrake when reversing it adjusts them up.
Regards John.
#575 S pack
  • 15,722 posts
Posted 20 June 2013 - 08:13 PM
Regards John.
How then do the self adjusters work on front drum brakes?????
