* * * * * 1 votes
Lucky the lime green metalic GTR 1972
748 replies to this topic
#576 _Agent 34_
_Agent 34_
Posted 20 June 2013 - 09:16 PM
Dave,
you have to go forward ! LOL
#577 hanra
  • 10,980 posts
Posted 20 June 2013 - 09:45 PM
#578 S pack
  • 15,727 posts
Posted 21 June 2013 - 12:39 AM
^^^ Thanks Brad, you saved me the effort.
Dave.
#579 71Ranger
71Ranger
  • 267 posts
  • Name:Brian
  • Car:71 LC
Posted 21 June 2013 - 06:36 PM
Hi Grant,
Keep in mind that without the self adjusters you might get knocked at RWC time.
Brian
#580 xu2308
xu2308
    Grail Hunter
  • 4,704 posts
  • Name:AL
Posted 21 June 2013 - 09:07 PM
Hi
See below. The gasket is critical, otherwise water will sit permanently behind the boot catch area (and cause a rust hole like the one I had).
Bazza
Never knew they had a Gasket, who sells the gasket ????????
#581 frash da bucket
frash da bucket
  • 1,890 posts
Posted 22 June 2013 - 08:03 AM
Hi Dave,
You seem to be a expert in the mechanic's.
In my field of mechanics of 30 years or more,my field was,brakes,steering and suspension,and you believe what a book says to you.In theory the book is saying you use your depress foot pedal while reversing backwards.
On torana rear brakes its a little different,the handbrake leaver on the inside facing the backing plate,conects to the brake shoe,which on the other side is the automatic self adjuster,which works of the reaction arm, to the self adjuster,when appling the handbrake while going reversing backwards does adjust the brakes up.
Regards John.
#582 S pack
  • 15,727 posts
Posted 22 June 2013 - 08:35 AM
I see your point John, theoretically, either method will work for adjusting the rear brakes, however there is no need to use the handbrake as depressing the brake pedal performs the same operation with the benefit of the front brakes applying also.
God knows that when driving at speed in reverse you need every bit of braking effort you can get.
#583 _Agent 34_
_Agent 34_
Posted 25 June 2013 - 07:08 PM
Update #103 Another day another problem solved
OK so I found out in this tread http://www.gmh-toran...e-goes-through/ that you cannot get the rubber grommets for the heater cable.
so went to PLAN B - the local ford wrecker
Found these and they all fit like a glove - problem solved only they belong to a ford and not a Holden, they wreck everything else but Holden !
so if you need these grommets to put in your fire wall you can get them off a ford wrecker - DOH !
Not sure of which rubber style/ look is the correct look but if someone has a photo can they put up so I can get as close as possible.
#584 _BARRY JACKPOT_
_BARRY JACKPOT_
Posted 26 June 2013 - 05:30 AM
How long's this gunna take :)
#585 _Agent 34_
_Agent 34_
Posted 26 June 2013 - 06:10 AM
Chris,
  • I'm sort of stuck for the following reasons;
  • need to change the front  cross member
  • the engine builder has two race cars there
  • they have their own issues and i cannot get this hoist
  • the engine and drive line will go in as well when there
Apart from that, I've got no mates, three kids, babysitting the friends dog, building a yabby tank for nate, misses just went away on a five day holiday, don't have " reversing depress pedal " super duper brake rear  adjusters, my Man cave is rally cold this time of the year and before my missus went she gave me a list of SHIT five miles long that i have to do while she is gone !!
Apart from that, I'm fine !
But yesterday I - got that grommet  and that put a smile on my face !
Bro, I swear that If your not at Torana fest I'll see you at the nationals
#586 _LONA-CK_
_LONA-CK_
Posted 26 June 2013 - 07:10 AM
your a hard done by bloke you are, and a funny cxxt too.
just do what your doing mate and that rubber is not the right look mate, none of them are, i will go down the shed pull you one off one of my good fxxking heaters and post it to you from newcastle tomoz, call my tonight or better still send me you postal address to my phone 0433729059
cheers gong
Edited by LONA-CK, 26 June 2013 - 07:14 AM.
#587 _mikecatts_
_mikecatts_
Posted 26 June 2013 - 07:35 AM
Your a nice man John.... And Grant.. If you dont keep the missus happy, she wont let you play...
cheers gong
#588 S pack
  • 15,727 posts
Posted 26 June 2013 - 07:45 AM
cheers gong
John, I'm interested to find out if you can get the grommet off without tearing it, cutting it or cutting the cable and casing.
Dave.
#589 _LONA-CK_
_LONA-CK_
Posted 26 June 2013 - 08:01 AM
just being the shed and the only way i can do this quickly is by slitting the rubber or sending you the hole cable, so sorry mate your out of luck.
cheers gong
#590 _BARRY JACKPOT_
_BARRY JACKPOT_
Posted 26 June 2013 - 09:53 AM
Don't think Toranafest is gunna happen as there is a new project arriving at the farm today that's gunna keep me busy
#591 _2ELCS_
_2ELCS_
Posted 26 June 2013 - 10:34 AM
Clark rubber could be your friend Grant?
#592 S pack
  • 15,727 posts
Posted 26 June 2013 - 05:33 PM
Clark Rubber wiring grommets.
http://www.clarkrubb...ng-grommet.html
#593 _Agent 34_
_Agent 34_
Posted 26 June 2013 - 07:51 PM
Wayne - do they sell frangas as well as the chemist ?
thanks guys, off to clarke rubber for a few frangas !
will report back on this tomorrow on my franga pack
#594 _Agent 34_
_Agent 34_
Posted 29 June 2013 - 08:34 PM
I prayed to the heater box gods before i started.
It's all over !
another mill
got the yabby tank done - all named ;
harry
peter
Ian
they are known as the Yabby Dealer Team " YDT" LOL
Edited by Agent 34, 29 June 2013 - 08:36 PM.
#595 _BARRY JACKPOT_
_BARRY JACKPOT_
Posted 29 June 2013 - 08:46 PM
Looks awesome.
#596 S pack
  • 15,727 posts
Posted 01 July 2013 - 08:53 PM
Hey Grant, are you still looking for the drum brake self adjusters? There's a set on evilbay ATM.
http://www.ebay.com....=item2ec8d560d8
#597 hanra
  • 10,980 posts
Posted 01 July 2013 - 09:16 PM
Nice spot Dave!
#598 _Agent 34_
_Agent 34_
Posted 02 July 2013 - 07:58 PM
Right NO ONE F@#%#KEN bid on this RIGHT !    It's MIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIINNNNNNNNNNNNNNNNNNNNNEEEEEEEEEEEEEEEEEEEEEEE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
thanks Dave I'm on at a 1.25
It's sort of round the corner as well.
Ps; I will just feel a lot more comfortable when I " depress the brake pedal in reverse knowing that my brakes will be self adjusted " , AHHH modern technology, cannot get that in a modern car
Edited by Agent 34, 02 July 2013 - 08:02 PM.
#599 71Ranger
71Ranger
  • 267 posts
  • Name:Brian
  • Car:71 LC
Posted 12 July 2013 - 06:27 PM
Hi Grant,
Whats the latest, Im getting withdrawal symptoms
#600 hanra
  • 10,980 posts
Posted 12 July 2013 - 06:59 PM
$11.30 they sold for!!! Nice score!!!!
