Quick questions. Rear main seal
8 replies to this topic
#1 rodomo
  • 18,031 posts
Posted 22 November 2010 - 08:00 PM
Did early reds (149,161,179,186) all have rope seals?
Was the neoprene seal introduced with 173 & 202?
Am I correct that 173 and 202 had both at different stages?
Edited by rodomo, 22 November 2010 - 08:04 PM.
#2 _judgelj_
_judgelj_
Posted 22 November 2010 - 08:57 PM
i think it was the early reds that had the rubber seal similar to rope. then neoprene was introduced later on, with the rope being available in some red 202's from the hq. maybe someone can add to this?
#3 rodomo
  • 18,031 posts
Posted 22 November 2010 - 09:40 PM
#4 _judgelj_
_judgelj_
Posted 22 November 2010 - 11:16 PM
are they both red 202's? the one on the right is probably a hq motor
#5 S pack
  • 15,689 posts
Posted 23 November 2010 - 12:26 AM
Hi Rob,
AFAIK the 138,149,161,179,186 have rope rear main oil seals. The LC workshop manual describes how to replace the Rope oil seal. All Rope seal crankshafts have the hatching around the seal journal.
I can't say with any certainty if early 173 and 202 had rope seals, I thought they always used a Neoprene seal.
There is more than one type of neoprene seal. Additional to the one in your pic, GMH also used a neoprene seal that fitted into a groove similar to that for a rope seal and I have also read about a double lip neoprene seal being tested in service.
In 1973 GMH engineering department also experimented with a run of 25,000 engines comprising of 6cyl & V8's utilising a rear main oil seal made from Chicago Rawhide.
It seems that eventually GMH reverted back to the rope seal for the blue and black motors and possibly before the red motor was discontinued.
Dave
#6 yel327
  • 13,598 posts
Posted 23 November 2010 - 04:46 AM
Rope started around mid-late HQ. From then onwards all red, blue, black 6cyl, 253 and 304/308 were rope seal. Of all the earlier 6cyl engines I have ever played with (EH-HG) they have all been neoprene. Early 253 and 308 from HT release were also neoprene.
#7 rodomo
  • 18,031 posts
Posted 23 November 2010 - 03:50 PM
Yes, I remember that seal that replaced the rope. 1st wifeys HQ had that. We had to change the crank because of the soft thrust face. (Manual)
I don't have a pic though.
Bit of a balls up really if you look at the big picture. They should have just modded the flywheel flange and the block to accept a 1 piece seal.
#8 TerrA LX
Posted 24 November 2010 - 09:57 AM
Looks like some wicked wear on the neo seal you have pictured.
#9 _budd_
_budd_
Posted 12 November 2017 - 12:39 PM
is there a modification to rope seal rear mains for the 202s
