1974 LH TORANA RESTORATION
#101
_Kush_
Posted 19 June 2011 - 05:49 PM
#102
Posted 19 June 2011 - 05:59 PM
_TUFF75LH355_
Posted 19 June 2011 - 07:00 PM
#104
_nial8r_
Posted 19 June 2011 - 07:49 PM
#105
Posted 19 June 2011 - 08:21 PM
#106
Posted 19 June 2011 - 09:14 PM
#107
_LH SLR 3300_
Posted 19 June 2011 - 09:35 PM
#108
_LH SLR 3300_
Posted 26 June 2011 - 06:19 PM
Put the original disc rotors on so i could take the car off the chassis stands & get it rolling again, pushed it out of the carport for the first time in almost three months.
With help from my Mrs, fitted the engine & headers. Went in without too many dramas & spent the rest of the weekend fitting up the bits needed to make it run.
Pretty happy to go from this.
To this in just under three months.
#109
Posted 26 June 2011 - 06:31 PM
What prep did you give the items that you sent for zinc plating,and who did you use?
Ive seen different levels of success with zinc and cad plating,Ive never been sure if its the prep work or the plating process.
Ive seen it peel off on occasion,which just isnt right...
Are you 100% happy with the finish and service provided by your guy?
I personally think its better than chrome in many applications,and have a bunch of stuff here I want to get done.
I just need a good provider.
Cheers,Craig.
#110
_LH SLR 3300_
Posted 26 June 2011 - 06:43 PM
Some of the items i had plated were in good condition so didn't really need any prep work, those that did i degreased & cleaned off any surface rust, paint etc. It's like any part you recondition, the better the prep work, the better the end result. I used All Metal Bumpers in Ingleburn. The plater only had problems with three of the brake lines for some reason, first couple of goes, the finish did have a blistering/poor adhesion issue, but he got them right in the end & overall his service, price & the quality of his work is excellent & i'd recommend him to anyone. For what my plans are with this car, chrome plating was never an option & i'm pretty happy with how it's turned out so far & i have some more parts to go on the car i think you'll appreciate to. Cheers Matt
#111
_nial8r_
Posted 26 June 2011 - 07:00 PM
will the extractors cause any heat problems to the oil temp as they look like they run pretty close to the R/H side or is it just camera angle ? and what brake set up are you going with on this one, same as the Orchid LH ? keep up the good work mate and keep the pic's coming
#112
_LH SLR 3300_
Posted 26 June 2011 - 07:17 PM
The headers do come close to the windage tray sump but don't actualy touch so i think it'll be OK. I almost considered having them ceramic coated to cut the heat down but decided not to. This car will have the same brakes as the Orchid car, i was planning on fitting HQ brakes but by the time i bought the conversion kit, discs, second calipers & recoed them it was easier & almost as cost effective to buy the larger brake kit. I also considered recoing the original brakes, but with the power the engine makes, the car would've been badly under braked so that idea was scraped fairly quick. Cheers Matt
#113
_mick74lh_
Posted 26 June 2011 - 10:34 PM
#114
Posted 27 June 2011 - 10:01 AM
So do we call your project a "rolling resto"? If so, then it's the most detailed one I have seen.
Can I ask a question....? For a full front end rebuild, as you have done and I too am just about to do, is there a full list of parts available, or a rebuild kit of sorts? I need to do all the bushes as a start, including those that fit the rear of the subframe. Taaaa.
#115
_LH SLR 3300_
Posted 27 June 2011 - 05:18 PM
#116
_2ELCS_
Posted 27 June 2011 - 06:45 PM
Wayne
#117
Posted 27 June 2011 - 08:32 PM
#118
_TUFF75LH355_
Posted 27 June 2011 - 09:39 PM
#119
_LH SLR 3300_
Posted 27 June 2011 - 09:46 PM
#120
_LH SLR 3300_
Posted 02 July 2011 - 06:40 PM
As i'm trying to make this car appear as factory original as possible, i didn't want use nuts,bolts & large washers to fit the bucket seats i have, so i cut some floor sections with the appropriate captive nuts & reinforcing plates that a forum member kindly donated from a rusted wreck. Then i unpicked the plates from the old bits of floorpan, cleaned them up, applied a weld thru primer.
Then i trial fitted the seats marking the floorpan where the holes for the captive nuts needed to be, then measuring & checking that they were exactly where they needed to be before drilling the holes. I placed the old floor sections from the donor car in place & they confirmed my measurements were OK.
Using the original seat bolts & a jack with a block of wood to position the plates against the floorpan, i plug welded the rear most plates in. As the front of the seats bolt onto a box section of the floorpan, i had to cut that section out, weld the plate to it & re-weld it back in.
One side welded in & finished off in primer.
I was starting to run out of daylight, so i tacked the other side in & called it a day. Tomorrow i'll finish welding & clean up some surface rust on the floor before sealing & painting both sides. Bolted the seats in to satisfy my own curiousity & they fitted perfectly confirming all my earlier measurements & trial fitting were OK.
#121
_Liam_
Posted 03 July 2011 - 09:55 AM
Yours looks much better lol.
#122
_LH SLR 3300_
Posted 03 July 2011 - 12:06 PM
#123
Posted 03 July 2011 - 03:53 PM
You could probably make a nice living doing this sort of work.
Cheers Mick.
#124
Posted 03 July 2011 - 04:32 PM
#125
_LH SLR 3300_
Posted 03 July 2011 - 05:53 PM
Fitted the seats & carpet, may try & fit the B&M shifter during the week.
