Dirtbags dream car rebuild! HK monaro!
#276
_A9XOSS_
Posted 12 June 2011 - 05:57 PM
#277
_Quagmire_
Posted 12 June 2011 - 11:50 PM
Seen the price of thick wall RHS lately? Plus, who has the time for that??? I'm behind enough as it is!!!!
put bomber on the job if he makes it down
make a change from grabbing cuppas and changing cd's/maccas runs
#278
_dirtbag_
Posted 15 June 2011 - 08:35 AM
I'm just using an oxy to do the main welding.
The wheelarch is fully welded now which is good.
#279
Posted 15 June 2011 - 09:51 AM
#280
_dirtbag_
Posted 15 June 2011 - 03:49 PM
#281
_Viper_
Posted 15 June 2011 - 04:48 PM
#282
_dirtbag_
Posted 15 June 2011 - 05:32 PM
#283
_jabba_
Posted 15 June 2011 - 06:23 PM
#284
_dirtbag_
Posted 17 June 2011 - 06:07 PM
I need to fix a dent on the front of the radiator support panel, so figured bolting the engine bay back on would be the best way to do the repair and be certain the engine bay will keep it's shape.
Once I put the engine bay back on I moved the car so I could get it onto the hoist.
Here's the yummy crap I'd been sweeping under the car : )
It's good to see it in a different position.
I lowered the front too hahaha.
It was a struggle but I finally got it into position to get on the hoist.
Here's the dent I need to fix.
Have I mentioned how much I love my hoist?
I got to get a good look at the rear valance. It's pretty stuffed but the owner supplied a rare spares replacement. Yay!
There's a tiny bit of rust on the inside too, so I'll fix these bits when I cut the outer panel off.
The floors look perfect though.
Inside the plenum is perfect too. Apart from some dodgy repairs and usual rust this is a really good shell. It could be a LOT worse.
Having it in the air will make it a lot easier to fully weld the lower parts of the new rear guard too.
I'll get back into the fun stuff next week.
#285
_Viper_
Posted 17 June 2011 - 06:52 PM
Looking at the pic I got no idea where I would even start? except maybe put a bolt in that hole and try pull it out?
#286
_dirtbag_
Posted 17 June 2011 - 07:06 PM
#287
_Ozzie Picker_
Posted 18 June 2011 - 08:36 AM
your doing excellent work,there arn,t to many people anymore that have the experience,and patiance to do this kind of work.
hope you do this for a long time,as many people need someone with your skill to restore basket cases.
#288
_Quagmire_
Posted 18 June 2011 - 02:22 PM
so that if he goes into the great unknown his legacy can live on
now who would like to offer thier first born?
#289
_Squarepants_
Posted 18 June 2011 - 07:46 PM
Me and DB...
#290
Posted 18 June 2011 - 08:15 PM
Henrob 2000 "should" reduce the chance of warpage compared to the normal oxy. But when you're as good as Dirtbag a normal oxy will suffice.Is it hard to not warp the panel with oxy? Can you do a whole line at a time or small stiches then move onto another spot?
Did you use normal filler rod or mig wire with oxy??The panel will distort to a certain extent as you're welding, but as it cools it will shrink again. I move around the panel as much as I can to spread the heat evenly, and not get big hot spots. It depends on how big an area you're welding. Even if the weld distorts really badly, you can just use the oxy on the weld to shrink it back in. Or if it needs stretching you can stretch it with a hammer and dolly. It's good to hammer and dolly the welds flat anyway.
#291
_dirtbag_
Posted 18 June 2011 - 10:23 PM
For filler wire I just use mild steel wire. That way there is nothing in the weld but mild steel, meaning panel beating/shrinking/stretching is as easy as a panel without a weld through it.
#292
Posted 19 June 2011 - 11:35 AM
You mean uncoated mild steel wire?I've tried a henrob before and wasn't taken by it. Having said that I know a few people who swear by them so to each their own : )
#293
_dirtbag_
Posted 19 June 2011 - 11:45 AM
#294
_judgelj_
Posted 19 June 2011 - 02:26 PM
#295
_dirtbag_
Posted 19 June 2011 - 03:11 PM
#296
_judgelj_
Posted 19 June 2011 - 04:35 PM
#297
Posted 19 June 2011 - 04:51 PM
#299
Posted 19 June 2011 - 10:09 PM
Thanks mateYep. It goes rusty when not being used so I usually cut about 2 foot off at a time and sand the surface rust off it with 120 then it's good to go. Cheap too.
#300
_mick74lh_
Posted 21 June 2011 - 08:56 PM
my uncle used to have an old fridge with just a small light bulb in it to place things to prevent rust
Please excuse my stupidity if theres an obvious answer but how does a fridge with a small light in it prevent stuff from rusting? Surely there would be oxygen inside the fridge?
