Dirtbags dream car rebuild! HK monaro!
416 replies to this topic
#401 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 07 May 2012 - 09:27 AM
i agree about the shaft carrier craig, looks like itwas made in a year 9 metalwork class. even folding up some sort of cover for it would probably be an improvement i reckon.
#402 _berro59_
_berro59_
Posted 08 May 2012 - 10:22 PM
Nice work as alway Dirtbag!
Youre a God!
Cant wat to get my ht monaro underway!
#403 _dirtbag_
_dirtbag_
Posted 16 May 2012 - 07:08 AM
Thanks berro, but you spelt jerkoff wrong, you accidentally wrote God : )
Well I did a little bit more last week to the steering.
I'd love to be able to reconfigure it so it isn't using that ugly bearing and it's mount, but the kit is engineered this way so it needs to stay. I'll see how it looks with the motor and pipes in and if it's too visible I'll make a cover like what stinga said.
Anyway, I couldn't find a reamer short enough to run through the unis, and the unis aren't able to be pulled apart without killing them so I ended up taking a tiny amount off the shaft. The hole in the uni is 14.3mm and the shaft was 14.32mm so it wasn't much but enough to be a nuicance.
Once I'd cut the first piece of shaft to length I tested it to make sure it fit properly, then I chucked it into my incredibly massive industrial mill to cut in the flat spots for the cotter pins.
I'll show you just how massive this mill is. It's so big I nearly need both hands to carry it!!! hahahaha! It's very handy though!
So one shaft is now done. Hooray : )
To determine the length of the second shaft I first had to get a uni onto the end of the steering column. I had no idea how hard it was going to be to get the shaft out of the column, but when tapping the steering wheel off the spline the whole shaft came out with it. Sweet! I like it when every now and then something is easy!!!
So I machined the end of the column down and milled the flat spot in.
I gave it a quick sand and coat of black while it was out as it was a bit surface rusty.
Now I can measure the second shaft.
Ready to go in.
All done.
So it wasn't the hardest thing in the world to do, but it was more involved than I'd have thought a "kit" would be. Anyway, it's done now so time to move onto something else : )
Edited by dirtbag, 16 May 2012 - 07:11 AM.
#404 76lxhatch
  • 7,205 posts
Posted 16 May 2012 - 11:13 AM
I think the issue of how the bracket looks kind of disappears when you look at 3 unis plus a bearing...! I'm sure it will work nice though, function over form
Coming along well
#405 SHEEL
SHEEL
  • 340 posts
  • Name:Daniel
Posted 16 May 2012 - 11:33 AM
yeh agreed, also looks like it's taking up a lot of space when it comes time to run some pipes...should be interesting!
this is my favourite of your projects, along with the monza. I always come straight into the non-torana project area looking for Dirtbag updates!!!
#406 _dirtbag_
_dirtbag_
Posted 16 May 2012 - 01:39 PM
Yeah it's certainly not ideal but it's legal so that's the price you pay I guess : )
#407 _Viper_
_Viper_
Posted 12 June 2012 - 10:37 AM
Hey Tim, what's your final thoughts on the steering kit? Would you buy the same one again or is there something better?
Friend has a HT we are considering converting. So we will have to modify the shafts the same as you have?
#408 _dirtbag_
_dirtbag_
Posted 12 June 2012 - 04:04 PM
Hi Clint. Look, cosmetically there's lots of things I'd have done differently, but at the end of the day it's ADR approved and can be easily regoed as it is now.
It does feel pretty good through the steering wheel though.
#409 axistr
axistr
  • 1,209 posts
Posted 12 June 2012 - 06:06 PM
G'day Tim,
If you find that the steering wheel feels a little tight then loose through 360 deg under load put the unis out of phase by 45 deg. With steering shafts that run through angles more than 10 deg this can often happen.
Nice work mate , well done.
#410 5752cc
5752cc
  • 29 posts
  • Name:Paul
  • Car:Glacier white LJ
Posted 19 June 2012 - 11:29 PM
Hi Tim
Like others I'm amazed at what you are doing with this and the Monza & even better, taking the time to put up the pics and give advice & ideas.
I thought you might be interested in the following link. Its from the South African Muscle Car forum & although a Dodge you will probably appreciate the work (and time) that has gone into it
http://www.africanmu...hp?f=23&t=11164
Paul
#411 _mick74lh_
_mick74lh_
Posted 19 June 2012 - 11:45 PM
Hi Tim
Paul
Just had a look at that link. What an awesome forum! I'll definitely be going back for more of a look in the future.
#412 _dirtbag_
_dirtbag_
Posted 27 March 2014 - 05:33 PM
It's been a long time since I've posted in here! Not a stack has been done but some has been none the less. The lower parts of the front guards were stuffed inside and out so they're all replaced, and all the panel gaps are set now.
The biggest changes are things you don't really see. It's getting monster power, so I'm adding 2 sets of extra rails underneath, plus a half cage as Qld no longer allows full cages (pansies!!!) and by keeping it a basic 4 point the rear seat can stay. I've also mini tubbed it so it can sit nice and low and swallow a big fat tyre without scrubbing.
I narrowed the original banjo 2 1/2 inches each side just so I could make sure it was all going to fit in as I wanted it to. I'm happy with how much room the tyre has now.
The wheel and tyre in this pic are stock HK centre in an 8 inch rim with a 245 tyre, and there's heaps of clearance. I haven't even rolled the guard yet : )
The outer rails are just to support the inner sills and the inner rails join the front and rear suspension.
#413 _judgelj_
_judgelj_
Posted 27 March 2014 - 05:41 PM
wow
#414 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 27 March 2014 - 05:57 PM
Its nice to see some pretty wheeltubs instead of the ones that look like a bit of duct work that seem so popular.
#415 _dirtbag_
_dirtbag_
Posted 27 March 2014 - 06:48 PM
The front guards were pretty crusty.
The parcel shelf was pretty hacked as well.
I made the tubs higher than standard as well as wider so the wheel can go right up in there : )
#416 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Car:Goon
Posted 27 March 2014 - 08:45 PM
Nice.
Time to rip that front x member out again and channel it into the rails.  :)
#417 Ice
  • 15,198 posts
Posted 27 March 2014 - 09:45 PM
Nice ride height tim
4 user(s) are reading this topic
0 members, 4 guests, 0 anonymous users
