Dirtbags dream car rebuild! HK monaro!
416 replies to this topic
#176 _DomDom_
_DomDom_
Posted 11 May 2011 - 07:24 PM
Whatcha doin with the rear "perfectly straight" part of the guard? will you replace the part above the wheel arch only?
Dom
#177 _shadowmaster_
_shadowmaster_
Posted 11 May 2011 - 07:26 PM
Well done Tim... Did you make the half lower quarter as well as the top piece or just the top ? if you made the bottom as well then thats a hell of an accomplishment.
#178 _DomDom_
_DomDom_
OOOPS. Forgot to say how awesome the job is. Just goes to show that we expect that you know how good you are by now.
Dom
Edited by DomDom, 11 May 2011 - 07:29 PM.
#179 GML-31
Posted 11 May 2011 - 07:49 PM
all bought replacement panels outside, tim fabricated the inner wheel arch
Edited by GML-31, 11 May 2011 - 07:51 PM.
#180 _dirtbag_
_dirtbag_
Posted 11 May 2011 - 08:10 PM
I was planning on doing that, but was put onto rare spares who supplied all the new outer rust repairs I needed. Yay rare spares : )
Having said that, the lower piece wouldn't have been too hard to make, but replacement panels are cheaper and easier hehehe.
Edited by dirtbag, 11 May 2011 - 08:12 PM.
#181 rodomo
  • 18,035 posts
Posted 11 May 2011 - 08:48 PM
Yay rare spares : )
Good on you! It's easier to "tweek" a Rare's bit than to try and fab one.............even though you've got the gear. :spoton:
#182 _dirtbag_
_dirtbag_
Posted 11 May 2011 - 09:26 PM
Yeah, if it were my car (I wish!!!!) I'd have made it myself, as I'm not paying for my time, but in this case it would have been cheaper to go with the rare spares pieces, so we did : )
#183 _mick74lh_
_mick74lh_
Posted 12 May 2011 - 11:56 AM
Wow thats like watching a magician
#184 _dirtbag_
_dirtbag_
Posted 12 May 2011 - 06:14 PM
A retarded magician : )
#185 _red roar_
_red roar_
Posted 12 May 2011 - 08:05 PM
I wish i was just as retarded......
Hey D/Bag, have you got any more pics of the green hatch, from one of your other threads, i looked but couldnt find it. From memory you said it was your mate's car? ( i need to drool some more)
#186 _dirtbag_
_dirtbag_
Posted 12 May 2011 - 08:32 PM
Hi Trevor. I found one pic. I'd have to go through my cd's to find others.
Here's some of the pics from my brothers hatch build thread.
Enjoy : )
#187 its Paul
its Paul
    Formerly lx8vd77
  • 1,577 posts
  • Name:Paul
  • Car:LXSS, VUSS, VESSv & the mighty HB
Posted 12 May 2011 - 08:42 PM
How good do those bumpers look, hay Tim.
#188 _red roar_
_red roar_
Posted 12 May 2011 - 09:34 PM
Cheers Tim, thats the one...
i knew it was in that thread "somewhere", i just havnt got the three days it takes to get through it. lol
That's got a chev ?
#189 _dirtbag_
_dirtbag_
Posted 13 May 2011 - 12:13 AM
Yeah, it's a 383 with well over 450hp at the wheels. 4 speed muncie and spooled 9 inch. 15x10 front and 15x12 rear welds. Cool car.
Just needs chrome bumpers and door handles : )
#190 _SnotGobbler_
_SnotGobbler_
Posted 15 May 2011 - 10:33 AM
nice rebuild, just gorked through most of it
i have a ques... you cover the bare metal with rust convertor. what do you do after that to remove the rust convertor?
at a guess you sand it off back to bare metal, then if surface rust still present, repeat process with rust convertor until all gone?
sanding with a block by hand or the grinder and with what grit approx? then cover with primer?
thanks heaps.. need to know for and idea of what to do when i get around to my torana doors
#191 _dirtbag_
_dirtbag_
Posted 15 May 2011 - 02:38 PM
Hey snot : ) The rust converter I use doesn't have to be totally removed. Once I'm happy with the colour the metal has turned after rust converting and the converter is dry I just dry sand it with 120 grit paper to get the loose bits off and to key the surface for the 2 pac epoxy etch primer.
I hope that helps.
Oh, in regards to there still being rust on the metal like this car had, I sand the bad bits with 36 grit discs on a grinder and reapply the rust converter.
#192 _dirtbag_
_dirtbag_
Posted 15 May 2011 - 02:41 PM
Sorry Dom I didn't answer your question. I'll probably end up fabricating a piece to replace the really pitted part over the wheel arch. I"ll have a bash at it first, but it looks like it might be easier to replace it.
#193 _DomDom_
_DomDom_
Posted 15 May 2011 - 07:39 PM
Thanks Tim.
It looks very compounded, curves and flats, how does one make a panel like that. Better give us lots of pictures. ;-)
Dom
#194 _dirtbag_
_dirtbag_
Posted 17 May 2011 - 07:17 PM
Hey Dom. Well I had a bit of a look at the rear guard today. It's pretty ordinary so I thought I'd have a go at making a new piece.
I stuck some wax paper over the panel so I could draw on the outline to get a rough template for tracing onto steel.
I don't have the skills of Tom Peach to make an entire quarter from scratch, so will be leaving the bits that are still in good nick in place, such as the tail light surround.
With the paper cut to shape I taped it onto some 1.2mm zinc and traced it out.
This next shot shows some thick black texta lines through the middle of the panel. One is for where the crease is that runs down the side of the guard, the other is for the lower crease/step.
The reason for the texta lines is I used a pounce wheel to perforate the paper, so when I coloured over it the texta goes through the holes and marks the steel.
Once I cut the piece out, I stuck the template on the other side of the panel so I could mark the slight swage line that I need to fold. I have to fold it from the back side, that's why I'm having to do this.
Then I put the fold in. Now it looks like this. Note I haven't trimmed the bottom of the new piece yet. I'll do that when I'm happy with how the rest of it fits.
I then started running it through the english wheel. I started with a fairly flat bottom wheel as I don't want to put too much crown into the panel.
I also started hammering out the flare. It needs to come out further, as it's holding the panel away from the car at the moment, but I'd rather not go far enough with it than too far. It's easier to keep going than it is to undo.
Well that's all I got done to this one today, but it's a start.
Edited by dirtbag, 17 May 2011 - 07:19 PM.
#195 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 17 May 2011 - 07:28 PM
I am frOckin impressed,DB.
#196 Neils LX
Neils LX
  • 2,074 posts
  • Name:a
Awesome work dirtbag, you could make a monaro panel by panel.
#197 _dirtbag_
_dirtbag_
Posted 17 May 2011 - 07:32 PM
hehehe. It's the only way I'll ever afford one, that's for sure : (
#198 lxsstorana
lxsstorana
  • 2,499 posts
  • Car:SS Hatchback
Posted 17 May 2011 - 07:36 PM
Add me to the list and the rest of the forum members.
Great work! :spoton:
#199 _Quagmire_
_Quagmire_
Posted 17 May 2011 - 07:40 PM
anyone good at fibreglassing?
i can see a big $$$ spinner in that :)
#200 _mick74lh_
_mick74lh_
Posted 17 May 2011 - 08:49 PM
Awesome. Nice 'how to' so far. Very clear
