Am getting a friend to convert ( at a specialist engineering firm ) some 14x8 HQ GTS rims to 15x10 and 15x9 for me, to fit an A9X.
Dose someone have the correct back space/off set for these style of rims to suit above car.
Thanks, Merry Xmas and a Happy New Year.
Back Space HQ GTS Rims for an A9X
_walkinshaw_
, Dec 26 2010 08:25 PM
8 replies to this topic
_walkinshaw_
Posted 26 December 2010 - 08:25 PM
_cruiza_
Posted 26 December 2010 - 10:01 PM
same as HQ worked for me
_CHOPPER_
Posted 27 December 2010 - 02:13 PM
14x6 HQ rims: +13 offset
14x6 A9X rims: -6 offset.
Basically the A9X rims stuck out an extra 3/4" each side than an HQ rim.
Posted 27 December 2010 - 03:39 PM
I've got modified GTS wheels on my hatch.
15 x 8 on the front (4.5" backspace) and 15 x 10 on the rear (5.5" backspace).
I didn't build them but bought them off a forum member who had them made. Obviously your diff and any other modifications to your car will come into play.
Anyway, here's a couple of photo's.
torana 383 037.jpg 242.33K
18 downloads
torana 383 039.jpg 228.3K
13 downloads
torana 383 045.jpg 242.25K
13 downloads
Posted 27 December 2010 - 04:01 PM
I forgot to mention I wouldn't go 15 x 9 on the front. I think it will be too wide.
My first preference would be 15 x 7, next 15 x 8 on the fronts.
_JBM_
Posted 27 December 2010 - 08:47 PM
I had 14X8 all round on my L34.
Stock offset GTS rims were too far inward with the flares and looked stupid, even with the extra 20 mm it would be silly.
If youre changing the rim width the amount of factory back space wont really help.
You should measure how much clearance you have and set the back space from that.
James
James
_cruiza_
Posted 27 December 2010 - 09:19 PM
My car had A9X style front end HQ stub axles and vented discs with HQ off set rims 14 by 7 on front and 14 by 8 on rear front tire 225 60 rear 245 50 back could have been wider but I never had any problems with tires rubbing or catching and full suspension travel
Posted 28 December 2010 - 04:20 PM
On a 8" rim 4.5" backspace or 0 offset is perfect.
On a 9" rim I wouldn't go any more than 5" on a standard diff width as tyre clearance on the inside may become a problem if it has a large rolling diameter.
Mark
Mark
_CHOPPER_
Posted 28 December 2010 - 10:09 PM
For those of you who are interested, it is cheaper to get a 15x10 made rather than a 15x9. This is because they take a 10" wide outer and narrow it to 9".I forgot to mention I wouldn't go 15 x 9 on the front. I think it will be too wide.
