uc disc brake rear end
_benster208_
Posted 29 December 2010 - 06:32 PM
_CHOPPER_
Posted 29 December 2010 - 07:33 PM
_benster208_
Posted 29 December 2010 - 08:13 PM
The distance between the axle face where the disc sits to the end of the splines is different between disc and drum brake axles by the thickness of the disc.
yeah but the thickness of the disc where it sits onto the axle is only a few mills different than a drum brake. isnt that why the disc axles have a spacer behind the bearing?
_CHOPPER_
Posted 30 December 2010 - 08:39 PM
Posted 16 January 2011 - 03:30 PM
_CHOPPER_
Posted 16 January 2011 - 08:42 PM
Posted 16 January 2011 - 08:56 PM
Edited by Steve TPF, 16 January 2011 - 09:00 PM.
_CHOPPER_
Posted 16 January 2011 - 09:46 PM
Posted 17 January 2011 - 05:22 AM
_CHOPPER_
Posted 17 January 2011 - 10:45 AM
Let's face it. GMH was such a tight arse back then if they could get away with using the same axle for disc and drum brake diffs, they would.
_benster208_
Posted 17 January 2011 - 02:24 PM
Posted 17 January 2011 - 04:42 PM
Your only real option is to find a disc axle, and you may have to buy a whole rear axle assembly (diff+housing etc) to get one. So it's wreckers or Ebay.
Couldn't agree more. There weren't that many disc rear UC's made, Holden would never have gone to the trouble of making different axles if a spacer plate would do the job.
_CHOPPER_
Posted 18 January 2011 - 02:31 PM
Posted 18 January 2011 - 05:12 PM
_CHOPPER_
Posted 19 January 2011 - 12:18 AM
_benster208_
Posted 09 February 2011 - 09:24 PM
Posted 10 February 2011 - 05:55 PM
_wally308_
Posted 07 March 2011 - 03:31 PM
just reading through this thread, i have a UC hatch with rear drum but i brought a rear Disc Set up to go in.
i currently don't have enough funds to do the full conversion yet EG, Getting rotors machined, Getting Handbrake cable Made and getting the Calipers rebuilt,
so in the mean time i want to pull out my 3.90 center in my rear drum as it is costing me fortune be hind my worked 308.
Replace it with the 3.08 Ratio center out of the Disc brake diff .
is this just a straight swap?
what else is involved?
any info would be great
Posted 11 June 2011 - 06:25 PM
You can get a minor rebuild kit (seals not pistons) pretty cheap - less than $20ea IIRC. The calipers are the same as on one of the early falcons - XB? Try asking for that instead of UC caliper kits because no-one will have them listed.
Posted 11 June 2011 - 07:06 PM
K867S
And DB2268 for pistons
#21
Posted 12 June 2011 - 08:15 PM
#22
_UC HATCH_
Posted 20 June 2011 - 11:37 PM
Been a while since I drew that pic up and looked in here.
How did you go with you brakes in the end.
I have some other pics that may help out with others I did at the time and will add them here.
The measurements are as close as I could find out, not having the axles myself and getting them from others on the forum, as best as I can.
So if any mistakes are found let me know and I will rectify them.
Use the info if you want but double check before hand.
1/ Retainer differences (Cut down drums retainer = disk retainer) as Chopper said GMH being a tight arse
2/ Torana Disc & Drum Rear Axle dimensions (same pre machining and splineing ) again GMH being a tight arse
3/ Is for machining drum axle to a disc axle but as said earlier by chopper depends on spline end for length of spline or hardness if extending splines. (may have same length if hardened before splines cut if after maybe not ) I don't know myself depends again on GMH being a tight arse
or
For a spacer to be made to move the reaction plate out 12mm (keeps everything standard on drum axle) with a open retainer no need to replace bearings and seal if you want and can cut of old retainer or full ring spacer if new bearings and seal fitted.
(spacer measurements to fit inside the reaction plate ~120-122mm OD x 56MM ID x 12mm thick)
NOT 100%ON IF THE OLD RETAINER THICKNESS NEEDED TO BE ADDED TO THE NEW 12 RETAINER SO TRIPLE CHECK
Hope this is of any help to anyone and my pics makes sense to you.
Mark
Posted 21 June 2011 - 04:58 PM
