LS1 Conversion
#26 _ls1chook_
Posted 18 July 2011 - 05:26 PM
#27
Posted 18 July 2011 - 05:49 PM
#28 _ls1chook_
Posted 18 July 2011 - 05:53 PM
#29
Posted 18 July 2011 - 05:56 PM
#30 _ls1chook_
Posted 18 July 2011 - 08:28 PM
#31 _ls1chook_
Posted 20 July 2011 - 04:10 PM
#32 _ls1chook_
Posted 20 July 2011 - 04:26 PM
#33
Posted 20 July 2011 - 05:32 PM
#34 _ls1chook_
Posted 20 July 2011 - 07:03 PM
#35
Posted 21 July 2011 - 08:10 AM
#36
Posted 21 July 2011 - 09:08 AM
What work did you have done to your engine?
Get the MSD 5096 starter and pm fullnoise in here (he made my custom 4-1 pipes - my starter remains on the drives side to)
You can save money in the diff department by running a borg warner 28 spline diff... they weigh a shitload less then a 9" to
#37
Posted 21 July 2011 - 11:19 AM
9" factory iron LSD, factory 31 spline axles and oil, no brakes 70.5 kg. (Iron housing with LSD centre 32 kg. Housing 22 kg, axles 16.5 kg)
9" alloy Truetrac, Moser 31 spline axles and oil, no brakes 59.5 kg (Strange alloy housing with Truetrac centre 23 kg, Housing 22 kg, axles 14.5 kg)
Rorym's BW M78 Skyline, no oil, open centre, brakes and axles 64 kg. (From this thread)
If you take 8 kg off the M78 Skyline for brakes and add 1 kg for oil that makes it weigh around 57 kg vs 59.5 for the alloy centre 9". Once you add the weight of a decent centre to the BW it will probably be heavier than a alloy 9".
Personally I doubt 15 kg either way would have any measurable effect on performance.
Edited by ls2lxhatch, 21 July 2011 - 11:32 AM.
#38
Posted 21 July 2011 - 12:30 PM
Yeah I thought about a Borg Warner but I want reliability, in case I decide 2 go more power later on. the engine made 440rwhp on the dyno when inside the shop was 46 degrees( it was on black Saturday) so it's already making decent mumbo. The engine was stock, only had pacy extractors, 2.5" exhaust, upgraded valve springs, 10psi pully, extream clutch, & lowerd springs. The combo had more in it when it was 1st tuned but ran out of injectors that came with the kit, they wernt firing anymore at 105%, so couldn't tune it past 5600rpm.LS1's don't have a return fuel line from factory, are you modifying it like dirtbag did?
#39
Posted 21 July 2011 - 12:58 PM
#40
Posted 21 July 2011 - 02:19 PM
If I was to build another diff for my hatch I would be tempted to build a BW M78 with a KAAZ. As far as I know the KAAZ is not available for a 9".
#41
Posted 21 July 2011 - 03:38 PM
#42
Posted 21 July 2011 - 05:06 PM
#43
Posted 21 July 2011 - 07:05 PM
The series 78 diff has a romac spooled 3.7 centre (spools & gears available on ebay)
#44 _Liam_
Posted 21 July 2011 - 07:24 PM
#45
Posted 21 July 2011 - 08:04 PM
#46 _Liam_
Posted 21 July 2011 - 08:05 PM
#47 _Quagmire_
Posted 21 July 2011 - 08:22 PM
basicly an upgraded detroit locker or lsd
#48
Posted 21 July 2011 - 08:43 PM
The KAAZ LSD is a cross between a clutch pack LSD and a locker. In a straight line the torque is used to increase the clamping pressure on the LSD clutches. This makes the KAAZ a locking LSD.
The 9" LSD uses a clutch pack but the pressure on the clutch pack is preset when the diff is assembled. The diff has to be able to slip for cornering which means it will also slip in a straight line hence the term "Limited Slip Differential".
A locking diff will not slip in a straight line and will unlock for cornering.
Edited by ls2lxhatch, 21 July 2011 - 08:48 PM.
#49 _Liam_
Posted 21 July 2011 - 08:46 PM
#50
Posted 21 July 2011 - 08:51 PM
Yeah their standard LSD's are pretty crap thats why i got a KAAZ for later on
Are you aware that you can not engineer or register the car with a spool?
