E30 320i
65 replies to this topic
#1 TempesT
TempesT
  • 493 posts
  • Name:James - JImmy or Jim
  • Car:LX hatch
Posted 06 January 2011 - 11:32 AM
I have always loved German built cars. Ever since being around my best mates e30 325i blood red coupe I have like the BMW E30. So under the false pretense of needing a cheap runaround I picked up this little bimmer for $600.
Its a 320i auto with 165k on the clock. When I got it the brakes were no existent and leaked coolant under the dash.
First job was to fix the leak. It turned out to be a solenoid that allowed coolant to flow into the heat exchanger under the dash. It had separated in half, pulling out the brass rivets that held it together. I replaced with bolts and reinstalled. A fiddly fix but cross that off the list.
I then dumped the coolant and replaced. After doing this I was having over heating issues due to and air lock in the cooling system. After checking the thermostat and re installing I managed to solve the issue by raising the front of the car and running the heater with the bleed screw off. After some fiddling i managed to get a constant stream of coolant from the bleeder screw atop the thermostat and that solved the over heating.
Next on the list was the brakes. I wanted to put some vented x-drilled discs and EBC green stuff pads on. During the boxing day sales I was not able to find a stocked set so i decided to just slap some standard replacement DBA discs and Bendix pads in. Shed still needs a bleed to set my pedal feel but it was a marked improvement, the discs i pulled off looked to be the originals! So the rears will defiantly require the same treatment.
There is a bunch of little stuff i need to sort on on her. Lots of little trim pieces need a clean or fixing but theirs a few of these out there being wrecked atm. To get the car where I want I will put some new carpet in, replace whats broken trim wise and have some dents fixed. Then depending how keen I get I like the Idea of some bilsteins, lowering it it and a set of fake bbs 16/17's. It depends what i can find cheap. Id also like to think one day ill stumble across a wrecked 3251 and manual to go in.
Its a neat little car and im looking forward to putting her back on the road.
jim
#2 Statler
  • 6,307 posts
Posted 06 January 2011 - 11:41 AM
BMW = Bavarian money waster. :)
Good luck with it Jim. They do look better with a M-body kit.
#3 _Big T_
_Big T_
Posted 06 January 2011 - 01:23 PM
Nice !! Being raised in a BMW household (mum had a red E30 323i among many others) I have real soft spot for these cars. All my shed is missing is a 635csi and then it will be complete.
Good to see this little E30 being given some love and at $600, you cant go wrong.
#4 Collo
Collo
    ( . Y . )
  • 114,647 posts
  • Car:A Black POS
Posted 06 January 2011 - 02:16 PM
It looks pretty pissed off in this pic :P
Not a bad little car though. Good price too.
#5 _Bomber Watson_
Posted 06 January 2011 - 04:10 PM
I used to have a E30...Was a 318i though.
#6 _tyre fryer_
_tyre fryer_
Posted 08 January 2011 - 02:32 PM
My friends dad has one of these with a 355 stroker in it...
they are great little cars.
#7 TempesT
TempesT
  • 493 posts
  • Car:LX hatch
Posted 12 April 2013 - 10:55 PM
So I still have this.... and I thought I would buy a parts car for it.......$150 later
The worst bit is they guy i got it off..... well he guilted me into not wrecking it instead I have got it running and given it a clean up with the intent of RWC and dailying it.
#8 TempesT
TempesT
  • 493 posts
  • Car:LX hatch
Posted 12 April 2013 - 11:06 PM
Still scratching my head if I will take it off for a blue slip or not.
In the mean time I started buying parts for the 2door.... lol
I picked up:
- 240 getrag 5 speed manual, flywheel and cross member ect   -  $127.00
- Tail shaft to suit above 1522mm long - (sent over from the uk) $130 deliverd (took 4.5 days ! wow!)
- M20B27 complete engine - $62.77
so plan is to get the 2 door regod and pull the engine and slap the 320i 731 head on the m20b27 bottom end and attach that up to the manual
Obviously there are quite a few cosmetic things to fix in that process to.
still thinking I may sell off that parts car. hmmmmmm
Edited by TempesT, 12 April 2013 - 11:19 PM.
#9 _jabba_
_jabba_
Posted 17 April 2013 - 10:31 PM
Sell the 4 door, put your effort into the 2 door :).
#10 TempesT
TempesT
  • 493 posts
  • Car:LX hatch
Posted 11 October 2013 - 08:17 PM
LURKING
I took jabba's advice......
some cluster mods
the wheels have had some loving
about to start some body work.. obviously their is a fair whack of work I may have skimmed over but hey people only look at the pics
Body >>> interior >>>> rwc >>>> lower it >>>>> 2.7 manual coversion
Edited by TempesT, 11 October 2013 - 08:19 PM.
#11 _jabba_
_jabba_
Posted 12 October 2013 - 09:57 AM
You forgot the turbo ;).
#12 TempesT
TempesT
  • 493 posts
  • Car:LX hatch
Posted 12 October 2013 - 03:27 PM
nah jut after a fun neat daily.....
I went and rode the current model zx10r.... i think i like the giixer better
now one of these should quench the need for speed.
#13 _jabba_
_jabba_
Posted 12 October 2013 - 04:32 PM
Most fun i've had on 2 wheels is a crappy old cbr1000f i bought for a couple of hungy. I've never been on anything that moves like that in my life and its a 20 year old bike. I could only imagine how a modern litre bike would go! 2 gears get you to something like 180km/h, not sure what the rest are for hahaha.
#14 TempesT
TempesT
  • 493 posts
  • Car:LX hatch
Posted 12 October 2013 - 08:31 PM
it has three levels of traction control and three different power settings.
I told the dealer "yeh mate i dont intend on taking it off full abs/traction control and low power mode.....
second sweeper i hit I thought bugger it this is tame. traction off power setting F for FAST. it makes its power up high but wow it winds up.
still think the GSXR will suit me better.AND its 4k cheaper
Edited by TempesT, 12 October 2013 - 08:38 PM.
#15 _jabba_
_jabba_
Posted 12 October 2013 - 09:35 PM
Its kinda scary that they sell a bike like that with a go-slow mode. If you can't use a throttle then maybe you shouldn't buy a 1L bike hahaha.
#16 _markelldawe_
_markelldawe_
Posted 12 October 2013 - 10:10 PM
Should do something like this!!
DSCF4152.jpg?t=1357540809
DSCF4401_zps088e0abe.jpg?t=1361531530
#17 TempesT
TempesT
  • 493 posts
  • Car:LX hatch
Posted 13 October 2013 - 08:14 AM
gday markelldawe,
is that your car?
yeh ls1's in e30's is becoming quite popular however its a lot of work. Id love to do one (i have too many projects already) but this is just going to be a boring old cruiser.
#18 _markelldawe_
_markelldawe_
Posted 13 October 2013 - 08:31 AM
Yes, it was my car. You are not the first to make this mistake, it isn't an LS1, its a late model Toyota vvti 1uz-fe! It had an aftermarket Link computer on it, hand made extractors, a T5 manual etc. I did not ever take it to the drags but I reckon it would have done a mid to low 13. This engine replaced a turbo 2.7 stroker with 180rwkw. Great fun cars.
gday markelldawe,
is that your car?
Also, who did you use to ship your tailshaft from the UK? Someone I know wants to bring over some brake parts.
#19 TempesT
TempesT
  • 493 posts
  • Car:LX hatch
Posted 13 October 2013 - 05:16 PM
lol what a mistake... i just saw the manifold and thought ls.... I have seen a few 1uz e30 build on the net.
errrrm there was just a mob in the on ebay in the uk that have bmw spares. Their shipping prices are extremely reasonable.
#20 _Bomber Watson_
Posted 13 October 2013 - 05:27 PM
Remind me to punch you in the head next time i see you Jim, for mistaking a real mans V8 for a frOcking LS1....
#21 _jabba_
_jabba_
Posted 13 October 2013 - 09:47 PM
I thought the ls1's had a tighter v (or narrower heads) than the 1uz, i would have thought they would be easier to fit. Not saying its the wrong engine for the job tho ;).
I think a nice 1gz would be a better way to go ;)
Edited by jabba, 13 October 2013 - 09:49 PM.
#22 _Bomber Watson_
Posted 13 October 2013 - 09:52 PM
Both 90 degree V's, but the 1U has the cams in the head, so yes its wider
If you can find me a 1GZ, i'll fit it to the most ridiculous thing i can find....There like hens teeth..
#23 _jabba_
_jabba_
Posted 13 October 2013 - 09:55 PM
There has been 3 on ebay in the last 3 months. The last one went a couple of weeks ago for $2500ish. From what i've read they share the same crank pattern as the 1uz so 1uz manual conversion bits just 'fit'.
Ahh just found it
http://www.ebay.com....13250735&_uhb=1
Have you seen the turbo 1gz supra, that thing would be fuuuunnnnn. Not sure about the weight distro but who cares... Poweeeeerrrr
Edited by jabba, 13 October 2013 - 09:57 PM.
#24 _Bomber Watson_
Posted 13 October 2013 - 10:01 PM
Whats better than a 1jz? 2x 1jz's :D
#25 TempesT
TempesT
  • 493 posts
  • Car:LX hatch
Posted 13 October 2013 - 10:33 PM
the jz's are heavy buggers.....
lol all this talk of a v8 into this thing, it not gonna gonna happen lads.
I really should have looked at the engine better :(
Ill show you bomber.... i will make it my life goal to buy a jc/lj and put an aussie v8 in it.
