coil over suspension lh lx torana
35 replies to this topic
#26 _LXSKD308_
_LXSKD308_
Posted 12 July 2013 - 04:21 AM
basically i just had two discs laser cut, then welded the two mounting plates to each one, they then bolt through the old spring seat into the boot area, springs are king springs and are 150lb, and shocks are gaz,
when you say welded the plates to each one do you mean to the coilover or too the car in the spring seat
#27 ls2lxhatch
  • 5,332 posts
Posted 12 July 2013 - 04:20 PM
The coil over shock mounts are welded to the laser cut ring. The laser cut ring with the welded on shock mount is then bolted into the factory spring seat on the car.
The bump stop in the middle of the factory spring seat has to be cut out before the ring is bolted in.
This photo shows the factory spring mount. Picture from this thread.
Edited by ls2lxhatch, 12 July 2013 - 04:27 PM.
#28 _doucmyuc_
_doucmyuc_
Posted 12 July 2013 - 07:10 PM
has anyone ever achieved an inboard or alternate shock mounting system driven off a bellcrank?
#29 _LXSS350_
_LXSS350_
Posted 12 July 2013 - 09:22 PM
Not on a torrie. Are you talking off a diff or with irs?
#30 _doucmyuc_
_doucmyuc_
Posted 12 July 2013 - 10:44 PM
Solid axel - bellcranks could be mounted around or sub fllorpan with coilovers extended off that. Packaging wise would be a great option - however cost wise wouldnt be as cheap to fabricate billt bellcranks and rods than it would be to cut and shut floor pans/tubs and new subframes.
#31 _LXSS350_
_LXSS350_
Posted 12 July 2013 - 11:57 PM
Anything is possible with money but never seen it on a torrie and I have never looked at doing it. Perhaps an oversight but everything is worth considering if only for the thought process.
#32 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 14 July 2013 - 09:24 PM
Do you have more info regarding the above image?
#33 ls2lxhatch
  • 5,332 posts
Posted 14 July 2013 - 09:43 PM
The IRS is on a 1967 Chevelle Pro-Touring Tribute Car.
http://www.lateral-g...d.php4?p=404313
#34 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 15 July 2013 - 09:42 PM
Thanks for the link, there's a lot of drooling reading there.
#35 ls2lxhatch
  • 5,332 posts
Posted 15 July 2013 - 11:01 PM
I found the link using the google image search function.
If you click on the camera icon in the google image search it will allow you to search using an image.   You paste in a link to the image you are interested in and it will show you all the web pages that image appears on.
http://www.google.co...hp?hl=en&tab=wi
#36 The German
The German
  • 268 posts
  • Name:Uwe
  • Car:LH V8 1974
Posted 25 February 2018 - 05:12 AM
My KW Coilovers
Edited by The German, 25 February 2018 - 05:23 AM.
