SINGLE CAB KOMBI UTE V8 BUILDUP
#176 _dirtbag_
Posted 15 February 2012 - 06:53 PM
The time has come to weld one of the sides on.
I removed some of the paint where I want to weld and trimmed the existing body so the new side would fit on properly with no overlaps.
I did find a couple of little rust holes in the wheel tub but nothing serious.
I also sanded some of the primer off the inner sill for where I'm going to plug weld the new side on.
So that meant drilling a row of holes along the lower edge of the new side.
There's about a 1mm gap between the existing body and the new side.
At the front there's a seam where the new side will join. I'll weld the new side to the seam, which will also fill the seam. Lovely : )
Let the welding begin!
Welded.
Now it's sanded and the inner sill has been trimmed to suit.
The front pillar tapers in more than the new side, as the new side is 3 inches deeper. I'm going to split the seam and pull the pillar out to meet the new side.
It's starting to look like a proper car!
I still have to finish the wheel arches though.
You can see here how the pillar has been brought out to meet the new side.
Good storage in the sides.
And of course some rust converter : )
I can actually notice the 3 inch added to the sills now. I like it. It'll look a lot better when I finish the wheel arches though.
That's it for now : )
#177 _CraigA_
Posted 15 February 2012 - 07:06 PM
Keep it coming
#178 _dirtbag_
Posted 16 February 2012 - 04:37 PM
Well I did a little bit more today. I had to finish the wheel arches as it was bugging me.
I added the inner lip to keep it looking stock.
With that done I did the front one too.
It's funny but even though I've lengthened the car 5 1/2 inches, to me it looks like the wheel base has been shortened. The deeper side panels and longer tail create the illusion I guess, but I like it : )
#179 _Viper_
Posted 16 February 2012 - 10:30 PM
#180 _dirtbag_
Posted 17 February 2012 - 11:45 PM
#181
Posted 18 February 2012 - 12:25 AM
#182 _dirtbag_
Posted 24 March 2012 - 09:34 AM
I then started on the other side by sanding off the etch where I have to weld.
The wheel arch on this side was knocked in a bit so I gave it a bit of a hit with the slide hammer.
I got most of it out, but I'll get the rest pulled out when the side is welded on, as it's just pulling the whole tub out if I go any further.
With that done I sanded the inside of the new panel and drilled the holes along the sill for plug welding.
Let the weldathon begin : )
With all the sill plug welds done and sanded I could trim the inner sill to match. Looks much neater without the other bit sticking out the bottom : )
Then the wheel arches needed doing.
Then of course it's the usual rust converter and etch primer.
Stinga, yes there's still a bit to do. I still have to cut the rust out of the doors, make the tray, put a lip all around the top of the tray, panel beat the whole thing etc. Feel free to come and help : )
As for tail lights, we're thinking something like a low light kombi tail light. Something that's smaller than what was in this originally.
#183 _mick74lh_
Posted 24 March 2012 - 01:28 PM
#184 _Moose lc_
Posted 02 April 2012 - 10:45 PM
Great work
Moose
#185
Posted 03 April 2012 - 08:35 AM
60-66 Chev pickup would look good, or 71 Camaro, or even s4 Corvette.
A lot would depend on wheel choice and colour/style
That said,I really like early zombie lights,too.
#186 _Liam_
Posted 03 April 2012 - 11:47 AM
#187 _stretchlc_
Posted 03 April 2012 - 05:35 PM
#188 _dirtbag_
Posted 22 April 2012 - 10:18 AM
The tray is going to be timber decking running length ways. It'll be in 3 sections that will hinge at one end to gain access to all the compartments inside. I've been talking to the owner about using marine carpet to line the storage compartments so things don't rattle around so much. One thing that cropped up was the compartments filling with water. We don't want that, so I've got to make it so the water wont go in the compartments.
Anyway, the first thing I needed to do was to build a lip around the top of the tray so the timber can sit inside it.
I folded up the pieces so they wrap around the top rail, as it makes it look neater. I also added a folded safety edge along the top so there's no sharp edges.
I've made the lip 35mm high, to leave room for the drain channels and timber. Plus I think a bit more height to the tray will help it aesthetically.
The new lip will flow into the back of the cab so it'll all look like it's meant to be there.
It's amazing how long this tray is. The main pieces I've used for the lip are 2400mm long, yet I still have to fold up another piece just over 500mm long to get the length I needed : )
I've tacked the straight pieces on first. I'll make the corner pieces separately as curving the safety edge is tricky.
I've got to make recesses next to the engine lid hinge mounts so the hinge pins have room to be slid out when needed.
By making the rail cover part a bit deeper it can be used to mount the engine lid seal along the top.
The arty shot : )
Next thing I did was make the corner pieces.
Where the lip meets the cab needed to be boxed up so the timber can be in a straight line all the way along the cab, rather than having to taper into the corners.
With that done it was time to start on the drain channels. I started by fully welding the new rail pieces to the top supports that run across the tray, as the drains will cover these so I wont be able to get to them once the drains are on.
Again I folded up some 1.2mm with a safety edge to make the channels. That way when someone reaches in to grab something or work on something in one of the 3 sections they wont cut themselves on the steel edge.
I've only made the drain for the middle section, but you see how it's going to work. Each cross drain will have a hole drilled straight through it to and a tube welded in that will run to underneath the car. I'll do the same in each rear corner. Should work fine and be easy enough to make. I can't imagine this car getting driven too much on really rainy days but it can't hurt to plan ahead as much as possible.
Once all the various bits and pieces are fabricated and fitted I'll then have the fun task of a massive weldathon blending it all in, but I think it'll look pretty cool. The lids for each of the 3 compartments will just be 1.2mm zinc with a 10mm folded edge that will overlap the lips in the tray. The timber decking will get screwed to the 3 steel lids and they'll all have gas struts to support them. I still have to nut out the hinges and catches yet but I'm not at that stage yet so haven't been thinking about it. i will soon though so hopefully something will pop into my pea brain : )
Edited by dirtbag, 22 April 2012 - 10:22 AM.
#189 _SLEDGE_
Posted 22 April 2012 - 05:37 PM
#190 _j.e.d._
Posted 22 April 2012 - 06:17 PM
#191
Posted 22 April 2012 - 06:31 PM
#192 _dirtbag_
Posted 22 April 2012 - 06:48 PM
#193
Posted 22 April 2012 - 07:56 PM
Do you have a link to that thread, Tim? Assuming there is one.
The Dub is coming along beautifully, cant wait to see it with some colour.
#194 _dirtbag_
Posted 22 April 2012 - 10:02 PM
As for the falcon I haven't really done much other than started stripping it. I can start a thread if anyone wants to see it, but it is a Ford : )
#195 _Liam_
Posted 22 April 2012 - 10:09 PM
Hahaha I think you're right Paul : )
I'd love to see it Tim.
#196
Posted 22 April 2012 - 10:44 PM
#197
Posted 22 April 2012 - 10:50 PM
#198 _j.e.d._
Posted 23 April 2012 - 04:34 AM
#199 _wblje_
Posted 24 April 2012 - 07:00 PM
#200 _dirtbag_
Posted 06 May 2012 - 08:17 AM
It was blasted a couple of years ago and then given a coat of crap single pack etch, so now it's got heaps of surface rust. And structural rust : )
This shows the sill, base of A pillar and a super straight door : )
Here's the area cleaned up.
More nice stuff.
I wire wheeld the door jams and at the base of the rear dogleg was just bog. Lots of bog. Tasty : )
At least there's no more bog in there : )
Here's just a few more pics of cleaning the metal, then back to the kombi!
Nice hey : )
