Nice Jeff And because the disc is so large it moves the caliper right out of the way of most of the suspension Paint them red though.. .and remove the AMG logo
Yes....doing them in red is a given of course....will probably try to add the BREMBO decal or paint onto them like the red ones have now. (they are silkscreened from the factory I imagine) could even do something custom like HDT or HSV, that would really confuse people here
I have an adjustable proportioning valve already plumbed into the rears (it is a wilwood distribution block/adjustable valve..mounted under the master cylinder) but the rear will need all it can get probably as is, ha ha..
And probably will eventually go with something larger in the rear as well...maybe even run the 4 piston ones on the back (which is what the Mercedes use), just would have to sort out a park brake of some sort if I did that.
