What an excellent idea!
Torana hatch in California...
#726
Posted 19 December 2013 - 02:18 PM
#727
_LS1 Taxi_
Posted 19 December 2013 - 02:23 PM
Yep, really neat work!!
#728
Posted 19 December 2013 - 03:56 PM
Little bit of an update....decided I would finally add a parking brake to the car. Come across some little calipers that looked the part so picked up a pair. They are from Wilwood..and after a little mock up the cable should be able to run in a perfect spot and bracket should be pretty straight forward I reckon..going to work on them tomorrow.
They are pretty small, and the pads are not too large, but I think it will be enough since I don't normally park on 45 degree hills or anything.
hi jeff them little suckers are the go,just askin im runnin floatin hubs and me disc is only like a cm thick,wondering if ya can get thiicker pads for em
what did they set ya back bud
Maz
#729
Posted 19 December 2013 - 04:36 PM
I saw these a while ago and was looking for them everywhere and couldn't find them again.
Thanks Jeff, now I have the brand and part number. I'll have to add them to the next summit order.
Matt
#730
_LXSS350_
Posted 19 December 2013 - 06:08 PM
It depends a lot on your disc thickness. Some of them are made for quite thin discs even if you shave the pads right down.
I used these at $170ea
Mechanical Caliper can be configured for rotors width from .375" to 1.375". The caliper weight is only 2 pounds, and the size is 3.50" (w) x 2.75" (h) x 4.50" (d), and are anodized to give them a long lasting finish.
Edited by LXSS350, 19 December 2013 - 06:10 PM.
#731
_LS1 Hatch_
Posted 20 December 2013 - 01:44 AM
That is why I was sure to get the part number of one of them at least in the pictureI saw these a while ago and was looking for them everywhere and couldn't find them again.
Matt
Oh, and I got mine here..
http://www.ebay.com/...2bedd3d&vxp=mtr
#732
_LS1 Hatch_
Posted 20 December 2013 - 01:48 AM
Aside from those others above, maybe check on Wilwood's site to see if they do a narrow version as well ? These just bare fit over my disc as it is, if the pad was any thicker I wouldn't get them over.
And the mounting bolt hole threads are 3/8-24 by the way, if you can guess your length you can order up some quality bolts at the same time.
#733
Posted 20 December 2013 - 01:58 PM
thanks guys,i was the same as you toranamat69 seen em then lost them,my rotor is 7 to 8mm in thickness , not thick . 375'' would be 7- 8mm ,
rotors diameter is roughly 10.275 inches.,yours look the go LXSS350,
thanks jeff for putting yours mate up as i would still be looking for them
Maz
#734
_LS1 Hatch_
Posted 21 December 2013 - 01:48 PM
No problem, hopefully you can sort out a pair for yourself too!
My rear rotors are 330mm, and right on the width limit for the little calipers, but they seemed to fit well in the end.
In looking for cables, searches seem to only come up with Lokar and their unversal kits, but they don't have one with an actual end that fits these calipers the way I would like to see it...not a lot of other options it doesn't look like, but still doing some looking around....hmmmm...
#735
Posted 21 December 2013 - 02:33 PM
thought the old cable would work and just change the ball size but looking at pic theres another arm that the outside cover to cable must sit in which must have a flange to stop all the cable moving.is that what that is,maybe cable guy can help lol
#736
_LS1 Hatch_
Posted 21 December 2013 - 02:50 PM
I did come across (on google) a place that does do some types of custom cables not all too far away, so might even check with them.
I do have a pretty much straight shot forward along the lower control arm and to the factory little bracket that held the original cable on the body...so I can most likely copy the original routing if I want. Have to have another look under the car though and work that part out too, ha ha
#737
_LS1 Hatch_
Posted 27 December 2013 - 10:11 AM
I ended up with some Lokar cables...the numbers Wilwood reckons, and of course they don't exactly fit like they should...what is new it seems..
Got things modified though and they should do the trick though.
As well, I did want to go with the factory parking brake, but it's just a hair tight for the cable to get up to it now with how I built the headers, where the trans sits, etc. (I could probably sneak it through perhaps...) but decided to go with a hand pull type parking brake instead. I actually used a handle I had laying around from a VH/VJ Charger. I modified the mounting bracket, etc and should work out well I think. I did not mount it on the outside where it is in the Chargers, because that was always a pain in my old one getting in and out over it, if it was on. (Not that I really need to use it a lot, but still...) and with the Procar seats I have there was actually decent room for the handbrake lever between the seat and console.
Pictures to come...just finished painting the new mounting brackets and they need a bit to dry. Still will need to cut the cables to length and run them through the floor still.
#738
_LCOOLJ_
Posted 27 December 2013 - 07:33 PM
#739
_LS1 Hatch_
Posted 28 December 2013 - 02:42 AM
#740
_LS1 Hatch_
Posted 28 December 2013 - 06:53 AM
Not too shabby so far I reckon..
I had to re-angle the handle's mounting plate, and then built a spacer to bring it away from the floor about an 1", along with having a mount for the cables as well. Did need to drill a couple holes in the floor for the cables though. I will use some 3M strip caulk to seal up around them though, should do the job.
Oh, and made the stud that attaches to the original hole in the park brake handle and screws into the brass block that came with the lokar cables.
_LS1 Hatch_
Posted 28 December 2013 - 06:58 AM
And... used a rubber grommet in the original cable bracket near the body lower control arm mount..
I still want to tie the cables to the lower control arm as well now..keep it from being lose. Easy way would be to just run a cable tie through one of the original sway bar holes and tie the cable to it, but wouldn't mind doing something a little nicer looking...just have to have a think/design something perhaps. Hmmmm..
(sorry pics are a little blurry, lol)
_LS1 Taxi_
Posted 28 December 2013 - 09:15 AM
Really nice work
#743
_LS1 Hatch_
Posted 28 December 2013 - 09:28 AM
Just need to give the carpet a vacuum and put the seat back in now...oh, and might as well pull the old under dash pedal out while there is room without the seat as well.
Then just go for a drive again
#744
Posted 28 December 2013 - 09:59 AM
Nice as usual Jeff. 3M Strip Caulk isn't easily available over here, it seems, but I have it on the shopping list! That said my local Repco and AutoPro didn't even have efi hose clamps in stock last week (teenage chick tried to sell me perforated clamps instead, saying "they'll be right"), so I don't expect much.
#745
_LS1 Hatch_
Posted 28 December 2013 - 10:44 AM
I've got the 3M strip caulk here "in stock"....heck, I even have EFI hose clamps here, and never used them, lol..
(I recently picked up a huge box of brand new stainless steel hose clamps in a heap of different sizes made for silicone hoses,etc so they don't have the teeth slots in them either... from around 5/8" up to about 3" or so. )
#746
Posted 28 December 2013 - 12:49 PM
great work jeff ,park caliper looks pretty snazzy on there,good lookin lokar cables too,gee have they got any laws over there,would not get away with no handrake here,too tight , mmm,might have to move where its fun
cheers maz
#747
_LS1 Hatch_
Posted 28 December 2013 - 12:55 PM
No laws what so ever basically....aside from needing lights and what not, ha ha. No need for heater, even wipers you could get away without if you didn't drive in the wet. Any engine, blowers , no brake rules, etc, etc. (I knew somene ages ago with a T-bucket street rod with only rear brakes..and another guy who had one with front calipers but no pads in them and no lines going to them)
As nice as it is to be able to build what ever you want...does make for some scary stuff out on the roads! (some of the rat rods getting around are downright scarey!)
#748
_LXSS350_
Posted 28 December 2013 - 01:02 PM
Came out well.
You will loose nearly 1/2kg without the std park brake pedal. ..... LOL
#749
_LS1 Hatch_
Posted 28 December 2013 - 01:06 PM
#750
_LS1 Hatch_
Posted 29 December 2013 - 10:46 AM
Got the parking brake light switch on too...used the original Charger one on it, and ran a new wire up to the Torana loom for it (Used the original yellow color of course, makes it easy to track things in the future)
Then also got the 4th pedal out of the way too...cleans it up a little bit to me at least. (I like most of the original looking things about the dash, but the "other" pedal sort of in the middle of things never really grabbed me,lol)
And only skinned my thumb in two places working under the dash getting the mechanism out..
