Well....hit my first snag with the car
Was out today driving around, putting some more test miles on it, pretty close to home at least. I had pulled onto a main road with not alot of traffic and gave it abit of stick (sure pulls hard!
) and then started to slow down for the intersection where I was making a right turn and noticed it started to squeal real loud all of a sudden. I just slowed up more and got around the corner (was going to pull up and have a look) when the noise went away. Hmmmm... so kept driving and just looked down at the gauges and noticed it was only sitting at 12 volts and the temp had gone up a little.. I was only a few blocks from home at this point so just kept going...
Pulled into the driveway with the temp gauge around 3/4 of the way up and just shut the car off..popped the bonnet and the overflow coolant tank was bubbling abit and only had to look for a sec (already knew pretty well what the problem was from what had happened) and saw what it was. The belt had slipped off the idler/tensioner pulley and jammed behind it. Since it couldn't spin, the belt overheated and broke around the balancer.
When I put all the new front brackets on the engine for the a/c and alternator I used the original tensioner assembly and pulley...seemed ok at the time, but when I tried to rock it back and forth now, noticed that it does have some play in it....so looks like I should have used a new one at the time (used new everything else bolted onto the engine)
So luckily a pretty simple fix, and lucky as well it was close to home!
Will order another tensioner and belt up and get back to getting some miles on the car and hope nothing else much comes up!
