Issues with disc brake conversion
#51
Posted 22 February 2011 - 07:08 AM
#52
_nicole_
Posted 22 February 2011 - 07:15 AM
Measuring a 5 stud PCD is different to measuring 4 or 6...... Measure from outside edge of 1st stud to centre of 3rd stud, Outside edge of 3rd to 5th & so on...... 4 & 6 stud is measured from centre 2 centre......
Whats a PCD?
#53
_cruiza_
Posted 22 February 2011 - 07:20 AM
#54
_nicole_
Posted 22 February 2011 - 07:34 AM
Pitch Circle Diameter
Ok thanks for the info. Will give it a shot on a couple with very similar dimensions and see what i come up with.
#55
Posted 22 February 2011 - 12:10 PM
#56
_uctorry_
Posted 22 February 2011 - 01:20 PM
Have you thought about getting hats made up for the rear end and getting off the shelf disc fitted to these
May be more expensive up front not sure but in the long run you just replace the bolt on disc
just a thought
#57
_nicole_
Posted 22 February 2011 - 04:05 PM
Hi guys
just a thought
I dont really understand how this works, but will run it past the mister when he gets home and see what he thinks.
#58
Posted 22 February 2011 - 04:26 PM
Harder to find a suitable disc
Not recommened for handbrake style calipers as they tend to pull and can distrort the disc
#59
_nicole_
Posted 23 February 2011 - 06:03 AM
Edited by nicole, 23 February 2011 - 06:03 AM.
#60
Posted 23 February 2011 - 09:44 AM
I think those later ones are different.... ask a tyre shop or net search the stud pattern
Then get a look at a disc to see if you can cut 25mm off it and still have room for the pad
Volvo runs a handbrake inside the disc like Commodore... the bell might be too big
The 2mm offset difference might be an issue too unless your going to space the caliper back somehow
#61
_nicole_
Posted 23 February 2011 - 11:19 AM
Early Volvo is Torana pattern
Thanks Datto, I called the brake place and they're going to get one in to have a look at. The 2mm will be ok, as there's a few washers we can take out to get an extra few mm. Wouldnt have a clue about the handbrake side of it, but hopefully it will be ok.
#62
Posted 23 February 2011 - 11:25 AM
As I'm sure there will be a few interested parties who are either doing or contemplating this mod.
Cheers Ab
#63
_nicole_
Posted 23 February 2011 - 11:53 AM
Can you keep us all posted on the outcome please Nicole
Cheers Ab
Dont get your hopes up too much just yet! As Datto said, pretty slim chance of it being right, but its a lot cheaper and easier than the alternative if it works. If not, the only other alternative for us will be the blank rotors and there's not enough interest to warrant buying 25 sets of discs at above the equilibrium price.
#64
_LS1 Hatch_
Posted 23 February 2011 - 12:35 PM
And not a bad price over here and could ship some over via container..
#65
_uctorry_
Posted 23 February 2011 - 01:46 PM
what size are the discs and are they vented or solid
_LS1 Hatch_
Posted 23 February 2011 - 02:03 PM
Front first, than rear for thier original application...
_LS1 Hatch_
Posted 23 February 2011 - 02:10 PM
_nicole_
Posted 23 February 2011 - 04:49 PM
UCtorry - discs are the DBA616 specs, and Im really just chasing solid, but if vented is the same as slotted, then i'll take them if that's all i can get.
#69
Posted 23 February 2011 - 08:19 PM
The Thunderturd disc is too thick and no good to you for the caliper your using
#70
Posted 23 February 2011 - 08:24 PM
#71
_LS1 Hatch_
Posted 24 February 2011 - 01:27 AM
Thanks for the info Jeff, however our engineer wont allow us to redrill, that's the whole issue. The DBA616 discs fit perfectly, except that we want to run sprintmasters which are a different stud pattern to the skyline/pintara's.
I just mentioned the Tbird discs because they are Torana pattern is all...was not sure on the thickness issue though, good point.
The similar era Taurus was the same bolt pattern but assume discs would be similar.
I just found it out because I wanted a small donut spare wheel for my car ages ago and after a little checking around I found the Tbird space saver spare was a perfect fit on the Torana....course it's Chev pattern now with big brakes so different story..
#72
_nicole_
Posted 24 February 2011 - 06:36 AM
toranamat - lol, i'll keep that in mind!
LS1 - Thanks for your efforts, hopefully the one which should be in today will be ok. If not, given its a 5 stud disc, if we turn it, then fingers crossed we can re-drill holes where we need them, and leave the old holes empty. We want to keep the torana stud pattern if at all possible, given the wheels just cost $2k to go on them!
#73
_nicole_
Posted 26 February 2011 - 05:07 AM
#74
_nicole_
Posted 20 May 2011 - 07:17 PM
Just a quick update on this issue, have managed to source some RDA616 blank discs, which are approx 16 weeks away. The price is $135 for a pair standard, or add another $22.50 per pair for slotted.
If interested PM me and i'll update you further.
#75
_@milco@_
Posted 26 March 2012 - 11:22 PM
Hi guys,
how did you go with the blank rotors?
