Cheers Guys.
A little more info.
So far I have the engine and gearbox in and fitted. I fabricated my own engine mounts and gearbox cross member because I didn't like some of the other stuff that was out there and also just wanted to give it a go myself. I have better scaled pics of each part of the engine mounts before they were welded in the event that someone may want to copy them one day.
Growla - I did cut the tunnel out the VE just in case but found some gentle manipulation of the forward part of the torana tunnel allowed the T56 to fit ok. Not a lot of room but at least 3/8" all way round. I'm hoping it will be enough. As the gear shift setup on the VE T56 is different to an aftermarket T56 I decided to use the forward shifter mounting position after sourcing a shifter that will fit. This also gets it away from the middle floor strengthening section thingy that I have seen others need to modify.
VE Commodore T56
One version of the aftermarket T56 (There are Others)
I'll try to keep the info coming guys.
Stay tuned.
Cheers,
YT
