YT's LH Project
#26 _Gunmetal LH_
Posted 16 March 2011 - 10:44 PM
May I ask which engineer you went through?
#27 _mick74lh_
Posted 16 March 2011 - 10:50 PM
#28
Posted 17 March 2011 - 12:17 PM
#29 _Gunmetal LH_
Posted 17 March 2011 - 01:34 PM
#30 _YTsLH_
Posted 17 March 2011 - 06:37 PM
My engineers name is Doug Potts from Australian Technology. I didn�t have any problems with the proposal to Motor Reg.
Cheers,
YT
#31 _YTsLH_
Posted 17 March 2011 - 07:27 PM
*Warning I am neither a fibre glasser, or is it fibre glassier *
I basically cut the guard where it seemed best, mounted the two pieces separately to the body, then bent up a piece of tin and bolted the two bits together. I then glassed them together from the back with about 6 � 8 layers of cloth.
I also glassed in a corner fixing for the door flare.
At the Torana show I also saw a lot of flares that dipped inwards where the door and rear quarter guards met or downward to form the shape of a �M�.
This is it almost finished.
Yes, that is filler to get the shape right.
Once I have the shape all perfect I will cover it with a thin layer of fibre glass and cloth to hold it all together permanently and stop it falling off.
Cheers,
YT
#32 _YTsLH_
Posted 17 March 2011 - 07:28 PM
Edited by YTsLH, 17 March 2011 - 07:31 PM.
#33 _Liam_
Posted 17 March 2011 - 07:31 PM
#34
Posted 18 March 2011 - 08:56 AM
Mark
Edited by Growla, 18 March 2011 - 08:57 AM.
#35 _YTsLH_
Posted 27 April 2011 - 03:44 PM
The diff is still getting made.
9" Heavy Duty housing
31 spline Currie billet axels.
The proposed centre is a
4.1 STRANGE CENTRE
RACE CASE
NASCAR PINION SUPPORT
1350 YOKE
DETROIT LOCKER
Comments are welcome on this setup.
I'm fitting XF rear disks as this is what the engineer specified and is on the Statement of Requirements. I picked up the mounting brackets and callipers this week for $44.
I have also been getting rough prices for the headers and exhaust setup and also trying to source some rigid 3/8" fuel line. If anyone knows where to get some in Adelaide the help would be appreciated.
Here are the picks of the engine mounts I made before they were welded.
Cheers,
YT
#36
Posted 27 April 2011 - 04:03 PM
Thanks Shane
#37 _YTsLH_
Posted 07 June 2011 - 06:11 PM
Still awaiting the diff to be made. I've been assured it will happen this week although the centre hasn�t been ordered as yet.
I've modified the VE hydraulic clutch master cylinder to fit.
And fit the "Fly by wire" accelerator pedal.
Just need to match the pedals.
Overall I'm pretty happy with it. It�s all very strong and will take many a stomping in its life.
Hoppers Stoppers front brake kit and Drop Stubs arrived last week but wont install them until I get the diff in.
I'm also looking at an in boot fuel tank and radiator at the moment.
I'll keep you posted.
Cheers,
YT
#38 _YTsLH_
Posted 18 June 2011 - 06:21 PM
Shorten heavy duty 9� diff housing setup for LH Torana, Curry billet axles, bearings.
I re-cond a pair of XF rear callipers and mounting brackets. DBA slotted disks to suit.
Boxed upper and lower trailing arms with new bushes.
Stub tech drop stubs.
Standard Hoppers Stopper front brake kit.
I�m still awaiting the centre.
The little fella helping fix the calliper brackets and axles.
For the curious I made timber bushes and pressed them in to the inside of the diff housing to hold the axles straight while I wait for the centre.
Cheers,
YT
#39 _abtorana_
Posted 18 June 2011 - 06:36 PM
sure your not tellin porky pies (lol)
anyway i will be following this build for sure , going to be a real weapon when finished
good luck
#40 _YTsLH_
Posted 19 June 2011 - 10:10 AM
Nah, lucky enough I have a couple of people and my engineer to run ideas past. That plus lots and lots of research. I have found that everything has been done at least once on the internet
Also I work in an industrial maintenance field so have access to a lot of trades and machinery, lathes, mils, boiler making, etc.
Cheers,
YT
Edited by YTsLH, 19 June 2011 - 10:12 AM.
#41 _YTsLH_
Posted 18 July 2011 - 04:20 PM
All most finished installing a -8 aluminium fuel line. I�m going to use the original one as a return line. The front drop stubs and brakes are on. I�m hunting for a couple of HQ 15� now. I didn�t realise how hard they are to find. The engine wiring loom is on and finished some final touches to the gearbox cross member.
I�ll stick the K Frame/Engine back in this week and get stuck into the rest of the looms. Hope to have it to a point where I can turn the ignition on and see what dramas that can unfold.
Cheers,
YT
#42 _Fugly_
Posted 19 July 2011 - 09:18 PM
Might even make a set of them mounts myself, what are the bushes from?
If i had have seen your thread earlier i would have suggested different rear brakes, i use them on one of my Centura's, as brakes they work great but the handbrake is shit & in my case they are a pain is the arse when competing in burnout comps.
Thanks for contacting me with the link, i will definitely be watching.
Cheers Brenton.
#43 _YTsLH_
Posted 22 July 2011 - 05:53 PM
Here's a couple of pics of the Gearbox cross member I knocked up. The humps are to fit the 3" pipes through.
Cheers,
YT
#44 _YTsLH_
Posted 24 July 2011 - 11:40 AM
A random pick my work area.
I've plugged all the looms in and about to start nutting out any issues that arise.
Cheers,
YT
#45 _patch_
Posted 24 July 2011 - 04:16 PM
#46
Posted 24 July 2011 - 06:23 PM
#47 _patch_
Posted 24 July 2011 - 06:39 PM
#48 _BLACK LH_
Posted 24 July 2011 - 08:20 PM
#49 _YTsLH_
Posted 25 July 2011 - 11:14 AM
With the looms all plugged in again I cautiously turned the ignition on and the instruments all lit up which was a good sign. Then it went through its self check and came up with the expected faults so pretty happy with that. It gives me something to work with.
I�ll get back on it tomorrow and let you know how I go.
Cheers,
YT
#50 _LS1 Hatch_
Posted 25 July 2011 - 01:08 PM
I made my loom, and remember that first time turning the key...lol (all went well and it fired right up actually)
