15" Weld Draglites
#26
_L32M20_
Posted 15 July 2011 - 08:23 PM
#27
Posted 16 July 2011 - 09:35 AM
Not trying to second-guess you here but I don't think you should completely give up on the Draglites until you've actually tried fitting one as the clearances are so tight on the 15s to the Hoppers kit that any small margin of error in measurements could throw you out. I still think there might be some chance they will fit.Damn Im pissed off=.... the Draglites WONT fit!!!, heres the situation
I went to Chris Mills today with the dimension sheet of the Hoppers kit and took a tape measure= the overall distance I need for the brakes to clear inside the back of the wheel running the smaller 290mm Hopper Stopper kit is 360mm ( 14") but the lowest end of the rear of the 15" Draglites is measuring in at only 315mm because of the lip design on the wheel!. Higher up on the wheel it measures in at 365mm but the lower end wont clear without spacers,which I wont do.
The narrower end of the calipers needs only 320mm clearance but it angles up getting thicker as it progresses and this is where the reduced ID section is in the back of the Draglites so it will foul on the Calipers there.
From Rexy's photo above I reckon that the outer edge of the wheel centre sits slightly further toward the outside of the car than the bolt up face - my Cragars are the same, and this allows the smaller diameter section of the rim (the bit you measured at 315mm) to sit further out of the way. The sketch with the dimensions shows 3mm between bolt up face and the outside of the caliper, however this extra clearance at the outside of the wheel centre gives me enough room to easily slip a finger between the caliper and wheel centre:
(that's the clearest pic I could get, hope you can make it out, might be about time to clean the car I think!)
The dimension sketch is also a little out on the shape of the caliper shoulder (it is only a sketch after all), they actually roll off quite quickly at that 320mm diameter edge. My wheels do have the 320mm required (barely, more like 319mm) but I don't think that would clear at the position shown on the sketch anyway, it is more about the offset of the reduced diameter part of the rim. These are the 15x7s I had on there for some time:
You can see that there are recesses between the spokes and in one of these there is a balancing weight. The new 15x8s I just got don't have these recesses and I got the wheels balanced off the car then went to fit them and discovered that the weights were too wide and hung off the edge of the lip a bit, fouling the caliper! (And it was more the width than the height that was an issue). I melted down some old lead weights to the equivalent and poured it into the corner between the centre and the rim (similar to the position of the welds holding the centre) so that it didn't stick out so far, which gave me the clearance required.
Sounds like it was just dumb luck on my part that my wheels fit, I never checked any of this when I bought everything!
#28
Posted 16 July 2011 - 11:27 AM
#29
_76S.L.R_
Posted 16 July 2011 - 11:35 AM
Dan do you know 100% if Draglites fit over these damn brakes without a spacer!?
#30
Posted 17 July 2011 - 12:04 PM
#31
Posted 17 July 2011 - 07:04 PM
#32
Posted 17 July 2011 - 09:40 PM
2 FLY or LX77SL might be able to put you in contact with her
#33
Posted 18 July 2011 - 07:31 PM
If i had one i would, pretty sure MISS308 runs them on her car
I wanted to get the Hoppers 290mm kit too until I read your comments that Draglites wont fit over the calipers. When I bought my LC it camed with 2 x 15x5" Weld Pro Stars.
If you want to go halves in the shipping costs* I will send you one of my Weld Pro Star rims to trial fit? I don't know if they are the same internal profile as a Draglite, but I reckon they would have to be close.
* provided it cost $20 or less one way.
#34
Posted 18 July 2011 - 07:42 PM
Maybe they have what you need to test fit
If you get along with someone there
Even if its the wrong stud pattern you could knock the studs out of your hubs to trial fit
Or take an assembled stub down to the branch
#35
_76S.L.R_
Posted 18 July 2011 - 08:13 PM
There was a lovely Redy-orange LX 4 Door about the spearwood area( my area of Work) a few times that had the Weld Draglites on it but that was the end of last year and sadly not seen it since,I could'a asked that guy but it seems to have vanished. I cant believe no one in the Torana Club is running Draglites,I contacted guy who runs it but said no one has them on their Torry?!
HYBRID: the post cost would be too expensive mate and the design of the Pro stars compared to draglites differ too much anyways so the rear of the wheels would differ as well but I do thank you for the offer chap....
Edited by 76S.L.R, 18 July 2011 - 08:16 PM.
#36
Posted 18 July 2011 - 09:19 PM
Pick another wheel mate... your causing yourself too much heartache
Or change your brakes back to something that fits
#37
_mumbo_
Posted 18 July 2011 - 09:58 PM
#38
_76S.L.R_
Posted 30 July 2011 - 03:19 PM
Now I tried the same wheel on the back and it will definately NOT clear the rear guards and its only a 205 tyre!? (with 4.5" backspace)rear guards are not rolled.
the old 14" armolites I had on have a 4" backspace with a 215/60 tyre and did clear but not by much, I measured my 9" diff and its showing approx 1460mm from drum face to drum face,is this correct Torana length???.
So the only thing stopping me from being mobile again is finding the correct backspacing I need on front and back and I'll buy the draglites ASAP! Can anyone offer any advice on what backspacing I need?, I wanted 7" on the Front and 8" on the rears but I dont see how it would fit?. when I had that Draglite on the rear it looked to need a wheel pulled closer inwards to the car,it had a few inches of space between the tyre and Shocky. From what I see most guys are running 4.5" backspace on their Unflared Torry's and a much bigger tyre than 205 so why is mine not going to clear,I can only suspect my diff is wider for some stupid reason? HELP!!!
and a BIG thanks to Mumbo!, I now know they clear the Hoppers Brakes at least
Edited by 76S.L.R, 30 July 2011 - 03:27 PM.
#39
Posted 30 July 2011 - 05:22 PM
#40
_76S.L.R_
Posted 30 July 2011 - 05:43 PM
Edited by 76S.L.R, 30 July 2011 - 05:43 PM.
#41
_76S.L.R_
Posted 30 July 2011 - 08:47 PM
#42
Posted 30 July 2011 - 09:08 PM
#43
_76S.L.R_
Posted 30 July 2011 - 09:42 PM
Edited by 76S.L.R, 30 July 2011 - 09:42 PM.
#44
Posted 30 July 2011 - 11:18 PM
#45
_76S.L.R_
Posted 30 July 2011 - 11:44 PM
I was thinking the same thing earlier but was'nt 100% sure, though with an 8" x 5.5" backspace on rear I dunno what tyre would fit!?,I suspect I wouldnt get much bigger than a 205 on the rear due to the oversized diff problem, thats pretty darn small for rears but may have to live with it and I'll have to try get the rear guards rolled ( fronts have been done years ago).15x8 with 5.5 inch backspace and 15x7 with 4.5 inch backspace will give you an even look back and front.
#46
Posted 31 July 2011 - 02:40 AM
#47
_76S.L.R_
Posted 31 July 2011 - 04:05 AM
From memory there is roughly 60mm of spline I think?
Edited by 76S.L.R, 31 July 2011 - 04:06 AM.
#48
Posted 31 July 2011 - 04:14 AM
To give you an idea
Final Drive fitted mc donald brothers mounting kit and my old top arms to the borg warner and changed stud pattern on axles/rotors and new bearings etc for $700
So a housing cut/weld and slight shorten of axle would be pretty cheap (just strip it yourself and take housing/axles only)
Edited by DanWA, 31 July 2011 - 04:14 AM.
#49
Posted 31 July 2011 - 07:27 AM
I borrowed Mumbo's 15 x7 draglite with 4.5" Backspace and 205/ 60 tyre ... <snip> ... on the back and it will definately NOT clear the rear guards
It depends on how close the 205 on the 7" wheel is to fitting, but by moving the whole extra inch width to the inside as you've suggested by your measurements, you're moving the tyre quite a way inward too. One inch (25.4mm) extra width all offset to the inside will move the centre of the tyre 1/2" inboard, which means that in theory a 225 on the 8" wheel would have nearly 3mm more clearance to the outer guard than the 205 on the 7" wheel. If I were you I'd definitely roll the guards and if the 205 was close to scraping in then the 225 on 8" wheel may be an option which would look OK.though with an 8" x 5.5" backspace on rear I dunno what tyre would fit!?,I suspect I wouldnt get much bigger than a 205 on the rear due to the oversized diff problem, thats pretty darn small for rears but may have to live with it and I'll have to try get the rear guards rolled ( fronts have been done years ago).
#50
_76S.L.R_
Posted 31 July 2011 - 09:34 AM
I borrowed Mumbo's 15 x7 draglite with 4.5" Backspace and 205/ 60 tyre ... <snip> ... on the back and it will definately NOT clear the rear guardsIt depends on how close the 205 on the 7" wheel is to fitting, but by moving the whole extra inch width to the inside as you've suggested by your measurements, you're moving the tyre quite a way inward too. One inch (25.4mm) extra width all offset to the inside will move the centre of the tyre 1/2" inboard, which means that in theory a 225 on the 8" wheel would have nearly 3mm more clearance to the outer guard than the 205 on the 7" wheel. If I were you I'd definitely roll the guards and if the 205 was close to scraping in then the 225 on 8" wheel may be an option which would look OK.though with an 8" x 5.5" backspace on rear I dunno what tyre would fit!?,I suspect I wouldnt get much bigger than a 205 on the rear due to the oversized diff problem, thats pretty darn small for rears but may have to live with it and I'll have to try get the rear guards rolled ( fronts have been done years ago).
I'll try this option first then using=
15x 8" 5.5 backspace on the rear( trial fit a 205/60 first)
15x 7" 4.5 Backspace on fronts,is a 195x60 tyre ok on 7" rims? I'll get the guards rolled too but will need to find a mobile Guard roller guy if there is one in W.A as I cant take the car to them
