302 stroker question
_MAWLER_
Posted 14 May 2006 - 03:41 PM
I have a mate with a 302 in his XB coupe and was wanting some information on stroking it out. Can anybody tell me what the capacities are it can be taken it out too and the standard sort of rod combos, cranks and stuff ppl use.
I have no experience with ford gear so any information would be a help.
Cheers,
Posted 14 May 2006 - 05:11 PM
_MAWLER_
Posted 14 May 2006 - 05:22 PM
What if its a Windsor, none of that stuff will fit?
Cheers,
_[BOTTLEDUP]_
Posted 14 May 2006 - 05:52 PM
If its a Windsor then you're limited to 347ci, due to the smaller deck height.
_CHOPPER_
Posted 14 May 2006 - 08:59 PM
Posted 14 May 2006 - 11:27 PM
_Jewboy_
Posted 15 May 2006 - 01:51 AM
There was 351M aswell
_Jewboy_
Posted 15 May 2006 - 01:52 AM
_high_rpm_
Posted 15 May 2006 - 02:05 AM
_MRNOS_
Posted 15 May 2006 - 08:10 AM
Posted 15 May 2006 - 02:00 PM
_MAWLER_
Posted 15 May 2006 - 02:42 PM
The engine is in the car and all hooked up but no fuel system. Is there a definitive way to tell if it is a clevo or windsor without having to pull the heads off or take it out etc. The less work that has to be done the better.
2nd question, we found an old trading post add from a couple of owners ago in the bag of receits he got given which claims it was stroked to 351. Again, is it possible to verify this without doing too much work, ie, through just removing the sump and looking that way, rather than dismantling the thing.
Thanks for all the help guys, poor bloke hasn't got this far in months, haha.
_high_rpm_
Posted 15 May 2006 - 03:38 PM
the engine is alot wider as well i forget the angles but the windsors heads sits about 1/2 inches more then the clevo
_MAWLER_
Posted 15 May 2006 - 04:24 PM
Edit: From memory, the whole engine and heads are blue. So that would suggest windsor then, unless the whole kit has been resprayed in Ford blue, just for looks.
Cheers,
Edited by Liam, 15 May 2006 - 04:26 PM.
_[BOTTLEDUP]_
Posted 16 May 2006 - 12:51 PM
Clevelands are best identified by their larger 'square' style rocker covers, they also have a pressed tin timing cover. The deck height of a Clevo (from mains tunnel to head face) is 9.2" vs 8.2 for a 302W. When I get home I can post up a couple of pics of a clevo to show you what it looks like.
If the engine has been 'stroked' to a 351, then my money is on a Clevo.
Unfortunately there isn't a way to externally verify if the engine is a 302 Clevo or a 351... only difference is the stroke, which needs a head off to measure correctly.
Any other Q's feel free to PM me mate.
-Dave.
Posted 16 May 2006 - 01:53 PM
The easiest way to tell a Cleveland from a Windsor is where the top radiator hose goes. The thermostat housing is fitted to the block on a Cleveland & to the front of the inlet manifold on a Windsor.
Dr Terry.
_MAWLER_
Posted 16 May 2006 - 03:28 PM
It was all good when he had is HQ, now that he's gone to the XB, I dunno, I just can't look him in the eye anymore, lol. Has sure made me reailse I don't know squat about anything but Holdens tho.
Cheers,
Edited by Liam, 16 May 2006 - 03:29 PM.
Posted 16 May 2006 - 04:59 PM
i got told to do that when i bought my motor. still havent done it though
torrietree
_high_rpm_
Posted 16 May 2006 - 05:23 PM
here i was thinking you only knew everything about holdens...Hi Guys.
Dr Terry.
_MAWLER_
Posted 16 May 2006 - 06:27 PM
Edited by Liam, 16 May 2006 - 06:28 PM.
#21
Posted 17 May 2006 - 10:24 AM
I've been turning spanners for 30 years (& 10 years before that in my backyard) which is WAY too long.
I can answer as many questions as you like on Ford, Chryslers & even riceburners.
Dr Terry.
#22
_Pete_
Posted 19 May 2006 - 06:08 PM
#23
_Oldn64_
Posted 19 May 2006 - 06:59 PM
_MAWLER_
Posted 20 May 2006 - 09:00 AM
Good one Oldn, I always did have a problem with thinking spacially
#25
_[BOTTLEDUP]_
Posted 22 May 2006 - 07:40 PM
302 windsors and 351 windsors use a totally different block.I've got a sneaking suspicion windsors can be taken out further than 400ci, i know the 347 stroker kit is run of the mill stuff in the US and i'm positive theres a 406ci kit as well, Don't the Trick & Mansweto boys run a big inch windsor in their lovely little 2ENIL8 Capri?? that runs the big numbers down the track?
Consider one as a Big Block Chev and the other a small block.
347 is as large as you would be able to go with a 302 Windsor block, unless its an R series Ford Racing race block, which can be safely bored to 4.200.
T&M's Capri used to run a windsor based DART block (same as what I have) now it is using an after market 600ci 'mountain' motor...
Biggest cubes I can get out of mine is 455ci, but that's not really practicle, it will make more power, and last longer as a sub 440ci engine.
